Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
F1 flood fault.
Hi, I have a flooding fault on my P&P DD605SS Dishwasher. It has occured before due to "overlaoding" of unit. It has occured again( unit was not overloaded) I know how to to dry the board out ect ect but the service guy also punched in a lot of codes into the front panels...Do i need these codes to get the unit to operate properly??
Thanks,
  • MICKY66 Aug 15, 2008
    What sort of answer was this? your answering a question with an question!
Fi code comes up.....what do i do????
Posted on Aug 12, 2008
F1 has come up
This video explains how to repair this issue
Feb 21, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Error Mesage F1 beeping does not operate
The reason for F1 fault code in your dishwasher is due to the flood switch that has been activated in your unit. The best way to solve your problem is to turn off the water supply and power supply to your unit and call an authorized service center. These problems cant be fixed on your own.
Thank you !!
Aug 02, 2010 | Fisher and Paykel Dishwashers
F1 error
Thank you !!
Jul 12, 2010 | Fisher and Paykel DD605HSS 23 in. Built-in...
Eletronic oanel displays F1
Thank you !!
Jun 21, 2010 | Fisher and Paykel DS603SS Stainless Steel...
F1 fault on a ds603
The reason for your F1 fault code in your dishwasher is due to the flood switch that has been activated in your unit. The best way to solve your problem is to turn off the water supply and power supply to your unit and call an authorised service centre. These problems cant be fixed on your own.
Apr 05, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 display flashing?
Flashing wrench means a fault code has been triggered.
F1 is the fault code when flood switch at base of dishwasher cabinet turns on.
This can occur due to several reasons when moisture gets to the base of the drawer cabinet.
You will have to turn the power off and extend the drawer out as much as possible to expose the back of the cabinet. Take towels and a hair dryer to dry the base. Once the flood switch gets dry the problem will go away.
The main thing is why did the water get there. You could have a crack in the hose or simply the detergent may have caused too much foam.
Jan 07, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have a fisher paykel dishdrawer dishwasher that i get a F1 error code then it shuts down i have dried up the bottom tray but it will only work for about 1 week and it does it again
Perhaps you need to find out the source of the problem. The F1 code is due to the flood switch at the base of the housing getting triggered by water collecting. You could have a cracked hose or broken actuator arm (this is piece of plastic at the back of the drawer that holds the wires and hoses) Moisture can get to the flood switch if foaming occurs due to incorrect detergent powder being used.
Good luck
Nov 10, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Doulbe Draw model receiving an F1 error message.
F1 indicates flood switch has been activated. I wouldn't advise you attempt repair on these drawers- they really require an expert to disassemble (I worked for F+P for 10 years!!). Depending on which model you have (DD603 or DD601v2), repair varies. 603 has a small circuit board that acts as flood switch- located in base beneath drawer- requires drawer to be removed for access. 601v2 model has polystyrene float that acts as flood switch-leaks usually caused by split lid seal(tricky to access- drawer has to be removed) In either case, a leak has occurred and activated flood switch. These drawers are very sensitive to detergents (don't use tablets!!), and the way they are loaded.
Would suggest you get service technician to remedy F1 fault
Aug 07, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
F&P DD605SS dishwaser F1 FAULT
you don't need any codes if you've dried out the base and it's still not going I can talk you through finding the fault in live chat. cheers
Aug 06, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher problem
F1 is a flood code meaning excessive amounts of water have collected on the bottom catch basin. If a flood condition is detected, both draws will activate the drain motors and flash F1. Remove the bottom drawer and dry the catch basin.
May 31, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
145 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
