Question about Ricoh Office Equipment & Supplies
How do I delete email addresses from the scanner on my Ricoh C4000?
5 Suggested Answers
  • 903 Answers
SOURCE: How to delete an email
Hi, the email addresses are stored in the copier's address book. To delete one, press the User Tools button, then go into System Settings and go to the Administrator Tools tab. Choose Address Book Management, and a list of all the users will be shown. Choose the user whose email address you want to erase and press Delete. That address will be removed from the address book.
Posted on Jan 25, 2011
  • 903 Answers
SOURCE: Resetting the Tray size on a RICOH C4000 Main Printer
When you go into the print properties in Word, you can specify the paper size that will be used in the bypass tray. Depending on which driver you are using, the settings will be a little different, but there should be an option to select the input tray -- Bypass Tray -- and paper size.
As for the orientation, Word will show you a recommendation for how to place the envelope, but this recommendation isn't always right. It's a good idea to run a test envelope through and see which way the addresses print. (The envelopes should always be face down.)
Posted on Jun 05, 2010
  • 903 Answers
SOURCE: Our company has a Ricoh Aficio 20515P
Hi, you can add email addresses one of two ways:
1. Directly from the copier: Press the User Tools button and then go into System Settings. Under the Admin Tools tab, there is a button for Address Book Management (you might have to scroll down to find it). If you go into the Address Book you can select New Program to add a new email address (and add any other information for that address that you want, such as authentication info or a display name). Just make sure to save the address before exiting out.
2. From your computer: You can add email addresses from your computer by opening your web browser and typing in the copier's IP address. The Ricoh Web Image Monitor will appear. It may or may not ask you to log in -- if it does, use whatever username and password you set up. There should be an option for the Address Book on the main page, or you might have to hunt for it, but once you find it you can add new addresses easily.
If you have a lot of email addresses to add, it will probably be a lot easier to do it from your computer than from the copier. Hope that helps!
Posted on Jul 13, 2010
SOURCE: how to delete an email
Go to system tools. Admistration tools. manage addresses. select delete then the address you choose to delete.
Posted on Feb 05, 2011
Ricoh aficio mp c4000 USB port not working
That is a protection feature. The Administrator needs to give you permission, if you are the admin contact Ricoh.
Dec 18, 2016 | Ricoh Aficio MP-C4000
How to reset error sc 582
sc582 is an inverter error. The coil that heats the fuser may be bad, or there may be a bad connection somewhere. If you go into SP mode and execute SP 5810 to reset the fuser, see if the code comes back. If it does, have a Ricoh technician check the IH coil and the connections for it.
Jan 02, 2015 | Ricoh Aficio MP-C4000
How to delete an email address (destination) from Ricoh Aficio MP 4001
Open the web click the top box and make it "blue" by clicking on it (the box with the the www.)and type the IP address into it, click enter. On the web image monitor page sighn in an admin no pass word (upper right) and click address book and you will be able to do it. - Carl
Apr 01, 2014 | Ricoh Aficio GX5050 GelSprinter InkJet
Maintenance
Time for a new drum.
Jan 07, 2014 | Ricoh Aficio MP-C4000
How to delete an email address (destination) from Ricoh C5000?
Jan 03, 2011 | Ricoh Aficio GX5050 GelSprinter InkJet
How to delete an email address on the ricoh aticio mp c5000?
Nov 29, 2010 | Ricoh Aficio GX5050 GelSprinter InkJet
I am not sure how to delete stored names from the scanner. I figured out how to add names, but we now have employees that are no longer with us...and now we don't need there email address' stored...
Press the [User Tools/Counter] key Press [System Settings]. Press [Administrator Tools]. Press [Address Book Management]. Press [Delete]. Select the registered name you want to delete. Press the name key, or enter the registered number using the number keys. Press [Yes]. Press [Exit]. Press the [User Tools/Counter] key.
Mar 25, 2010 | Ricoh Office Equipment & Supplies
Printer shows offline/Scanner has no destination list
You must program the email addresses in the machine address book, so that you will have a destination list to scan to email.
You can also try to scan by pressing the Scanner button to access the scanner function and input the email address manually by selecting manual, and then press the Start button to scan the document.
Joe
Dec 18, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
I am having trouble scanning a document on the Ricoh Aficio 2018D, I also cannot locate the user manual, can you please advise how to scan on this machine?
If the scanner has not been configured, or network settings have changed, the setup for scanning on this unit is unfortunately quite difficult for a novice. the manuals are readily available at Ricoh.com, under Downloads, but this will not help very much with the scanner config.
Sorry:(
Dec 08, 2008 | Ricoh Aficio 2018D All-In-One Laser...
1,175 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
