Question about Woods INDUSTRIES 59112 INDOOR DIGITAL TIMER 24-HOUR
I have a timer, time set OK at15.53 but I can not set the off time for 1.30am ,or the on time for 9;am. Could you help set this timer.
You posted under Woods timers:
Please open following link to identify timer
Add a comment and say which timer is same-similar to yours so I can read instructions alongside you and offer free help:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Oval
Try resetting timer to see if functionality is restored.
If instructions are confusing, write out the steps so they are clearer.
If you are able to follow instructions and timer does not work, timer may be defective or worn out.
I test timers and some arrive defective.
Industry standard warranty for home-use timers is 1 year.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Apr 05, 2011
How do i change sleep mode
Sleep Timer Mode
The Sleep Timer mode is an energy-saving feature that enables you to set a time for the monitor to
power on and off at the same time every day. This also extends the life of the backlight bulbs in the
monitor. The Sleep Timer has five settings:
? Set Current Time
? Set Sleep Time
? Set On Time
? Timer: On/Off
? Sleep Now
To set the timer:
1. Press the Menu button on the monitor front panel to display the OSD Menu.
2. Scroll down and highlight Management.
3. Press the OK button to select Management.
4. Scroll down and highlight and select Sleep Timer > Set Current Time.
NOTE: You must set the current local time before you reset the time for Sleep Time or On Time. Note that the time is displayed in a 24-hour clock format. For example, 1:15 p.m. is displayed as 13 hours 15 minutes. A power failure or loss of power to the monitor will cause the timer to reset to 00:00. If this occurs, you will need to reset the sleep timer mode.
5. Press the OK button once to enter the adjustment mode for hours.
6. Press the - (Minus) or + (Plus) button to adjust the hour.
7. Press the OK button again to enter the time for minutes.
8. Press the - (Minus) or + (Plus) button to adjust the minutes.
9. Press the OK button to lock in the time chosen.
10. After setting the current time, the highlight automatically skips to Set Sleep Time. Repeat steps 6 through 9 to set Sleep Time.
11. If you do not want to set Sleep Time, press the OK button twice, then select Save and Return to exit the menu.
12. After setting Sleep Time, the highlight automatically skips to Set On Time. Repeat steps 6 through 9 to set On Time.
13. Set the Timer mode to On to activate the Sleep Timer settings.
14. When you are finished, select Save and Return to exit the menu.
The fifth selection, Sleep Now, turns the monitor backlights off immediately and stays in sleep mode
until the next On Time activates or a monitor button is pressed.
May 27, 2014 | HP Pavilion 22bw Black 21.5" LED Monitor...
Setting the clock on a brinks timer 44-1011
I finally found the instructions for the Brinks timer 44-1011 and they work.
    • BRINKS DIGITAL TIMER 44-1011 INSTRUCTIONS
    • CURRENT TIME SETTING
    • 1*Press and hold the OK button for 4 seconds. Hour Display flashes.
    • 2*Press +/MANUAL or - to select the hour. Press OK to confirm.
    • 3*Minute display will now flash. Press +/MANUAL or - to select the minute. Press OK to confirm.
    • 4*Press MENU to exit the time setting mode. Now the timer is in clock mode.
    • PROGRAM SETTING NOTE: This timer can be set up for up to 2 different programs. We will use PROG 1 for this example, however these steps can be repeated for any of the 2 programs. To cycle through the individual programs use the +/MANUAL or - after pressing MENU in step one until the desired PROG "#" is flashing. To clear a program setting hit the RECALL button when you have the program selected.
    • 1*Press MENU button, PROG 1 "ON" will flash, press OK.
    • 2*Hour will flash. Cycle with +/MANUAL or - to desired hour, press OK.
    • 3*Minutes will flash. Cycle through minutes +/MANUAL or - to desired minute, press OK.
    • 4*Program will be flashing again. Press +/MANUAL to get to PROG 1 "OFF" blinking, press OK.
    • 5*Repeat steps 2-4 to complete PROG 1 setting.
    • 6*When done setting programs press the MENU button to return to clock mode.
    • 7*Press +/MANUAL to have LCD showing either "AUTO ON" or "AUTO OFF" for the timer to execute the programmed settings.
    • DAYLIGHT SAVING TIME SETTING (DLST)
    • 1*In clock mode, press RECALL to turn on or off the Daylight Saving Time.
    • 2*Turn on DLST, the below of LCD shows +1H. Time is adjusted by adding one hour.
    • 3*Turn off DLST, +1H will disappear and LCD shows the real time. MANUAL OVERRIDE AND ALWAYS ON/OFF When in clock mode the +/MANUAL sign cycles through
    • 4 settings that serve as manual override. **ON - Indicates that the timer is in the ON mode, and will always be on regardless of the programmed setting. **AUTO ON - At this selection, the timer will come on regardless of the programmed setting, but it will follow the next programmed command. **OFF - Indicates that the timer is always off (i.e. the wall socket is turned off) **AUTO OFF - Indicates that the timer is in the OFF mode until the next programmed step that turns it ON.
    • NOTE: For normal timer function, the selection must be either "AUTO ON" or "AUTO OFF". RESET At any mode, press RESET for 5 seconds. All settings will be cleared, return to clock mode, 12:00 MO, AM, AUTO OFF will be shown on LCD
I hope this is helpful. It was a bear to find.
Dec 24, 2012 | Hardware & Accessories
Problem of Utilitech digital 8 outlet power strip timer
Copy following link to identify exact timer, and download possible manual.
http://waterheatertimer.org/GE-timers-and-manuals.html#striptimer
With this particular timer, press MODE and PRG button to clear timer programming.
When programming is complete, press CLK button to enter current time setting and end programming.
Then press Mode button until Auto indicator displays.
Make sure current time is correct, and that correct am-pm selected.
Make sure that on-and-off programs are set for same days-of-week, or conflict will cause timer to work erratically.
If timer is defect, buy another timer at Lowes and return defect in new package.
Oct 22, 2012 | Hardware & Accessories
Moonrays noma landscape 9 hour power supply. cannot figure it out
You have the 9 hour 200 watt Moonray.
Copy following link to identify timer and see basic instructions by pushing button and cycling throught choices.
http://waterheatertimer.org/Woods-timers-and-manuals.html#Power-pack
Sep 23, 2012 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
I have an Intermatic ST01C timer. Works great. I just noticed that I cannot set the DUSK time past 9:11pm. Any minute before that is fine such as 9:10pm but I wanted to set it to about 9:15pm. It has...
Call Intermatic.
You can set dawn-dusk parameters a bit longer or shorter than pre-programmed dawn-dusk times.
There is a limit to how many minutes you can add or subtract to pre-programmed times, and I'm not sure how many minutes exactly.
All astronomic timers have limited number of additional minutes, and folks write to fixya occasionally about wanting to extend the limit. But there is no work-around unless you choose to set fixed on-off times instead of using astronomic feature.
If timer begins to malfunction, you reset timer and change CR2 battery, and then reprogram the timer.
Instruction manual has troubleshoot checklist.
Timer comes with 1 year limited warranty.
Open following links for ez instructions, wiring diagrams, and battery illustration:
http://waterheatertimer.org/ST01C-program.html
Jul 29, 2011 | Intermatic Inc. ST01C Digital In-Wall...
How do I set timer
manual for HB51RC
http://www.intermatic.com/%7E/media/files/intermatic/products/instructions/timers/hb61rc%20-%20english.ashx
See timer at Amazon
http://www.amazon.com/Intermatic-HB61RC-Digital-Outdoor-Control/dp/B00004W4X5
Plug timer into outlet
Plug lights into timer
Timer turns on automatically at dusk + override lets timer run during daylight hours
Timing cycle repeats each 24 hours
Use selector button to set timer
Timer must be reset after power outage or after unplugging timer.
Rotate selector button and choose one of following
F > Lights are OFF
O > Constant ON
1 through 9 > timer turns ON at dusk and turns OFF 1 to 9 hours later
d > timer turns ON at dusk and OFF at Dawn
1. through 9. > timer turns ON immediately and then turns OFF 1 to 9 hours later
Maximum wattage 1000
50 mini-bulb-string of Christmas lights is 25 watts
Dec 14, 2010 | Intermatic Outdoor Timer/Photo Control...
I want to use just the pm of the timer....for xmas lights....I see how the arrowis to be put on the 5 .....thats when i want them to come on....and 9 later in the evening....where do i put the arrow for...
You posted under The Woods/Coleman 2001 timer.
This is same as Westek TM14DOLB, Sylvania SA200 and similar to GE 57696.
If this is not your timer, add a comment with description and brand of timer.
Also see Woods timers and manuals to help identify your timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#2001
This particular timer turns ON automatically at dusk.
And then you set the dial for other options as follows.
Dial set to ON > timer ON full time
Dial set to OFF > timer OFF
Dial set to 2 4 6 8 > timer turns OFF 2 4 6 8 hours after dusk
Dial set to Dawn-dusk > timer turns OFF at dawn.
Dec 12, 2010 | Woods Outdoor Lighting Timer
How do I change the date and time on my Fuji XP10 camera?
Try this. While in Shooting Mode Select the Menu/Ok button ( center ). This brings you to the shooting menu. To the left, the "Camera" Icon is highlighted and in red. Select the button that looks like the flower ( at 9:00 position ). The "Set" Button should now be visible. Select the Timer Key ( 6:00) and Set should be highlighted. Select the Menu/Ok again and Date/Time should now be enabled. Select the Bent Arrow Key ( 3:00) and here the date format and time can be changed. Hope this helps. Therese
Oct 17, 2010 | FUJIFILM FinePix XP10 XP11 Digital Camera
How do I set the hb51r so it turns on and off after 6 hours?
manual for HB51RC
See timer at Amazon
Timer turns on automatically at dusk unless you set override feature shown below
Push selector button and choose one of following
F > Lights are OFF
O > Constant ON
From these instructions, you should push button until 6 displays. Timer will turn ON at dusk and turn OFF 6 hours later
If timer.
If you want timer to turn ON immediately and turn OFF 6 hours later, push button until 6. shows in display.
If timer does not display or does not operate correctly, then timer is suspect. Return timer for another one.
Oct 02, 2009 | Intermatic Outdoor Timer/Photo Control...
Setting
manual for HB51RC
See timer at Amazon
F > Lights are OFF
O > Constant ON
Woods  INDUSTRIES 59112 INDOOR DIGITAL TIMER 24-HOUR Logo
44 people viewed this question
Top Woods Hardware & Accessories Experts
Gene Haynes
Colin Stickland
Colin Stickland
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
