Question about Yamaha 12V Air Pump
Looking to buy used waverunners.one is 98 yamaha gp 800 93hrs. limited,the other is95 seadoo gts580cc 177hrs.what should the compression test reading be and what else should i check? mav7273@aol.com
    President:
  • 1,978 Answers
For a motor to run the compression needs to be over 110 PSI. The normal compression will be between 130 PSI and 175 PSI . What is important is that both or all three cylinders be with in 5 to 10 PSI of each other. If one cylinder has much lower compression than another it is an indication that motor work is necessary to fix the imbalance. With older boats it is always a good idea to pull the motors and replace the crankshaft end seals. Also it is not a boat if it does not float. Inspect the hull for damage, cracks , holes, bashes/bruises, these will need to be repaired. Figure out how to look into the intake grate and inspect the impeller and mated surface for nicks damage. Seadoo's have a replaceable plastic ring around the impeller ($80) that is easily torn up by rocks and debris. If the gap between the impeller and the ring is wide you will lose significant thrust. Only your own sweat equity will make a boat needing a lot of work a good deal. Happy Riding.
Posted on Jul 07, 2011
What is the size and year model of my yamaha waverunner the hull id # yama31321394
Yamaha did not make the GP model until 97 and if the numbers you posted are correct you have a 94, that being said all yamahas up until 93 were either a 500 or a 650 so im guessing its not a superjet which is a standup so you may have a waverunner 3, Raider, Blaster, or a wave runner LX. What colors are on it? does it have twin carbs? there will also be a sticker on the engine cases noting engine size.
May 29, 2014 | Yamaha Boating
2006 yamaha waverunner FXHO will not accelerate above 15mph
vx110 , are all cylinders working ?? could be plugs, injecters, or worse the valves aresticking open ! pressure drop test by dealer !! compression test also ! clean fuel ??
Jul 07, 2013 | Yamaha 2006 WaveRunner VX110 Deluxe
Yamaha waverunner does not start
hi there it sounds like the switch gear need pulling apart and the copper contacts cleaned as it sounds like the kill switch is closed up and the starter button contacts need cleaning as well also check to see if the stater soliniod might need a cleanup where the wires go,also check your fuses to see if there contacting alright if you ride in all weather or the bike sits outside it can have these problems as mouisture gets into everything. hope this helps cheers pete
Jun 12, 2013 | Yamaha 98 Gp 1200 Air Box Intake Mount...
High idle 1997 gp1200
obviously your fuelling isn't set up correctly
Jul 13, 2012 | Yamaha 98 Gp 1200 Air Box Intake Mount...
Gp 800 will crank but wont start
Hi, most likely the trigger coils near the flywheel, it will still have spark but the timing may be off. Try new plugs first as they may have spark outside the cylinders but not when under compression. Regards Phil
Jul 01, 2012 | Yamaha Boating
YAMAHA WAVERUNNER 2000 XL 800, WILL NOT RUN PAST 12 MPH
Have you done a compression test on all cylinders? My guess is you have a dead cylinder (no oil to one or more cylinders causing loss of power). If the compression test passes (all cylinders equal and higher than 100-110 psi) you have a restricted exhaust from a failed catalytic converter that has broken apart.
Apr 05, 2010 | 2003 Yamaha YZ 250
1994 Yamaha Waverunner 3 will idle but wont take throttle
1994 700 cc waverunner when it has run for 15 min engine bucks at full throttle at 3/4 ok i have changer plugs antreated fuel
Aug 01, 2009 | Yamaha 12V Air Pump
Waverunner bogs down on acceleration
Our 1996 waverunner has been running great until this weekend. It seems to bog down after 3 minutes of running at full speed. If you keep it at 3/4 speed no problem, it runs steady. Tried carb cleaner but it still runs the same....What repairs are we looking at. thanks.....
Jun 15, 2009 | Yamaha 12V Air Pump
Yamaha 12V Air Pump Logo
285 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Piyal Perera
Piyal Perera
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
