Question about Dryers
It is workindg but it does not dry i cleaned it out it is blowing cold air .
  • 59 Answers
REMOVE THE BACK PANEL AND CHECK THE HEAT COIL
Posted on Apr 06, 2011
I HAVE A SCOTSMAN MODEL NUMBER QD0452A SERIAL NUMBER 991262644 I HAVE RESET IT BUT IT KEEPS SHUTTING DOWN AND FLASHING RED CONTIUNSLY
Normally that means needs to be cleaned. The air filter needs to be cleaned, and if you have a air compressor, blow it out and clean it as good as you can. Also of unit comes out easily, you can also hose it out, and let it dry completely with help of using air compressor to blow out excess water, then run on fan only to help dry, then once completely dry, then turn to cold.But bottom line here it is most likely dirty.I hope this helps you. Thanks Mike from fixya.
Jul 02, 2011 | Heating & Cooling
Works and appears to blow out semi cold air, but not cold enough to cool room down......
Hello, first thing is check the condition of the filter on the front of the unit, if it is dirty wash it and let it dry then reinstall it. Also, it is a good idea to clean the evaporator coil with a can of coil cleaner that you can pick up at any heating and cooling store. Just spray cleaner on evaporator coil and let it dry. If this does not solve the problem tjen the unit might be undercharged and will need a hvac tech to recharge it.
Apr 27, 2011 | Goldstar KG6000R Window Air Conditioner
My window unit is not blowing cold air
Hello, usually when a air conditioner does not ool it falls into two categories, airflow or low refrigerant charge. The first thing is check the air filter and make sure it is clean, if it is not was the filter with soap and water and let it dry. Tjen check the evaporator and clean it with some coil cleaner, ypu can purchase coil cleaner at a hvac supply house, and then spray it on the coil and let it dry. If this does not help then the unit is low on refrigerant and must be fixed by a hvac technician.
Apr 20, 2011 | Frigidaire Heating & Cooling
Only blowing dry air.
heating coils probably bad or could be a safety switch.
Sep 30, 2009 | Dryers
Will not dry clothes,blows cold air.
need brand.most dryers have thermal fuse that protect the element from going bad.I would first check your breaker and make sure it isnt tripped.a dryer will run but not heat if breaker is tripped.
Mar 10, 2009 | Dryers
Delonghi pac-02 a/c
I had similar problem .... on very humid days unit leaks ..... temp solution for me was to drain the unit .... inserted wire coat hanger into tube .... lots of watery gook came out.. - even tilted/tipped the unit inorder to get as much water out of it.......afterwards unit worked fine.
We are VERY SASTIFIED with the Delonghi Pinguino - bought it years ago when it first came out and it has provided years of troublefree service .... the water build up / leaking was only recently - in fact we never drained the thing until this year.
Aug 23, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
Carrier 42G250CF-1 won't blow cold air (on lamp flashes)
sounds like you low on freon, you will need a qualified tech to refill the freon.
Nov 19, 2007 | Heating & Cooling
Dryers Logo
24 people viewed this question
Top Dryers Experts
