Question about Goodman CKL24AR24 Air Conditioner
I have a Goodman AC model number CKL 24-1, with a disconnect box that is made by miswest electric. my question is: Where do I get a replacement pull out kill switch for the disconnect box.?Someone lifted the panel on the disconnect box and pulled the switch out and its gone.
    Brigadier General:
  • 4,736 Answers
Most home centers stock this type of box and the pull out switch in their electrical parts dept. Or if you want to do it online Grainger Industrial Supply can help you. They may even have a retail location near you. http://www.grainger.com/Grainger/wwg/start.shtml
Posted on Apr 04, 2011
We have a Goodman AC Unit and the pipe continues to freeze.
either the inside coil is dirty or system is overcharged.
May 14, 2014 | Goodman CLQ36AR49 Air Conditioner
Goodman AC unit
It doesn't look like the other 4 were used. Unless when it got "yanked" it also got cut. I am betting you don't need them though.
May 14, 2013 | Heating & Cooling
Goodman ac model # G8C13024AE what tonage is it
That is a 2 ton system. Look at the model number and the 24 is the giveaway. A ton is = to 12,000 btu's. 24 = 24,000 btu's whick is 2 tons of cooling.
Hope this help's!
Audie
Dec 10, 2010 | Goodman CLJ30AR32 Air Conditioner
My Goodman Central AC Unit will not power on.
Hi, have you checked all breakers, fuses in the disconnect box at the outdoor unit as most have them in behind the pull out off plug. Please give me more information on this and I can solve this for you.
Sincerely,
Shastalaker7
A/C,
Sep 01, 2010 | Goodman Heating & Cooling
Where is the fuse/breaker on a goodman cple 18-1
Hi, I wanted to look up the numbers you gave me as you listed 2 different model numbers, the CPLE-18-1 is a 1&1/2 remote condenser and the other you showed CPLE-24-1 is a 2 ton unit. Doesn't matter, but if your power was lost you have your main breaker box at your meter, and at the condenser you will have a disconnect box with a pull out type plug. If you see no fuses, try removing the plastic cover as they are required to install 2-fuses in side the box also. If this is a split system with the outdoor and indoor unit, you will also have a breaker inside for the indoor unit, its high voltage and you will have a circuit board in the indoor unit with a 3 to 5 amp auto type plug in fuse.
I hope this has helped you out on this. I will be here if you have more questions. Please do not forget to rate me as I know you will be kind. Keep me posted.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contracted
Aug 08, 2010 | Goodman CPLE24-1 Air Conditioner
Have a goodman ckl-24-il unit with txv.need superheat,and sub-cooling chart
here is a link to a pt chart click at top right all you need. just google how to take super heat or sub cooling if you dont know how. super heat should be @ 7-12 and ur fine. if you are over 32 deg f or 55 psig u should also be fine
May 30, 2010 | Goodman CKL30AR30 Air Conditioner
What ton is good man ckl 49 il where is the model number onthe furnace
ok ready for this? To find the tonnage look at the serial # Tonnage is related to 12's If there, on the serial # there is say 0062490 the tonnage is 24 or two tons 24 divided by 12 equals 2 Say the serial # contains 0063090 then the tonnage is 2 1/2 because of the 30 hopefully you see what I am saying the number in the serial # if it can be divided by 12 or 6 this is the tonnage. If you will send me the serial number I will tell you the tonnage. The serial number is on the outside unit at the copper connections where the electrical lines go in.
Good luck on your repairs hope this helped send me a note online here and if you need I will give you tonnage if you send the model # and serial number with your response> I will check online around 1500 hours on 1/9/10 central time. Remember to look for the numbers that are divisible by either 12 or 6 on the serial number
Dave
Jan 08, 2010 | Goodman CKL60AR60 Air Conditioner
Goodman CKL24AR24 Air Conditioner Logo
289 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
