Question about Yamaha 12V Air Pump
What should the compression be on a 98 yamaha 800gp limited be?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 118 Answers
Depending on what brand gauge your using it can be anywhere from 120 to 150 psi. Using a snap-on comp tester you should see about 140
Posted on May 18, 2011
98 Yamaha xtc 700 has spark but won't start has new plugs and getting gas
You have fuel and spark, do you have compression? Those three required. Then is the spark happening at the right time, timing being off could keep it from starting also.
Feb 01, 2017 | Yamaha Motorcycles
2008 Grizzly 450. Starts and idles fine but at about 10 mph why does it start to cut out like a rev limiter?
2011 grizzly 450 reverse rev limiter - Yamaha Grizzly ATV Forum
www.grizzlycentral.com > ... > Grizzly Engine & Transmission
Mar 11, 2012 - 9 posts
This is a discussion on 2011 grizzly 450 reverse rev limiter within the ... is for earlier model years like 2008. thanks for welcoming to the site :) rev limiter - Yamaha Grizzly ATV Forum
May 23, 2009
Grizzly 700 Reverse rev-limiter Override Mod - Page 3 ...
May 21, 2009
Hitting rev limited/ slow speed.... - Yamaha Grizzly ...
May 20, 2009
reverse rev limiter - override witch bypass - Yamaha ...
Oct 22, 2008
More results from www.grizzlycentral.com
Rev Limiter - GrizzlyOwners.Com Yamaha Grizzly Forums
www.grizzlyowners.com > Grizzly 660 > Modifications
Old 06-30-2008, 10:43 AM Thread Starter. modrak .... jasson450r is offline ... hey guys! how do you do this rev limiter mod on a 06 660 griz? i'm interested in ...
How to bypass reverse switch Grizzly 700(speed limiter ...
? 1:03
https://www.youtube.com/watch?v=l8nn5Z4cuN0
Dec 25, 2015 | Yamaha Motorcycles
Yamaha starting problems
Hi, Anonymous the starter drive/Bendix/clutch is a mechanical gear driven component that engages the clutch pack ring gear to turn over the engine. It has an internal mechanism that allows the gear to turn in one direction and once the engine starts allows the drive gear to free spin. If gear free spins in both directions then the drive gear has failed, it is not serviceable and needs to be replaced. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
How To Star Starter Clutch Replacement Sample
98 00 Yamaha XV650 Star Service Manual XVS650 Moto Data Project
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2003/LIT-11626-16-05_22.pdf
Yamaha
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 05, 2014 | 2005 Yamaha V Star Classic
Why02 yz 250 won't kick or pop start runs while pulling it but dies as it stop rolling?
Hi, Anonymous you may have a faulty cdi or charging coil issue for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Dirt Rider Magazine
98 YZ250 won run
YAMAHA YZ250 LC Owner Service Manual
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
May 16, 2014 | 2003 Yamaha YZ 250
Compression and spark but wont start
Hi, Anonymous are you getting fuel? for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
98 YZ 125 won start
yz 125 wont start
Yamaha YZ125N1 Service Manual
May 03, 2014 | Yamaha YZ 125 Motorcycles
I have a 93 yz125 and it wont start, I got fire, fuel, and 120lbs of compression and ideas?
Hi, Baileys3223 you may have a timing issue for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
98 YZ 125 won start
Dirt Rider Magazine
YAMAHA YZ125 Owner Service Manual
Sep 30, 2012 | 2004 Yamaha YZ 125
Looking to buy used waverunners.one is 98 yamaha gp 800 93hrs. limited,the other is95 seadoo gts580cc 177hrs.what should the compression test reading be and what else should i check? mav7273@aol.com
For a motor to run the compression needs to be over 110 PSI. The normal compression will be between 130 PSI and 175 PSI . What is important is that both or all three cylinders be with in 5 to 10 PSI of each other. If one cylinder has much lower compression than another it is an indication that motor work is necessary to fix the imbalance. With older boats it is always a good idea to pull the motors and replace the crankshaft end seals. Also it is not a boat if it does not float. Inspect the hull for damage, cracks , holes, bashes/bruises, these will need to be repaired. Figure out how to look into the intake grate and inspect the impeller and mated surface for nicks damage. Seadoo's have a replaceable plastic ring around the impeller ($80) that is easily torn up by rocks and debris. If the gap between the impeller and the ring is wide you will lose significant thrust. Only your own sweat equity will make a boat needing a lot of work a good deal. Happy Riding.
Apr 04, 2011 | Yamaha 12V Air Pump
98 Yamaha R1 been sitting now seized any answers please ?
I'd pull the spark plugs and shoot a little WD40 in the cylinders. try to turn it over without reinstalling the plugs. Hopefully since it's not under any compressive strain, it'll turn over for you. When it does, reinstall the plugs.
I hope this helps... Good luck!
Sep 23, 2009 | 1998 Yamaha YZF-R1
Yamaha 12V Air Pump Logo
80 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Craig Butler
Craig Butler
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
