Since i bought my laptop. i can't get the keyboard the light up. it only lights went it start up like 5 seconds than it goes off. at night i would like it to light up, so i can work without needing any other lights. please help, i really need it
  • laptopbonker Apr 04, 2011
    Can your provide additional information:
    Make/Model/Manufacture
  • 139 Answers
1. there must be a key to activate the keyboard lite.
2. try to read the manual or you can find it on keys from F1 to F10.
3. it must be used with the function key.
Posted on Apr 04, 2011
Caps lock light flashing and laptop not responding
Hello.
Disconnect all power. Flip the laptop to unlock and remove the battery. Reinsert and lock the battery. Power on, again.
Hope this helps.
Jan 05, 2012 | Dell Keyboard for Inspiron 1300 B120 B130...
My emachine em350 battery is not fully charging. it started by charging to 89% then 86% now its at 65% I bought it 5 months ago. What should I do?
Here's how Dell
recommended a reset. First, power down and remove baterty. Second, unplug
AC Power adapter from computer AND wall. Third-Wait till green light goes
out. In my case, went and got coffee and watch a show. Fourth plug adapter
into wall and computer and power up WITHOUT the baterty installed. After
boot up, insert the baterty. It worked?!!?!
Sep 07, 2011 | Acer eMachines 350-2074 Netbook
Laptop wont even start to power up when power buttonis pressed the green power light comes on for about 4 to 5 seconds then goes off the same thing happens with battery or power packthe same thinh happens...
Problem may be a simle matter of the battery contacts needing to be adjusted so they make better contact for charging and use. Use a needle and ~GENTLY~ raise contact bars on either laptop or battery.
Jul 18, 2011 | Dell Latitude D610 Notebook
TV was working fine when we went to bed Monday (August 30) night. Got up the next morning and turned it on. It appeared it was going to come on, the green light flashed and then the lamp indicator light...
1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C) See Service Tip VS-78A
Sep 08, 2010 | Mitsubishi WD-52725 52". Rear Projection...
I bought a house with a Night Sentry Solid State Timer model # EJ341 and have no instructions on setting or programming the unit.
rapid Programming.
1. Move control lever to OFFCLEAR for at least 5 seconds
• red indicator light goes off
• all time settings are
erased.
2. Move control lever to ON.
• red indicator light will start
flashing.
3. Check a clock; then turn pushbutton time dial clockwise at least one click.
• stop at the half hour nearest to present time (note
AM or PM).
Note: When turning pushbutton time dial, do NOT
accidentally PRESS at the same time.
4. Press pushbutton time dial once to enter present time.
• red indicator light goes off (present time has been
recorded).
5. Turn pushbutton time dial clockwise to desired
ON time.
• red indicator light blinks with each click.
6. Press pushbutton to enter ON time.
• controlled light(s) will turn on.
7. Turn pushbutton time dial clockwise to desired
OFF time.
8. Press pushbutton time dial to enter OFF time.
• controlled light(s) turn off.
9. Repeat 5-8 for other on/off times.
10.Turn pushbutton time dial for at least 2 more turns
from the first ON time to complete this program
• red indicator light will turn on and stay on (steady
light means timer is in automatic).
Note: Pushbutton time dial does not turn
automatically after setting to indicate time of day
Aug 22, 2010 | Hardware & Accessories
I have an HP Pavilion 9000 that was working just fine. We powered it down for the day and when we went to start it up the next day it would not start. Blue light is lit where power supply plugs into...
Make sure the PS or adapter you are using is good. If it does the same with another known working adapter or battery then it appears that the cmos on the mo bo is corrupted. U might try disconnecting the hard drive and optical drive to see if unit stays on. But if it still goes out then it is definitely the board and a faulty peripheral is not to blame.
If board is bad, time to go shopping since the repair is not really cost effective given the cost of the board and the high labor expense involved.
Jun 14, 2017 | Compaq Laptop Keyboard for HP Pavilion...
Dell Latitude cpx
Try to connect and external keyboard to it
with the external monitor.
If the shortcut is in the keypads where most off the beer propably came in contact.
will now be seen if its boots up.
If it boots up with external keyboard the ptoblem is in the beer soaked keyboard.
change or clean the keyboard with isoprophanol
to dissolve moisture and beer.
This is the solution. Please vote!!!
Jul 09, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
