Question about Samsung SGH-A877 Impression Cell Phone
I bought a new digitizer for my phone and it came with tools but no instructions......I don't want to tear it apart without a little knowledge...lol!
  • 449 Answers
A good teardown video of the SGH-A877 is here:
and here.
Posted on Apr 04, 2011
How do I change my shifter shaft seal on my 1983 Honda atc 200es big red please help
yes of course you can alls you need is a small hook tool like dentists use and just pull it out ps.when replacing the new seal wind a small piece of electrical tape around the splines so not to damage the new seal and also dab some oil on the inner lip to help locate ( I usually tap them home with a long reach socket so they locate square ....hope this helps .....goose
Mar 04, 2015 | Honda Motorcycles
Tip
Just a "do it yourself" gal dropping in to say *THANK YOU* for your post on...
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
  1. Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
  2. If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
  3. Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
  4. Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
  5. Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
  6. With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
  7. With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
  8. Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
  9. Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
  10. Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary. If you get confused and require further assistance, please refer to my profile at http://www.fixya.com/users/jsrock516 and use the “Ask Me” feature. For excellent diagrams to assist in reassembly you can also refer to the searspartsdirect.com website. Just type in your COMPLETE washer model number and look under the Agitator Parts heading. I hope this information is found to be helpful.
on Mar 06, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Clogged
If you can find a way to reach the clog you may be able to remove it without tearing it apart. I use a flexible tool that comes from the auto parts store. It's made to reach down into tight spaces to retrieve a dropped part or nut. When you push the. Button on the handle it pushes little tines out the other end which I use. To grab the restriction to pull it out.
Mar 14, 2014 | Hoover Vacuums
My olympus stylus has no instruction book. Bought it in July. Don't know how to use.
Is a new model.
http://www.olympus.co.jp/en/support/imsg/digicamera/download/manual/
select your model and clik to download in PDF format. You need acrobat reader to open the file manual
Is importan to people who share knowledge hear your comments or received rate points
Sep 16, 2011 | Cameras
Where can I find the starter on my 02 honda shadow? Don't wanna tear apart the whole engine if I don't have too lol
just follow the hot side battery cable and it should lead you to the starter. hope that helps you.
Sep 02, 2011 | 2005 Honda Shadow Spirit 750
HOW DO I REMOVE DUST FROM THE INNER LENSE SURFACE ON THE DMD-ZS7? CAN THE FIRST RING BE REMOVED FOR ACCESS?
First of all, does this dust show up on your prints? If not, don't worry about it. All lenses have dust inside. You don't have the tools, knowledge, or re-alignment equipment necessary to take the lens apart.
Apr 25, 2011 | Panasonic Lumix DMC-ZS6 Digital Camera
I lost my last key and need the keycode to get a new one. can i find out how to get it without tearing my bike apart
to my knowledge yamaha don't keep the codes on file. its cheaper and fairly easy to replace the ignition barrel as a whole than to call a lock smith but i believe those are your two options.
Jan 05, 2011 | 1992 Yamaha FZR 600
How do I clean the dust off the sensor on my Canon Powershot SD1100IS Is there a tutorial that shows the step by step process to take the camera apart and get to the sensor?
Sensor cleaning is done on DSLR cameras, not on point-and-shoot cameras. If you take it apart without the proper equipment, alignment tools, and not to mention knowledge, you will end up with a paper weight.
Apr 18, 2010 | Canon PowerShot SD1100 IS Digital Camera
Buick lasabre ltd 1992
a few phillips head screws mostly around the door handle then just pop in plastic plugs
Jun 03, 2008 | 1992 Buick LeSabre
Samsung SGH-A877 Impression Cell Phone Logo
65 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
