We have no instructions how to install the thermostat. Thanks
    Brigadier General:
  • 4,736 Answers
Snuggles, we need to know what kind of thermostat you have and the model number to help you.
Posted on Apr 04, 2011
Why won't new thermostat won't turn on?
Check that one of the wires has a voltage with a test lamp
Mar 22, 2014 | Heating & Cooling
Hi, we bought a new psts11p52 thermostat. it was installed by a local installer. they did not give us english operating instructions. is there a chance that you could send us a booklet or e-mail us a...
Go to this site and you can download the manual as .pdf....
http://dar.proflo.com/darmanager/Query?PRODUCT_ID=3984136&USE_TYPE=INSTALLATION
Apr 05, 2012 | Heating & Cooling
Installed a new Filtrete thermostat on a new Carrier high-efficiency furnace. I followed instructions exactly. It doesn't work. What did I do wrong? Furnace was installed in December. Broom handle...
Hi smargyle,
Welcome to fixya!
I can provide you with diagrams for the old Carrier therm and for the new Filtrete therm. But, I would need to know what the model numbers are for each therm plus how many speeds AC you have.
Please reply back with that information and we will get your AC back in working order.
Thanks,
Handie Andie
Jul 22, 2011 | Heating & Cooling
Where is the thermostat located on a 2001 pontiac grand am SE, 6 cylinder automatic
Follow the hose from the coolant reservoir to the engine. The thermostat is behind the housing where at hose connects. Below are instructions from autozone.com. Recommend you also read my post at http://www.fixya.com/cars/r5929960-s_thermostat, and thanks for using FixYa.
3.4L Engine
  1. Drain the cooling system.
  2. Remove the air cleaner.
  3. Remove exhaust crossover pipe.
  4. Disconnect the surge tank line fitting from the coolant outlet.
  5. Remove the thermostat housing to intake manifold bolts.
  6. Remove the thermostat housing outlet and thermostat
  7. Clean the mating surfaces.
To install:
  1. Install the thermostat and housing outlet.
  2. Install the thermostat housing bolts. Tighten the thermostat housing bolts to 18 ft. lbs. (25 Nm).
  3. Install exhaust crossover pipe.
  4. Connect the surge tank line fitting to the coolant outlet. Tighten the fittings to 15 ft. lbs. (21 Nm).
  5. Install the air cleaner.
  6. Fill the cooling system.
  7. Inspect the system for leaks.
Dec 20, 2010 | 2001 Pontiac Grand Am SE
Were is the termosat loctated
In the housing at the end of the upper radiator hose.
Please see my tip at http://www.fixya.com/cars/r5929960-s_thermostat . These are generic instructions. If you get stuck, please get back to me. Below are specific instructions for your car.
  1. Drain the cooling system and tighten the drain plug.
  2. Disconnect radiator hose from thermostat cap (thermostat housing).
  3. Remove thermostat cap.
  4. Remove thermostat.
To install:
  1. When installing the thermostat, be sure to position it so that air bleed valve comes uppermost and into the recession of thermostat case.
  2. Install thermostat cap. When installing cap, align arrow marks on cap and case.
  3. Connect radiator hose to thermostat cap.
  4. Fill cooling system.
  5. After installation, check each part for leakage.
Oct 29, 2010 | 2000 Suzuki Esteem
Diagram of thermastat 2000 chevy venture
Please see my tip at http://www.fixya.com/cars/r5929960-s_thermostat . These are generic instructions. If you get stuck or need specific instructions for your car, please get back to me with model, year and engine info.
  1. Remove the air cleaner intake duct.
  2. Partially drain the cooling system.
  3. Remove the radiator inlet hose from the thermostat housing.
  4. Remove the thermostat housing bolts.
  5. Remove the thermostat.
  6. Clean and inspect the thermostat housing gasket mating surfaces.
To install:
  1. Install the thermostat.
  2. Install the thermostat housing.
  3. Install the thermostat housing bolts and tighten to 18 ft. lbs. (25 Nm).
  4. Install the radiator inlet hose to the thermostat housing.
  5. Install the air cleaner intake duct.
  7. Start the engine and check for leaks.
Oct 06, 2010 | Chevrolet Venture Cars & Trucks
Model 1f90w-51 the up down buttons stopped working this is a white-rodgers
Electronic Digital Multi-Stage Thermostat 1F83-261
  • 1F83-51 - White Rodgers Installation and Operating Instructions Thermostat 1F83-51
  • 1F86-344 - White Rodgers owners manual Thermostat 1F86-344
  • 1F86-444 - White Rodgers Installation and Operating Instructions Thermostat 1F86-444
  • 1F87-251 - White Rodgers Thermostat 1F87-251 OPERATION INSTRUCTIONS
  • 1F87-51 - White Rodgers Installation and Operating Instructions Thermostat 1F87-51
  • 1F89-11 - White Rodgers Installation and Operating Instructions Thermostat 1F89-11
  • 1F90-51 - White Rodgers OPERATION GUIDE Thermostat 1F90-51
  • Hi, This is a good stat and I have used it alot in the past as it is a older model. If you have 24 volt control voltage at the stat, and the battires are good, then you have a malfuntion in the ciruitry and will need to replace it. I have sent you a ton of manuals on there products I thiught they may be helpful. Please dont forget to rate this post as I know you will be kind. I hope I have been of help to you.
  • Sincerely,
  • Shastalaker7
  • A/C, Heating Contractor
Sep 22, 2010 | Heating & Cooling
Instructions for honeywell ct31a1003
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Jan 09, 2010 | Heating & Cooling
THERMOSTAT,P/N CT62B1015,NEED INSTALL INSTRUCTIONS
HONEYWELL WEBSITE:
Go to honeywell.com
Sep 06, 2008 | Honeywell (CT62B1015) Baseboard Heater
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
