Question about Sunstar Ford Focus RS WRC #14 H.Solberg/C.Menkerud 1/18 2008 Rally Monte Carlo Limited Edition 3000pcs
Need sat nav manual ford focus - Sunstar Ford Focus RS WRC #14 H.Solberg/C.Menkerud 1/18 2008 Rally Monte Carlo Limited Edition 3000pcs
How do i update my Binotone 430?
You should be able to find out how to correctly update it in the manual. You didn't specify exactly which 430 model you had, but here are the links to each of them. Hope this helps you out.
Binatone R430 Sat Nav GPS Manual
Binatone D430 Sat Nav GPS Manual
Binatone G430 Sat Nav GPS Manual
Binatone F430 Sat Nav GPS Manual
Binatone B430 Sat Nav GPS Manual
Feb 05, 2013 | GPS
Sat nav not speaking
Mercedes commans sat nav version 4.1 for E220, is saying off road, and when at home is showing on map that I am somewhere in the National Park Peak District. I have been told to remove fuse for sat nav should be no 28 but in boot of car near sat nav cassette fuses in box only go upto 20. Am I looking in the right place?
Sep 12, 2012 | 2009 Ford Focus
Inaccurate sat nav
You have a few options:-
1) Update your map and or your satnav software/firmware
2) Try and reconfigure your satellite settings
3) Factory reset
There are some good sites out there with plenty of people who have plenty more experience then me, so you could try and get onto the forums and post you question or just search them for your answer.
http://www.satpimps.com/
http://www.pocketgpsworld.com/
Hope this helps
Bobthedodge
Aug 11, 2012 | 2012 Ford Focus Titanium
Ford focus 2003 TDCI the cigarette lighter power outtlet won't power my portable sat nav or tyre inflator assume no power to the lighter ?? can you help thanks
The fuse for tis lighter assembly has probably blown. Look in the fusebox for a blown blue color fuse. Replace this for a 20 amp yellow one. If you are powering items from this plug, it will need the extra 5 amp to cope. Hope this helps
Mar 10, 2011 | 2000 Ford Focus
Hi Experts I have a ford focus with a Blaupunkt Sat Nav, similar to the second one on this link with the standard type SD card and two select controls:-...
if the unit was in uses while the sd was pulled out it could of damaged the files on the sd card. you can check the files on a pc but not run the files. the sd card has all the info for the sat nav system if it can not find or use a file it will not let you change the file. you need to do a scan on the sd card. its like a pc if you not eject the sd before removing it damages the filing system.also the web page is not accessible in my area. i would need the model number of the unit. there are software patches and map updates for all nav systems you may need to update the sd mapping software. from the manufactures web site
Jun 29, 2017 | GPS
Fuse for 1999/2000 ford focus diesel estate cigarette lighter
its fuse 46 and it should be a 15 amp according to the manual as i have the same car as you hope this helps
Feb 15, 2009 | 2000 Ford Focus
Sat Nav CD
call your deale parts department or check Ebay.
Jan 15, 2009 | 2005 Ford Focus
Missing operating instructions / manual for Honda Sat Nav system
did any of you find one? i have just bought a SECOND HAND 2004 CRV but no sat nav manual - nothing on the net- any help appreciated.
Jan 12, 2009 | 2004 Honda CR-V
Ford denso sat nav
unplug the radio from the back and plug it back in
Jun 30, 2008 | 2005 Ford Focus
Sunstar Ford Focus RS WRC #14 H.Solberg/C.Menkerud 1/18 2008 Rally Monte Carlo Limited Edition 3000pcs Logo
Top Sunstar Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Sunstar Toy Expert? Answer questions, earn points and help others
