Question about Canon iR 2016i Black and White Copier
Good evenin,g. I have in a phtocopying machine this error code:download standby.I want to know how i can repare it.thank you
    New Friend:
  • 140 Answers
You have to download system software. which is available with canon engineer.
Posted on Apr 23, 2011
Hello i'm french, i have an oki c 8800 with : service call 173 fatal error. i don't understand what is this error and i want to know how to repare
Error code: 173
This error code means that the fuser temperature is low. You need to replace either the fuser or the thermistor inside the fuser.
May 27, 2011 | OKI C8800dn Led Printer
Error code 9 on hoover vision hd
Dear Carol. I'm writting to you because I encounter the same problem with the same washmachine (Hoover Vision HD 9kg): fill/empty ok but the drum won't turn = error 09!
My guarantee is out of date only from 3 months and Hoover Switzerland won't help me (I have to pay for the reparation more than the machine price!!!)
I've read on another web forum that the problem could be due to an electrical component (BTB12-600BW), but before to try to change it by myself, could you please tell me how did you resolve your problem???
Please, answer me at "maisoui_cyber@hotmail.com"
Thank you
Johan
Jan 10, 2010 | Washing Machines
Download standby,CANON IR 2016jphotocopy machine
Amanuel Getachew.
I faced this type of problem before. This type of error code or message may occurs when the system software of that machine is corrupted. So flash the machine with canon driver software. then it will be ready. good luck.
Apr 06, 2009 | Canon imageRUNNER 1023iF Black and White...
Canon ImageClass MF6500 Message on machine ''Download Standby''
My Xerox copy centre C123 shows error code 124-315
and the message says to Switch off the machine and turn it on
Feb 16, 2009 | Canon Office Equipment & Supplies
I HAVE AN ERROR CODE L6 ON A SHARP AR-163 PDIGITAL IMAGER.
L6 is a problem in the laser sistem. The polygon motor doesn't work. It is reparable if you can get it out of the machine to open it and lubricate it. If it doesn't get ok it can be changed, just the motor and the small printing board. GOOD LUCK.
Nov 25, 2008 | Sharp Office Equipment & Supplies
I have a Funai HDR-B2735 dvd/video cassette recorder with HDD. When turning the machine on, it automatically switches off with the screen displaying the message "System error 02/56" before going...
Exact same symptom as above, little flashing "W" on standby, error code 02-56 on switching the unit on, promptly turns itself off. It would help no end if Funai would publish a little bit more info about these error codes on their site, or have a forum somewhere. Gona try a factory reset and a replacement HDD, dont know if i could replace it with a new one or not. any ideas or experience with these errors would be greatly appreciated!
Aug 18, 2008 | Televison & Video
Canon ir 2016 copier on display says ( Download Standby) thanks
We have a Canon IR 2016 J and in a beginning in the dispaly appears the message "Download Stanby" then after we replaced the PCB board appeared the message "System Error E354" what should we do to solve this problem, and if it is possible to send us the Service Manual with error codes for Canon IR 2016
Apr 18, 2008 | Panasonic KX-FB421 Plain Paper Film Fax
Malfunction Detected Error c-0211
C0211 Manual Tray Rise Descent Error
• The Bypass Lift-Up Sensor is not blocked even when the Tray 2 Vertical Transport Motor has turned for a given number of pulses after the sequence to move the Paper Lifting Plate from the standby position to the feed position was started.
• The Bypass Lift-Up Sensor is not unblocked even when the Tray 2 Vertical Transport Motor has turned for a given number of pulses after the sequence to move the Paper Lifting Plate from the feed position to the standby position was started.
This is a rank B error. To reset follow these steps:
Open and close the front door.
If error recurrs check the manual bypass again or call for service.
Dec 04, 2007 | Konica Minolta bizhub C250 All-In-One...
Canon iR 2016i Black and White Copier Logo
75 people viewed this question
old marine
old marine
