Question about Hoover S3765-040 WindTunnel Bagless Canister Vacuum
Has diminished sucking pressure. Have new, clean filter, no blockage anywhere. When carpet attachment added, lights flash as if filter dirty. Hose will not pick up anything. Hose is clean. 2 years old; replaced 5 year old wind tunnel lost in hurricane Ike. Did I make a mistake as I loved my old Vac.? This was the first thing I bought after we lost everything. It has given me nothing but trouble.
SOURCE: steam vac will not pick up dirty water
My Hoover Steamvac problem isn't with the bruches--it's with the suction. Dirty soapy water stays in the carpet instead of being returned to one of the holding tanks.
Posted on Apr 19, 2008
Agent Don
  • 310 Answers
SOURCE: Hoover wind tunnel self propelled U6617-960
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=40485&thid=557365
Hoover Windtunnel self propelled U6617-960
Posted by srkelly on Apr 29, 2008
The vacuum has no suction at the floor. I have checked the hose, and no blockage. When I try to use the attachments, still no suction. What could be the problem.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Hoover U6437-900 / U6439-900 Windtunnel upright Vacuum
You definitely have a clod between the tube by the brushroll area and the attachment hose and the best way is to take a wire hanger and make a little hook on the end to see if there is a clog, the clog is closer to the fan area and anything big would clog up the area sideways and
-- you may have to remove the top cover to see if there is a clog and to better get @ it from the top. Another suggestion is to do a belt change whether you have one or 2 belts on the vacuum and to change the belts @ the same time every 4 to 6 months. Also, check you owner’s manual under trouble shooting to see if there is something else, other wise that is what I think is the problem. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Posted on Apr 29, 2008
reddevil6
  • 1673 Answers
SOURCE: Hoover Dirt Finder (light) not working
Good be a bad sensor, but if less then a year old, it is under warranty. I would take it in to a warranty repair shop and have them fix it.
Posted on May 13, 2008
  • 97 Answers
SOURCE: Hoover wind tunnel cyclonic U5780900
Well, the V belt is normally fairly slack until the handle is dropped below 45 degrees, which is when the belt tensioner assembly drops into place. If turning the brushroll by hand when the vacuum is in this position fails to rotate the self propel pulley, the tensioner is not functioning properly and will need to be replaced.
Also ensure that the brushroll can spin freely by hand, as these have a tendency to melt at the ends and seize the brushroll. I have also seen the groove that the v belt fits into melt itself out of round, which can cause the same symptom as you're describing.
Keep in mind as well that while the rubber belt may appear to be ok, it does have to be replaced every 3-6 months whether it breaks or not. Even though it hasn't broken, if you were to hold it up against a new belt, you would see that the old one has stretched significantly: which can decrease the machine's ability to rotate the self-propel transmission pulley and, in turn; the brushroll.
Feel free to contact me with any further questions.
-R
Posted on Oct 02, 2008
  • 50 Answers
SOURCE: no suction
I have found more vacuums on the way to the dump because they were full. Check. Is it full?
If not the air way is clogged.
Posted on May 29, 2009
Not sucking strongly enough
Hi Neil, it's Jack at Dyson.
If your DC40 isn't picking up as well as it should be, it's likely there will be a blockage that you may have missed. The most effective way to check for this is to follow the steps shown in our online Support guide: http://www.dyson.co.uk/support/dc40/dc40-multi-floor-complete/my-machine-is-not-working/machine-not-sucking-up-well/both-checks-checking-wand-and-hose-step-1
We'd also recommend washing both filters, which should be done at least once a month in normal use - the video attached should help. Use cold water without detergent, and allow at least 24 hours for them to dry before replacing them.
If you'd like some further help after you've given this a try, please call our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Jan 05, 2014 | Dyson DC40 Multi-floor Vacuum DC40
No suction
Check the airflow. A hose or filter is clogged, restricting the air flow. Change the filter (or clean it out according to the manual). Most likely, the machine sucked up some liquid, which mixed with dust and dirty clogs the filter. Also check the brush area for any blockage.
Dec 01, 2011 | Hoover Elite Rewind Bagless Upright...
No sucking
if you have no suction - then the problem could be a dirty filter or a blocked suction hose. clean the filter and check the hose from top to bottom for blockage. if all is clean and clear and you still dont have suction then the problem could be a bad vacume suction motor.
c...
Feb 02, 2011 | Hoover U5175-900 Fold Away Bagless Upright...
When I step on the head so that vaccum enguages it stops sucking. You no longer hear air being sucked through the handle as well, the head does not **** down to the floor. When you lock the handle in the...
near the bottom of the vacume where the hose bends down to the floor sweeper, check to make sure there is no blockage. this is the most common problem with vacume suction. you can use a wire coat hanger to help loosen the dirt and debris from the line and it is sometimes easier to clean properly if you remove the bottom plate ( like you would if you were changing the belt ). also while you are getting dirty and having fun, this is a good time to clean the air filter, ( tap it out good or/and use a brush or air compressor to clear and clean ).
c...
Dec 31, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
The vacuum cleaner is not sucking it has been cleaned out so is not jammed up anywhere it just won't ****.
Have you checked the filters?
It is true, you have a bag less machine-- and it catches the big dirt particles in the cyclone device--
But above that are a couple filters-- When they get dirty, you can't have any vacuum!
They really should be cleaned each time you empty the Cyclone section of debris.
Remove them, and tap them clean-- or replace them with new--
I trust that you have already checked the hose-- and it is not clogged?--
Often you can clean the hose, by reversing it-- so that you clean it from the handle, backward into the machine..
Dec 28, 2010 | Dyson DC11 All Floors Bagless Canister...
Why is the "dirty water" reservoir still empty after I cleaned the carpet?
There could be several problems that would cause the dirty water tank to be empty after you've cleaned the carpets. I'll try and walk you through each to help you diagnosis the problem.
Possible Problem #1: The dirt water tank lid may be the reason the machine is not sucking up the water. There is actually a gasket on the bottom of the lid where it connects to the actual tank itself. If the lid is not put back on properly (this is really easy to do, I've done this myself many times on my Hoover SteamVac), and the gasket is not sealing the lid to the tank, this will allow the suction to leak, greatly diminishing the suction power to **** the water back up. Try removing the lid and reinstalling it, making sure that it's put back on the correct way, and try to see if this fixed your problem.
Possible Problem #2: The Hoover SteamVac's like yours have a very poorly thought out design flaw to them on the attachment hose. Where the attachment hose connects into the SteamVac when the machine's handle is lowered to get underneath furniture and is close to the ground it puts a lot of stress on the hose where it connects into the machine (not the end the attachments go on, but the other end). This will cause the hose to tear at the stress point. This is a very common problem unfortunately, and I suspect might be the cause of your suction loss. To check this, remove the dirty water solution tank from the machine completely. Step on the handle release pedal to lower the handle part to the ground. Look at the lower part of the handle portion of the machine for where the hose enters into the handle section, then follow the hose to where it connects into the machine. Right at the end of the hose, before the hose cuff that's connected to the motor, inspect this part on all sides to see if you have a tear here. If you do, this is the reason the machine is not sucking water up off of the carpeting.
Possible Problem # 3. If neither of the first two possible problems were the source of your suction loss, try this one. Turn the machine upside down (you should probably remove both the clean water tank and dirty water tank before doing this, just to ensure that no water spills when you turn the machine over) so that the brushes are facing upwards. Look right behind the brushes for two red plastic tabs that are slightly sunken into the bottom housing of the machine. Pull these two tabs upward as far as they will go. There is a metal filter screen that will be exposed when you pull the tabs. Make sure that this screen is clear of debris. This screen protects anything from going into the motor, and if it has debris blocking it, this can cause the machine to loose suction.
Also make sure that there is nothing in the clear plastic suction channel on the top of the machine where you can see the water being sucked up. Sometimes if something gets stuck in this suction chamber, this can also cause the machine to loose suction.
I really hope that this helped you find the cause of your suction loss. If you were able to diagnosis this problem, and would like me to help you fix the cause of the suction loss, I'd be more then happy to now walk you through the repair as well. Please just use the Clarification Request form here on the same page, and I will then help you out with your repair. I just ask that if this repair was helpful to you, please help other Fixya members to find it, and rate the repair helpful by clicking the 4 Thumbs Up icons in the top corner of the repair.
Thank you very much,
Chris J.
GoVacuum
Apr 09, 2010 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Dyson hose looses suction
You have a blockage in the wand. Stand behind the machine and:
1) Remove the u-bend which is located NEXT to the right-hand side wheel, NOT above it. It connects from the bottom of the long gray hose to next to the right-hand side wheel. It is attached to the machine with a rectangular-shaped clip - push the clip and pull the pipe down.
2) Look through the wand if you can (DC07 wand is bent) - if you can't see the ground you have a blockage in either the hose or the wand
3) Remove the hose and separate it from the wand - hold the wand up into the air and look through it - if you can't see light coming through the other end, there is a blockage in the wand. Use a long object like a stick or a metal hanger to remove the blockage.
4) If the wand is clear, stretch the hose out and look for dark spots - those are the blockages. Again use a long object to remove the blockage - be careful not to damage the hose, you don't want to buy a new one.
Jun 29, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
LG V-CC162HTU my cyclonic wont **** :-(
Sometimes with a cyclonic vacuum it takes a while for all the fine dirt to be sucked out of your carpet. Sadly it could be a case of persisting until all of the fine dirt has been collected. If you have access to a compressor or air gun you can use that to gently blow out the dirt from the filter. Also make sure there's no blockage in your hose.
Feb 08, 2009 | LG Vacuums
Hoover agility wont suck
There are 2 filters and if either one gets clogged, it will not suck up the water. One is from the bottom, it is red, pull it out far enough to clean it. The other one is behind the dirty water tank, remove the tank and you can see it on the wall covering the inlet for the suction. Clean it off, you should have suction now.
Feb 13, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Won't dispense solution
Check the filter inside the dirty water tank. If it is pushed all of the way to the top, then it won't spray or suck. Also if this has the type of hose that has a block attached to it, when you removed the hose, did you put the other block back in place. Check the seal that the solution tank sits on.
Jan 09, 2008 | Hoover F7431-900 SteamVac Vacuum
Hoover S3765-040 WindTunnel Bagless Canister Vacuum Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
