I have a TS-2000 and I was using it as a 2 meter Echolink station as well as for my HF activities. One day I started getting an intermittent buzz on the transmit audio. We also tested the unit on HF SSB and the transmission was garbled. I really don't want to have to send it to the shop if there is anything that can be done to fix this. We've tried different power supplies and that didn't change the buzz. I did a full reset but no change. Any ideas?
  • 3,289 Answers
Hi Mike.. I was plagued with some strange sounds on my Icom 756Pro receive in the past - it can be frustrating to resolve. Trouble with xmit audio could be due to poor SWR and feedline issues. I would attempt xmit into a dummy load - to isolate the antenna systems. If the objectionable audio interference clears up and the SSB is no longer garbled - the issue will lie with the feedline / antenna arrangement. If the SWR is high or antenna system has a problem - power may be getting reflected back into your radio. You may feel a slight burning on your lips if they contact your mic (and it has a metal guard as opposed to a plastic body or foam wind guard on it) while transmitting.
Check your mic and input cables. Shield and ground conductors in the input & mic cable may have opened and are acting like a small antenna in the cable. Noise has an easy "in" if these conductors have become broken. Try a different mic and cable if you can - or transmit PSK31 or RTTY and monitor the audio to see if it getting into the transmitter some way other than the mic & mic cable. Maybe even try using a notebook PC on battery power (further isolating the setup from the home electrical system) for a non-phone mode.
Good RF grounding is going to prove most helpful to prevent stray signals from getting into your gear. The antenna mast & support should be grounded especially if they are fed with coax cable. It's not such a big deal if you're using ladder line (for HF anyway). The same holds true for the radio as well. Most rigs have a terminal marked ground just for this purpose. This is NOT for safety ground connection that is run wire the 120 / 240 circuits for lights, heat and plugs in your house - it is for a heavy gauge (preferably copper) cable to connect to a ground rod system driven into or cables laid in / under the turf. The cable should be bare wherever it is contact with the soil to get a good earth connection. There is plenty of info out there to help you choose and create a good RF grounding system for your station.
Try your radio on straight battery power if possible (in the car but connected to the station antenna). Again, this isolates the radio from the home wiring. These aren't all easy - and presented in no particular order. Do the easy ones first and go from there. Ask questions on local repeaters and in rag chews on HF if comfortable enough. Most hams are more than willing to help out.
I hope this helps and good luck! please rate my reply. Thanks you
73-
Steve / K1SJC
Posted on Apr 04, 2011
I have a KENWOOD TS-940SAT HF Transceiver that powers up with the TX indicator on, no power output and no receive.
Very little information about the situation of the transceiver is provided, it might be a complex one. The Kenwood TS-940SAT features a built-in automatic antenna tuner covers the amateur bands 160 through 10 meters. It is advisable for you to reinstall the transceiver and follow the right set up step to see if it works out eventually.
Apr 18, 2016 | Computers & Internet
How do i turn off the tnc indicator on the ts2000
per the manual the main band is the default for the built in terminal node controller you may have to change it manually by pressing the vfo A or B.
Oct 24, 2014 | Kenwood TS-2000
Problem only on 40 meters when trandmitting. Other stations complain about intermittent reception.
Hi Theo,
The fact that the other bands are clear, means that on 40 mts there may or may not be a bug, remember than HF is affected by atmospheric conditions, so it may not be your radio at fault just bad atmospherics on a particular band.
Solar activity plays an important role here to.
Anyway, if this is all confusing to you, may I suggest the following:
Join yahoo group SPECIFIC to your radio Make/Model, there expertise in such matters will be a joy to you, plus you can download manuals, schematics, software and other goodies for your radio.
Yaesu is a very reliable brand and amateurs around the world use these radio for their day to day workings, just like you do.
So join up, it's free, I know, I'm a member myself.
Best regards,
Peter
Jan 08, 2013 | Yaesu FT-857D transceiver
How hard is it to replace the finals in a kenwood ts-2000
Hi Damon,
It's Bloomin' hard, and it's tricky if you have little technical knowledge.
Yes Kenwood is a darn good brand, so to keep your Kenwood darn good, pay for the repairs, it's darn worth it.
Cheers,
Peter
Jul 02, 2012 | Kenwood TS-2000
Kenwood TS 2000X: Low HF TX power output on HF bands ONLY.
Hello, this problem is solved and how?
I have the same problem on HF and VHF 30Watt max output
1.8 MHz-20M 0-5Watt
10M 25 Watt
6M-30Watt
2M-25Watt
70cm 42Watt is ok
23cm 10Watt is ok
thanks
Tuxon7@gmail.com
Jun 12, 2009 | Radio Communications
Very low TX output power on ALL HF BANDS ONLY. Other bands OK!
look for a broken or cracked board near the driver s & finals, try pushing around on the board with your plastic screwdriver, you may luck into it.
Jun 09, 2009 | Radio Communications
Phone doesn't ring at station
Sounds like your station (phone) is set to not ring. You need to check your ring assignment.
Feat # *
Enter password (default is 000000)
Press the soft key under "show"
Press the soft key under "next" until 1. STATION appears in the display.
Press the soft key under "show" SHOW STA:_ appears.
Enter your station number and press the show soft key
Press the "next" soft key until RING ASSIGNMENT shows on the display.
Press the "show" soft key. You will see CO LINE 1 : followed by NONE or DAY or NITE or BOTH.
If it says NONE, your phone never rings for an incoming call. If DAY or NIGHT your phone rings depending on the time of day and the time definitions for DAY and NIGHT programmed into the KEY unit. If it says BOTH, your phone should ring all the time.
If you need to change the setting, press the "chg" soft key until the desired setting comes up.
When you're done with LINE 1, press the "next" soft key to move to the next line. Repeat the process for all your active lines. Obvisously changing settings on lines with no CO connection will have no affect.
While your in the mode, check your RECEIVE ASSIGNM as well to make sure your phone is configured to receive incoming call. It was the station feature just before the RING ASSIGNMENT feature.
Hope this helps.
Jun 04, 2008 | Vodavi Starplus SP7314-08 Corded Phone
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
