Question about Nokia 5610 Blue Quadband 3.15MP A2DP + Gift + WTY Cellular Phone
I can not activate the bluetooth it stays in off. after an reinstall of the new firmware 10.0 , when i select bluetooth the phone is trying to activate it but it stays off. the radio also keeps searching for stations , he can not find radio stations. do you have a solution regards Patrcik
  • 75 Answers
Reinstall the firmware or just reflash the phone with the current latest firmware. your problem will be solved..
PLEASE RATE THIS ANSWER, IF YOU GET ANY HELP FROM THIS ANSWER OR LIKE THE ANSWER
Posted on Apr 04, 2011
  • Adwovemai May 29, 2012
    I face d same proplem.. I ve reinstale firmware twice bt i see no change.
Bluetooth is not activating
reset to default factory settings first, if not done reinstall the firmware (assuming bluetooth is physically gud) if both not work then you have to replace bluetooth from mobile phone.
Aug 20, 2011 | Samsung SGH-L700 Cell Phone
How do i set the blue tooth settings on my nokia c3
From your phone's menu, select 'settings'.
Go to 'connectivity', select 'bluetooth'. Under the bluetooth menu, you would see the following sub menu
1. Blue tooth
can be set to either 'on' or 'off'.
2.conn. to audio access - you select this if yuo want to connect your phone to a bluetooth earpiece.
3. Paired device
under this, you would see 'add
new device'. You select it if there
is a new device you want to add.
4. Active devices - it shows any device that is active.
5. Phone visibility.
Select 'always visible' if you want
your device to always be visible
to any active device.
Select 'temporarily visible' if you
want to be temporarily visible.
Select 'hidden' if you want to be
hidden. To other devices.
6. My phones' name. Select this to change your phones' name from the default to any name of your choice.
Hope this was helpful? Please do indicate. Success.
Apr 11, 2011 | Nokia C3 Cell Phone
I did hard reset by using *,3,green button and switch button after i couldn't open it because of i forget my security password
Nanosh,
The hard setting and all will not undo the security password. There is only one way to get rid of the password and that is to get the firmware reinstalled. Nokia permits users to reinstall the firmware. So, do the following after fully charging the phone's battery:
1. Install the Nokia PC Suite on your computer.
2. Connect the phone to the computer through the USB cable (do not connect using Bluetooth).
3. Fire up PC Suite.
4. Select the option of Updating the firmware.
Thephone will be as good as new after the reinstallation is complete.
Feb 08, 2011 | Computers & Internet
My bluetooth stopped working on my phone. I press activate bluetooth and it says that its activating and an egg timer comes up. But that never goes away. Then you press the hang up button and it goes to...
This could be caused by a firmware issue but is more likely a fault with the phones Bluetooth controller. Stay away from free codes you find on the internet because incorrect use could make the problem worsee. Take the phone to a reputable mobile phone engineer or Samsung Service Point for repair.
May 21, 2010 | Samsung J700 Cellular Phone
Pairing with a motorola bluetooth device
Hello, Barb.
Here are some instructions from the manual:
To set up a Bluetooth connection, do the following:
1. Select Menu > Settings >
Connectivity > Bluetooth.
2. To activate or deactivate the Bluetooth function, select
Bluetooth > On or Off.
Indicates an active Bluetooth connection.
3. To search for compatible Bluetooth audio devices, select
Search for audio enhancements and the device that you want to connect to the phone.
To search for any Bluetooth device in range, select Paired
devices. Select New to list any Bluetooth device in range.
Scroll to a device, and select Pair.
4. Enter the Bluetooth passcode of the device to associate (pair)
the device to your phone. You must only give this passcode when you connect to the device for the first time. Your phone connects to the device, and you can start data transfer.
Hope this helps.
Apr 19, 2010 | Nokia 6085 Cellular Phone
New motorola v3m razr phone will not find any bluetooth devices
Is this a repair store,some stores have a tec that can reload the firmware and any new updates for the phone. The warranty is probably over and moto would charge you to repair the phone. See how far away that there is a Verizon that can reload the firmware.
Also,thanks to verizon for being thieves that you can not transfer
anything with bluetooth, so if you want bluetooth for your pc, or to transfer anything your out of luck. verizon has disabled
Obex in the firmware of the phone. You can bluetooth a headset,but thats all.
  1. Press Start.
  2. Scroll to and Select Bluetooth.
  3. Scroll to and Select Bluetooth Manager.
  4. Scroll to and Select Hands-free.
  5. Press Add to configure a new Hands-free device.
  6. Press Search to search for devices. Your phone will begin to search for the device (consult your device user guide for instructions on placing your device in pairing mode).
  7. Select the device.
  8. When prompted, press Yes to pair with the device.
  9. Enter the device passkey (normally 0000).
  10. Press Done. When your phone is paired, the Bluetooth indicator will be displayed on the home screen.
Just checking to see if this is the way you connect,or tried to connect.
Apr 04, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Samsung P310 Bluetooth Activation Problem
I too had the same prob!
Here's what u have to do (the method that worked for me!) :-
*Go to Settings>Bluetooth>
*It displays options like 1. Activation, 2. My Devices etc.
Select "My Devices"
*Then select "Search for new devices"
That way it automatically turns the bluetooth on and searches for devices!! (quite odd if u ask me!)
After u have transferred ur stuff, u can deactivate it by using the "Off" option from Activation
Hope this helps u! :)
Feb 20, 2008 | Samsung SGH-P310 Cellular Phone
Powering on bluetooth function on the phone
ahh i just fixed mine, try turning your phone on and off and then trying agan
it worked for me and good luck
Jan 31, 2008 | Motorola Mobility SLVR L7 Cellular Phone
H700
Thank you for your help. I was getting very frustrated trying to pair my new Bluetooth with my Nokia 6126. I'm all set now. You're a lifesaver!!!!!
Dec 01, 2007 | Motorola Mobility H700 Wireless Headset
Samsung SGH-D820 bluetooth static problem
find somebody else with blue tooth on their phone or get a device that is blue tooth ie hands free kit then on your phone select search for bluetooth devices if it finds any then select the item you want ie a friends phone or blue tooth if it says it is active then your blue tooth is working but to use the item with bluetooth you have to select the item it should come up as a list of items select the one you want then this should pick it up and this should solve your problem if not post back and i will try again hope this is some help.........................
Nov 01, 2007 | Samsung SGH-D820 Cellular Phone
Nokia 5610 Blue Quadband 3.15MP A2DP + Gift + WTY Cellular Phone Logo
61 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
