I have a Epson Stylus NX400 printer and it says that it's jammed. I checked and there's no paper in it. How can I fix it?
    Scholar:
  • 60 Answers
Now there's just a few steps you need to make and this should solve the problem.....
First method ....
Now when you have a paper jam you have to check the front feeds and the rear end feeds of the printer.....the rear end feeds are normally protected by the feed door i would call it .....
(Its kinda like looking for the back cover on a remote controller....just flip the printer to the back and look for the cover and remove it and see if a paper is jammed back there)...
Second method (only if the first method did not work...)
Every company keeps records of the drivers and software for every printer that they make.....which can be located and found on the any company's website under the title " drivers and support" ....
(Follow the steps to founding the type of the exact printer you have and download the utility for the type of windows you have..) the utilities helps you found out whats wrong with the printer and reset or fix the error massage....and there you have it .....
Now if the printer has no communication with the computer this process can not be probable ...
Posted on Apr 04, 2011
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
There are pieces of paper jammed inside the printer. I cannot access them by raising the scanner. I could see a small piece but after the ink holder adjusted when I turned the machine back on, the small...
I have mine apart right now trying to fix it. I was able to get my paper jam fixed (had the same problem) by putting another piece of paper through when it tried to roll the jammed paper out.
Does that help?
Aug 13, 2011 | Epson Stylus NX400 InkJet Printer
Epson nx400 says its "Idle" and wont print.. can i
You may download software from here
Also check this link if you still have problems.
pls. vote for better service... thank you
Nov 17, 2010 | Epson Stylus NX400 InkJet Printer
Epson Printer NX400 series problem
Found this on the web. You can download the
manual, reference guide, troubleshooting guide and more. Hope this helps. If you find this helpful, pls rate. me.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=106004&infoType=Overview
According to the error codes :
Make sure there's no jammed paper or other obstruction inside your Epson Stylus.
The print head may not be able to move because of some obstruction. Follow these steps to remove jammed paper or other obstructions from the Epson Stylus:
Turn off the Epson Stylus.
Open the scanner.
Remove any jammed paper or other obstructions from the paper path.
Carefully lower the scanner.
Turn the Epson Stylus back on.
Note: If you can't remove the paper or foreign object yourself, do not use force and do not disassemble the Epson Stylus.
Good Luck............
Jan 22, 2010 | Epson Stylus NX400 InkJet Printer
Smearing my printouts
Possible that the printhead got affected when it jammed the paper.
Take all the cartridges out and put them all back into the printer. Let it charge like it normally does.
Print a nozzle check pattern if you see any gaps or breaks or any missing lines on the pattern, clean the printhead.
May 02, 2009 | Epson Stylus NX400 InkJet Printer
167 people viewed this question
k24674
