Question about Dell E177FP LCD Monitor
Dell E177FPv, 17" TFT LCD Flat Panel Monitor will
  • 225 Answers
I think you might have the same problem I did with my E178FPb. I made a video on how I fixed it.
Posted on Jun 08, 2015
sandrew
  • 2961 Answers
SOURCE: Problem in LCD dell Monitor 17"
Check the pins in the monitor cable and the connector in the back of the pc aren't bent. Have you any way of checking the monitor on another pc or laptop to check that it's not faulty. If you have a seperate graphics card (this will be in a seperate slot away from other connections) check that it has not become unseated or push down on it gently, incase you diturbed it on connection. Do you get any beeps on start up?
Posted on Feb 19, 2007
  • 7 Answers
SOURCE: Dell 1703 FPi 17" TFT LCD Flat Panel
you have snap frame around the screen itself use flat screw driver fine edge, theres about four locations that snap into slots work them away and remove frame, then remove screws on back will seperate ,you will have to remove monitor button panel board to, once inside, four screws around screen itself once in side,this will lead you to power connection inside main screen frame, the board and the connections
Posted on Sep 07, 2007
  • 7 Answers
First there is a seprate snap frame around screen itself, there about four location on snap frame , 2 on each side ,use flat screw driver to seperate frame, there in slots like,there might be 2 on the top also,then go for screws in back, remove button panel from front side and remove flat wire connections to the board ,they pull out of slot on board , be careful putting them back in ,take your time they will go back in by pushing on the stiff part,about a 1/8 or so from the end to go in. of the connection,go for the VGA connection ,you will remve screws to seperate screen it self to get to the connection, it just pulls out of the socket on the board,hope this helps
Posted on Sep 08, 2007
tantong
  • 138 Answers
SOURCE: Dell 1704FPTt 17" TFT LCD Flat
I used to repair LCD monitor from Dell. There are 4 screws for rear panel and no screw for front frame. If there is no visible screw, you have to look for "capped" screw holes (little covers that fit flush with the case to hide the screws). If you don't see these neither, this must be a tension fit case. So, face the screen up and look for "rectangular hole" on the side edge (usually at the bottom edge of the screen). This will be a challenge to open without breaking it. You'll need a very thin flat screw driver and wedge it into that narrow rectangular hole. You can use any prybar if you don't have screw driver. It is not too deep. You may stab something important inside and pry it. Once it starts to spread, start sliding it along the seem and you should feel the tension tabs start "popping" open. Continue to work your way around until it's off. Hope this will help you to get the rear panel off. If there is anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 18, 2008
Benimur
  • 6966 Answers
SOURCE: NO POWER ON INDICATOR LIGHT AND NO Screen Raster on Monitor
Initially, pls check D854 on the Power Supply/Logic board. It is a dual diode. If you would prefer board replacement rather than component level repair, this might be of help. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
This is of course in addition to checking the usual, power cord, fuse, outlet etc.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 05, 2008
Dell 1704FPVs 17
Check you video cable ..if loose tight the screw..if still the problem presist try changing the video cable.
Sep 26, 2012 | Dell 1704FPVs 17" TFT LCD Flat Panel...
It is only a monitor?
Hi
Yes 1703FPs 17" TFT LCD Flat Panel Monitor it is only a monitor
In case I had help you pls vote me
Nov 06, 2010 | Dell 1703FPs 17" TFT LCD Flat Panel...
Dell monitor 1703FPs
you backlights are going off.y ou need to replace the power supply in this monitor very comon problem
Dec 30, 2009 | Dell 1703FPs 17" TFT LCD Flat Panel...
Dell E173FPf 17 vertical line problem
Yes, but the cost is not worth it. If you get it apart you will no doubt find a couple of bulging capacitors. Dell site has the disassembly instructions.
Oct 10, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
Dell E173FPc 17" TFT when turned on goes black
Hi Gaz,
First, verify the monitor is functional.
Monitor STFC (Self Test Feature Check)
Turn off the monitor
Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
Unplug the monitor video cable from the back of the computer
Turn on the monitor
The floating dialog box should appear on screen against a black background.
If the issue appears during the STFC, the monitor is defective. What are the results please?
Jan 22, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell E171FPb 17" TFT LCD Flat Panel Monitor Problem
The LCD and or the LCD inverted has failed. it is an unfortunate fact of life that nowdays it is cheaper to replace that monitor that to aquire parts for repair
Here is one on Ebay:
http://cgi.ebay.com/Dell-E171FPb-LCD-17-Flat-Panel-Color-Monitor_W0QQitemZ290290215133QQcmdZViewItem
You can buy a new 19 for about the same price
http://www.newegg.com/Product/Product.aspx?Item=N82E16824254009
Jan 21, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
Dell E177FP LCD Monitor Logo
758 people viewed this question
Alun Cox
