Question about Ovens
Hi I have a siemens HB86P.70B microwave oven approx 4 years old and the microwave switches off after a few seconds. Thanks Steve
3 Suggested Answers
SOURCE: siemens microwave oven HB86k.70b
I have the same problem, have you found out the cause?
Regards
Posted on Sep 04, 2008
caroldon
  • 17129 Answers
SOURCE: siemens HB86E560B/01 microwave oven.oven working
Please have your power rating checked on the outlet and also if possible measure the mains voltage on the outlet . If low this can trip the microwave as it runs short of current/voltage.
Also make sure the plug is tight on the socket. Choose a lower wattage and see if the microwave works a longer time. If so the microwave must be checked within for a faulty capacitor, magnetron , wave guide or transformer.
Clean the oven , check the connections within and try once again before we can infer.
Posted on Aug 19, 2011
Magnetron fan runs all the time
The timer that runs the mag is stuck. Unplug fan for 30 seconds and check it out. If not fixed, then look at replacing if microwave is older 7-8 years old.
Feb 24, 2013 | GE JKP90SPSS 27" Microwave Combination...
My electric Amana Range with self cleaning oven model Art6100 or Art6000 approx. 11 years old will not work on the clean cycle. Burners and oven work fine. We had the door off and apart to clean a few days...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Aug 28, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Siemens HB86E560B/01 microwave oven.oven working ok.when selecting wattage for microwave it cutts out after approx.30 secs. higher the wattage selection the sooner it cutts off. is there an overload heat...
Aug 19, 2011 | Ovens
Our microwave is approx. 9 years old and has started to shut off after 6 seconds. It is a Panasonci Inverter (Lost book) Type S333 (F04114182CP) Is this repairable.
1) power to display- main fuse good
2) no power to magnetron- check all realated thermal switches hidden behind control panel. Remove top grill to find two hidden screws.
May 30, 2011 | Ovens
Bottom oven switched off when setting timer. Can't get it to go on again. Oven is only a few weeks old.
Switch off from mains, reset the clock (not the timer) and it should work ok
Sep 04, 2010 | Siemens Ovens
Microwave stopped heating
HI, this will require the skilled hands of a qualified GE tech. the damaged part here is the Magnetron assembly. this is a very sensitive part that creates radiation and the heating process as well. you will need to replace this device asap if possible.
May 26, 2009 | GE Monogram® ZMC1095BFBB /...
Jenn-Air JMC7000 Microwave Stopped working
take the trim off of the microwave and on the top of the oven on the right side all the way in the back there should be a reset button just like a surge protector.
Dec 01, 2008 | Ovens
Beko DCC4521w cooker grill element
it is done from the rear and inside cavity.Can be supplied approx £24.00+p&p,Check old element for continuity.
Sep 14, 2008 | Ovens
Siemens microwave oven HB86k.70b
Regards
May 04, 2008 | Ovens
Ovens Logo
185 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
