2-wire wireless box
I couldn't connect to the internet. When I looked, the upper red light was on. I turned the power off and now no lights will come on. I tried severqal other outlets in the house and nothing worked. So do I replace the AC adapter or the entire 2-wire box?
Also, when the box failed, I finally can hear my home phone again. I guess the in-line filters don't work?? How do I keep the 2-wire signal from interfering with my ATT&T phone line?
  • pmj_5 Mar 02, 2009
    I have the same problem as subsea51 posted back in Aug. 08......I couldn't connect to the internet. I hae no lights on. I tried severqal other outlets in the house and nothing worked. So do I replace the AC adapter or the entire 2-wire box? There is not an on or off switch in the back, just a reset button which I also tried with no luck.
    Sergeant:
    Champion:
  • 236 Answers
Did you unplugg the modem or did you switched off the power from the back?
For the filters, did you use the right filter for the modem?
there are two types of filters, one for your phones2-wire wireless box - d729562.jpg
and another for your modem
Posted on Aug 06, 2008
I have Acer Extensa 5635z with win7 ultimate but its wireless doesn't get on. I tried to update driver but couldn't be updated itself. Then I assigned driver that I got from acer web site. There I...
I would suggest to connect your Acer through wire (cable), install any good DriverInstaller and run it. Or, if you're computer literate, look for driver by using DEV_ID info from device properties. The other solution will be to buy an USB WiFi dongle.
Jul 02, 2017 | Acer InviLink 802.11b (91.49C10.002)...
Tip
Troubleshooting DSL Modems
Ever look at your DSL Modem and wonder what all those lights mean? Why do some flash, while others remain solid? What if your lights are different colors? How do you tell if your DSL Modem is working correctly?<br /> <br /> Each light on your DSL Modem represents a function. The light is an indication of whether that function is working properly. Sometimes the placement and title of each function can vary by modem manufacturer, but they are pretty standard in interpetation. If you look closely your modem, you might find that each function is labeled in small print to help identify them.<br /> <br /> A standard DSL Modem has a light for power, internet, ethernet, link and wireless connection. A healthy DSL Modem will have a steady green light that does not blink or flutter for all features other than internet, ethernet and wireless. A flashing or fluttering light indicates movement and useage. When you are connected to your DSL Modem wireless, the light for this feature will blink indicating a connection and/or active useage. If the internet connection is working properly the color of the light will be green. If the connection is working but experincing a problem the light can turn to yellow or orange. If the connection fails, the light on the DSL Modem can be red or absent depending on the problem causing the trouble. If your service is turned off by the provider, more than likely the light will be "off".<br /> <br /> If your lights turn a different color, are absent or your internet connection fails try power cycling your modem before reporting the trouble to your provider. Power cycling helps the DSL Modem to reset its connection and repair your internet services.<br /> <br /> If you are using a DSL Modem alone to connect to the internet (no additional router) you can power cycle it by first turning off your computer and then unplug the modem itself from the power source at the wall. Wait for 1 to 2 minutes and then plug it back into the power source and wait for the warm up to finish before rebooting the pc.<br /> <br /> The DSL Modem should go through the normal warm up procedures of blinking lights, making them all stable and solid green ect. You will know when its finished warming up when the features are set at solid green (other than eithernet, internet and wireless connection as explained above). When the modem finished the warm up, reboot your computer and check your internet connection.<br /> <br /> Power cycling your DSL Modem can help keep your connection healthy and running at optimal speeds.<br />
on Mar 30, 2011 | Computers & Internet
How to confirm that the BSNL modem is having problem & cannot be used any more if INET light is continuously blinking?
There are several lights on your modem/router. Each one has a function and signals whether it is working correctly by the color it is displaying and a few other factors.
All of the lights on your modem/router should be green and solid - EXCEPT for 2 which are for your internet and wireless services. Blinking means activity. If you INET light is continuously blinking that means its healthy. Blinking means activity. The internet always has activity. The blinking does not signal your activity - it signals the traffic and connection on the internet. Your wireless connection also has a light which should show activity and availability. A blinking light on your wireless connection means that either someone is connected wireless and using the internet or that the connection is up and available for wireless access.
All of your lights should be green. If you see a red or yellow light - regardless of whether it is flashing or not - it means that there is trouble or problems that need to be corrected.
Each light is marked with its function. They should say things like "power", "link", Internet or INET, and "wireless". When you turn on the modem/router during your first set up, let it power up and finish its testing before connecting your pc and turning it on. The modem will test each light, make them all go from red/yellow to green - then make them all turn solid green (not in that exact order) and this is all normal. You will know when it is done when all lights are solid green and stop blinking and/or moving (except the INET & wireless lights which will be constantly blinking). When all lights other then those two are green and steady - then its time to connect the cable to your pc and power it up.
If you are having problems with your internet connection - you can rule out the cause being your modem/router by following the instructions above. When you rule out that the modem/router is not the cause, you can continue by checking your PC.
For a wired connection (wired meaning that you are connecting your computer to the internet by using a cord/cable) the first thing you want to do is make sure that the computer is automatically sensing the connection.
Your computer should automatically sense that there is a live internet connection when you connect the ethernet cord from the modem/router to the pc. When its working right, the computer will display a connection picture which is called an "icon" on the bottom right side of your screen near the clock area. Sometimes there is a downward arrow by the clock which needs to be clicked on to expland this area and show all icons for running programs. If you see a downward pointing arrow by your clock on the bottom right side of your screen, click on the arrow.
Test that it is sensing the internet connection by unplugging the ethernet cable from your pc and watch the bottom right side of the screen at the same time. Unplug it and repeat if necessary while watching the bottom corner to see a change which indicates it senses the connection. A normal internet connection icon looks like the picture of a computer monitor. Some glow green when they are active and the ethernet cable is connected. Some show a red "X" over the picture of the monitor on the bottom right side of your screen when the internet connection is down or not working. Some will say "cable disconnected" when you unplug the ethernet cord. Some show "Cable now connected" when you plug it back in. You should see something change and/or appear if your pc is picking up the internet connection correctly. When you have verified this as true - then you can continue on to the next step of troubleshooting the internet connection.
DSL service is an internet connection that is always on. Its considered a "live" connection. DSL connections usually do not require any set up (programming or changing settings). The only time that this is not the case is when someone tries to to set up a dial up connection like aol over the top of a dsl connection. You can check this by going to your control panel, click on internet options, and choose the "connection" tab at the top. In the connection area box there should be "nothing". The connection area box is for dial up connection settings. If a dial up service was set up in the pc it would show it here (you would see AOL dial up ect). If you see a dial up connection set up and you know that you have dsl, click on the remove box and delete it from this area.
You do not need to install anything from a disk to establish an internet connection if you have a dsl line. That means you dont need an "aol" disk or software to make the internet work.
to start the internet click on the blue "e" on your desktop which stands for internet explorer.
If you have any questions you can reply to my solution by going into the problem you posted on Fixya and click on the "reply" option.
Mar 03, 2011 | Samson Technology X6v ADSL ModemWireless...
For some reason the light above the WPS button keeps flashing red. I have tried multiple reboots, none of which have worked. when connected to the ethernet modem, the light stays as a solid red color.
You need to reset your Router before setup manually.
To restore the router to factory default settings, please do the following:
1. Unplug the router's power supply
2. Press and hold the reset button on the bottom of the router
3. Keep the reset button depressed and, at the same time, plug the power supply back in
4. Keep the reset button depressed for another 10 seconds
5. Release the reset button
======================= Manually configuration ==============================
Step 1 : Connect modem - Router - Computer ( Wired )
Step 2 : Open router setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left side under internet WAN click Connection Type
Step 4 : leave the Password Blank and click submit
Step 5 : Choose the connection type as dynamic and click next
Step 6 : Leave the Host name blank and click apply
Step 7 : On the left Under Internet WAN Click MAC Address
Step 8 : Click Clone and Click Apply changes
Step 9 : If the Internet status on the top right is connected
Step 10 : Then check if you have internet
Step 11 : if not Then unplug the Power Cable from the Modem And the Router
Step 12 : Plug the power Cord to the Modem
Step 13 : Wait till all the lights are on
Step 14 : Plug the power to the belkin
Step 15 : Check the color of the light in the belkin
Step 16 :If green then Check if you have internet
If not working then call belkin
WIRELESS SETTING UP A WIRELESS CONNECTION
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Aug 16, 2010 | Belkin Wireless Play Router (F7D4302)
Trying to connect to x box live. just bought the
Okay, to connect to Xbox Live using Wireless Internet you will need this:
One Xbox Wireless connection unit, There are two types, the black and white versions. The black one is able to pick up the most diverse signals and has a higher potential for speed so I recommend that one.
You will also need, of course, a high speed internet source (modem) and a wireless router connected to the modem. When looking for wireless routers look for ones with marks claiming to be compatible with Xbox Live or a Windows OS. Those have been tested to work with Xbox.
Before trying to set up your Xbox Live, make sure your Router is set up with your computer, and set to be used as a wireless router. That's another tip all together but just follow your installation CD.
Okay so here we go!
First, Connect the wireless networking adapter to the back of your Xbox.
If you have a network cable plugged into your xbox, unplug it. Check to make sure the adapter's light is on.
Here's what the light's mean:
On the gray adapter:
No light: It's not getting enough power( try plugging it another USB slot)
Green light: It is connected to a wireless router, gateway or wireless access point.
Red light: It is not connected, and is ready for configuration.
Flashing red: There is a malfunction. (try again, if the problem persists return it for a replacement)
On the black adapter:
Green light: It is connected to a wireless router2_bing.gif, gateway or wireless access point.
Flashing green: The adapter is attempting to connect to a wireless router, gateway, or access point.
Now the CONFIGURATION, the reason most of you are reading this:
Turn your Xbox on and go to "My Xbox"
Go to "System Settings"
Go to "Network Settings"
Go to "Configure Network"
On the basic settings tab select "Wireless mode"
Select "Scan for Networks"
Select your Wireless source.
NOTE: If your Network isn't listed you will have to manually enter it.
To do this select "Specify unlisted network"
You will need to enter your SSID
Then choose which security you used to set it up on your Computer (ie: WPA, WEP...) Then enter your security code. If there is no code then select "no security"
Your adapter should have a green light now.
Now go back to "Network Settings" and select "Test Xbox Live2_bing.gif Connection"
If it works your good to go!
If not read visit: http://support.xbox.com/support/en/us/Solutions/wizardhost.aspx?wizardid=xlcsv1
Hope this tip helps :) Tell your friends and ratings are nice. Just kidding, I just hope I helped.
Jan 18, 2010 | Microsoft Wireless Network Adapter Xbox...
The only light on my router is the router light. No other lights are coming on. I have tried rebooting.
When facing the router, Globe/Internet LED is on the right. Below are the LED indicators; Check the steps below:
Wireless Security - This light will only turn on if the wireless security is enabled.
Wireless-Computer Status - This light will turn on if a wireless computer is connected to the router.
Wired-computer Status - This light will turn on if a wired computer is connected to the router. Connect the wired computer to any gray port on the router. (There are 4 gray ports).
Router Status - Power light. Solid blue means the router is on and ready.
Modem Status - If this is off, it means the router is not connected to the modem. Make sure the cable is connected from the modem to the yellow port on the router.
Internet Status - This light will indicate if the router is connected to the internet.
If this is the first time you are installing the router, then what is important is to get the router, wired-computer and modem lights ON. Once they are on, you may insert the CD that came with the Belkin router to setup the internet connection and wireless settings.
Dec 07, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Power light is red. Hub is OK. No wireless and Internet connects
Have you tried configuring your wireless settings? If your internet works hard wired, its just the wireless settings that need to be configured. Access the router's setup by going to http://192.168.0.1 and change the wireless channel. Make sure to check the wireless security as well and verify if you are using the correct wireless network key
Oct 06, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
I turned off the power to my 2wire box - now I can't get it to power up and have internet. What do I do??? More details: I had turned off the surge protector the 2wire box is connected to - when I turned...
Hi there!. unplug the power plug of your 2wire box from the surge protector for 1minute and after 1 min, plug in directly to the wall outlet, not to the surge protector. try to unplug and replug as well the connection on the back of your 2wirebox and check the cable connection from the isp cable to the modem,, the last option that your going to do is to reset the modem of your modem/router but make sure that you know the settings of your modem and wireless settings if u have.. or contact your isp provide for further details..there is a situation that there is a problem from your dsl company connection, most dsl use telephone lines..
Aug 14, 2009 | 2wire 1000hg DSL Modem & 802.11g Wireless...
Power Light Is Red, Internet Light Is Green, Other Lights Off
Check cable connections.
Try unplugging router from power for five minutes.
If that does not work call Internet Service provider to check if there is a problem with their server.
Apr 10, 2009 | Actiontec GT704WG Wireless Router...
I have a Heath Zenith 6133. It is a battery operated light switch with another swith that goes into a "box with a black and red wire coming out of it... could lyou send me the manual. thanks
The battery operated switch sends a wireless signal to the "box with wires," which takes the place of an ordinary light switch.
Turn off power, remove existing wall switch, and wire as follows:
Using wire nuts, connect "O--O", "A--A", "B--B". Both 'wireless' and 'receiver' now act as 3-way switches.
Dec 06, 2008 | Electrical Supplies
Computers & Internet Logo
270 people viewed this question
David Payne
David Payne
