Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Catode Ray Tube
My red tube has gone out. Is this something that I will able to fix myself, or am living in a fantasy world?
  • 125 Answers
What tests have you done
Posted on Aug 08, 2008
Can't see football scores on CRT (standard television, not HD flat screen)
Unfortunately there is no way to switch resolutions on a catode ray tube television
Dec 01, 2013 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
No green and yellow colour
Hello
If you see the picture in yellow colour, means that there is no blue colour output from the video drive section in your tv, Yello is the mixtrure colour of red and green. Green is actualy there. blue colour is absent.
To detect this fault, you must open your tv. Just look in to the video output section, can be located at the picture tube base card, which is plughed into it diretly. See for any loose soldering points there. Check whether transisotors are used for red, green and blue output stages, or an Ic or three seperate Ics are used for this purpose. Anyway, blue catode of your picture tube pin gets a hig voltage, and so the blue emission is absent. You just check the voltages at red,gree and blue catodes, at the respective picture tube pins, which can be taken at picture tube base card. All of these three pin voltages must be somewhat equal to each other. In your case, no voltage at blue cathode will be higher that the other two. Check for the reason. It may be due to an open video output transistor [blue], or an Ic, of one Ic if used for the three colour outputs. Check and replace the same, will rectify your problem. Ok
If you have andy difficulty, get it to me through Fixya. Ok
Gopakumar, India.
Nov 21, 2010 | JVC AV-27230 27" TV
Prima sreen goes red on me is my tube gone
no ur tv must be had loose contact in video board section...or..driver transitor or driver ic may be failed in the vedio board section..if the tube is gone then there will be several horizontal retrace line will be found with red color, and they will not shake.. have a good day..
Feb 25, 2010 | Prima CV2011 TV
The colours on my tv have gone pink and green
Either your picture tube has gone bad or the transistor or IC on the crt board, on the picture tube, that feeds the blue gun has gone bad. You would have to test the transistor to see if its shorted or open with a multi-meter, or check the voltages to and out of it. The voltages are around 200v and dangerous if touched, best left to a proffessional. If its the transistor/IC it would be a cheap and easy fix by a repair shop, if its the tube, you may want to go tv shopping.
Aug 30, 2009 | Goodmans W280NS Television
Picture tube
HELLO
If your tube has gone and you are looking to replace it - my advice is don't bother - it will cost you dear in the end. The best thing to do is try to get another CRT TV set (maybe a different make/model).
It is a skilled job replacing a TV tube and should not be attempted by anyone who does not know what they are doing!!! In the wrong hands a CRT is dangerous and could cause serious injury if dropped or handled incorrectly (it makes one hell of a bang).
I wish you luck with it all the same (:-)
Jan 18, 2009 | Samsung TXE2746 27" TV
Blue convergence wont move to the center with the yellow plus sign my picture is yellow and blue can I fix this myself
no you will need to send it to a shop to have it fixed.it will be something to do with the convergence controls .you have 3 tubes red green and blue there is no yellow tube...have a shop fix it
Dec 28, 2008 | Mitsubishi WS-55809 55" Rear Projection...
JVC TV
On projection TV's there are three tubes red,blue and green. It sounds like the green driver transistor is open. Check for loose connections or cold solder joints on the crt board at the back of the green tube.
Apr 07, 2008 | JVC AV32F476 32" TV
Crt tube removal
There is not that much high voltage on the projection tubes
Pull the red annode lead from the flyback transformer
Careful not to touch the end of the red lead
Brush the lead across the metal frame that the crt was housed in and that should disapate the hv
If you are not sure it is gone then stick it on the metal again
Remember the tv mus be unpluged befor you attempt this
Good luck
Jan 16, 2008 | Sony KP-57WV600 57" Rear Projection...
Picture Color
http://www.partstore.com/ModelDetai...close=1&exact=1
What do you think "CRT ASSY, Projection: Blue" might be?
CRT ASSY, PROJECTION: BLUE
RCA Part Number: 258486
RCA Model: D52W20
52" CRT BLUE P16LTG00BMB, DELTA 250
They want $183,
Jan 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
47 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
