Question about Dishwashers
My GE 24 in Profile PDW8280JSS door wont open: Now the "clean" light is on. I tried cutting power for over an hour, I have run wash cycles, the lock handle will not move. The unit did not have much in it, when I last closed it, so I don't think it is jammed. Any ideas?
  • Dishwashers Master
  • 1,902 Answers
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Posted on Apr 04, 2011
Have a GE Profile PDW8280 dishwasher. My dishes are not as clean as they used to get - dishes feel gritty and food particles keep getting stuck in the middle and lower arm spay holes. Is there something...
If you have cleaned the filter sump and you are sure the kitchen side of the drain hose is ok, then I suspect there is some problem in the separation circuit between the wash and drain pumps in the dishwasher.
See this diagram.
The turbidity sensor (item 321) could be faulty. This is supposed to check wash water quality and drain it out and bring in fresh water during wash cycle. The other possibility is the flapper valve (item 328) is not working properly. This valve is supposed to separate the drain and wash sides of the dishwasher.
First thing to do is buy a dishwasher cleaning kit (Finish brand if you can) from the supermarket and run empty dishwasher with it according to instructions on the kit. Use the hottest cycle available.
If this does not affect the quality of wash, then start checking the parts I mention above.
Hope this helps.
Mar 30, 2011 | GE 24 in. Profile PDW8280JSS Built-in...
Dishwasher does not drain completely. Then when left fills with water by a slow drip and leaks onto the floor through the front door seal.
Sorry to read about your problem, I hope this helps you out.
you have a clogged pump or hose
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | GE 24 in. Profile PDW8280JSS Built-in...
After wash there is still dishwashing powder left and it is caked together
The most likely cause of this is cold water inside your dishwasher. The heating element may be burned out, but in any case you always want to run your faucet untill the water is coming out hot. Then immediately start your dishwasher. Try doing this because it will help clean your dishes even if your element is bad.
Sep 18, 2010 | GE 24 in. Profile PDW8280JSS Built-in...
Food is stuck in the bottom wand holes
I personally use a metal croquet hook to pull debris out out of mine
Jul 22, 2010 | GE 24 in. Profile PDW8280JSS Built-in...
The Normal wash cycle won't light up. Only china cycle - just bought used dishwasher.. GE Profile 5 wash cycles stainless
does the normal wash cycle work though sometimes a ligt might be gone on the control if the wash cycle doesnt work then your in for some headahces unfortunatley you would have to be able to diagnos which is the problem either the main control or the touch pad it all depends on how old the unit is ive seen both of these go you can find the part online at marcone appliance parts if you have a problem diagnosing which it is please call a technician and they will be able to tell which one is malfunctioning
Jul 13, 2010 | GE 24 in. Profile PDW8280JSS Built-in...
Not cleaning silverware and leaving film on dishes
to much detergant or not enough hot water prime sink before starting dw
Jul 01, 2010 | GE 24 in. Profile PDW8280JSS Built-in...
Wont drain
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jun 05, 2010 | GE 24 in. Profile PDW8280JSS Built-in...
Dishwasher stops running and won't drain
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
hhf
May 13, 2010 | GE 24 in. Profile PDW8280JSS Built-in...
Ge profile dishwasher electronic controls
try running an extension cord and plugging into a different outlet and see if anything changes, if it still doesn't do anything, jot down model # etc. from label, should be an 800 # to call for tech support, or an email, could be a place to start
Feb 03, 2018 | GE 24 in. Profile PDW9700JII Built-In...
Dishwashers Logo
110 people viewed this question
Top Dishwashers Experts
