Question about GE Dryers
My dryer, GE model DBXR463 IS SQUEAKING. hOW CAN i FIX IT?
Master_Tech
  • 770 Answers
SOURCE: My dryer is squeaking on the dryer spin cycle.
What is your model number ...sounds like the drum glides are going out or the support rollers
Posted on Jul 31, 2008
MNTECH
  • 1543 Answers
SOURCE: GE Profile Dryer Model # DPSR473EWOWW SQUEAKING
If the squeaking has been going on for only a short time, you may be able to get by with only replacing the rear drum bearing, but if it has been going on for some time you should replace the drum bearing kit part # WE25M40. Also be sure to check that the front drum slides are ok, especially the one on the left side of the front drum support, as this one wears out faster. Drum slides #
WE1M481 and
WE1M333 and if front support frame is worn so that there is nothing left to hook the slides into you would need a
WE3M26.
Posted on Sep 17, 2008
SOURCE: When dryer is on it continually makes squeaking sound
You need some lubrication inside the dryer. There are several pulleys and a belt tensioner that can be noisy if not properly lubricated. Be careful to use only an approved lubricant to avoid a possible fire hazard.
Posted on Dec 30, 2008
  • 61 Answers
SOURCE: GE Profile dryer Model # DPSQ495ET0WW squeaking
yes the part # is WE25M40
Posted on Jan 20, 2009
dragonsthatk
  • 547 Answers
SOURCE: GE profile dryer is making squeaking noise.
please replace felt around drum thank you for useing fixya RATE ME
Posted on May 17, 2009
GE dbxr463 dryer-can i turn the finish signal off or change it to chimes or tones
John,
Usually you cannot change tones. Sometimes you can turn it down, but that usually would have the volume control right there on the panel. The only other thing that I can suggest is unplugging your dryer and open up the panel and find your buzzer and unplug the wires going to the buzzer. Wrap electrical tape around each of them separately so that you do not cause any shorts when you put everything back together and plug it back in. Hope this helps!
May 12, 2015 | GE Dryers
I have a GE electric DBXR463 Model dryer and am trying to get a copy of the schematic to open it up... It makes a very loud noise... and has a burnt smell aswell... It does start...along with all other...
common problem is the rear bearing....http://www.youtube.com/watch?v=U7f8pF64008....copy and paste and watch the video,if this doesn't look like your machine,open the door and if there's two screws on the top remve them and pull off the top panel and everything else will be the same.
Apr 09, 2011 | General Electric DBXR463EG Dryer
My GE dryer DBXR463 electric dryer doesn't dry the clothes all the way anymore? What could be the problem? I have cleaned all of the lint and checked the venting on the back. It used to worked fine for...
Check the entire vent (exhaust ) system start the dryer and go outside to the exhaust vent ,you should feel a good amount of warm airflow.bet you will fine low airflow. You need good air circulation to help remove the moisture from the clothing warm or hot temps alone would take longer if ever to dry ..this generally happens slowly over time and the next thing you realize is that its running much longer than it use to... plus it cost more....if you still have a concern you may have a thermostat that is short cycling not letting it get hot enough long enough... Hope this helps GOOD LUCK
Aug 21, 2010 | GE DBXR463EBWW Electric Dryer
My dryer is squeaky. it's a GE model number DVL223EYOWW. how do I fix a squeaky dryer?
It depends on what is making the squeaking noise. Could be drum bearing, drum slides, tensioner pulley, pr even the leveling legs sometimes squeak.
Jan 10, 2010 | GE Dryers
Ge dryer squeaking when it first runs. mabye for
check your electrical panel and make sure both breakers to the dryer are in the on possition..when only 1 is on the dryer is using 110 volts instead of 220 volts
Jan 03, 2010 | GE DBSR453EBWW Electric Dryer
My Brand new GE model DBXR463 does not start. I plugged it into 110 volts AC. The manual says single phase 120/240 V and I have 25amp circuit. When start is pressed nothing is happening. Somehow, I think...
If this is brand new i assume you will have warranty..First of all try the plug fuse, next make sure the voltage setting is correct for your area, I note what you say on this!..to check a timer properly you would need a diagram and multimeter,I wish you well good luck
Oct 02, 2009 | GE DBXR463EBWW Electric Dryer
The dryer has started to make a slight squeaking noise, but it is still drying
On a GE dryer the part that squeaks most is a WE3X75. Centerpost drum bearing. It is a simple repair but you must get into the machine.On a frigidaire model The plastic bearing that mounts in the rear sorta like a GE model. No other dryers that I can recall have the squeaks. The newer GE dryers are made very simular to the old reliable frigidaire models so you ought to hit it out the ball park with these 2 links.
Jul 09, 2009 | Dryers
May 17, 2009 | GE Profile Harmony DPGT750EC Electric...
Jul 31, 2008 | Dryers
Dryers Logo
109 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
