Question about GoVideo DVR4200 DVD Player/VCR
Do I need to throw out my GoVideo because it is not digital. Comcast recently went all digital and I cannot get any response on my VCR. Channel 3's view stays consistance from the TV Channel and doesn't respond to the VCR. All the controls were tested - Nothing from the VCR ever displays on the TV. Is it because I'm not getting a signal from the Comcast box or do I need to get a DVD-VCR that is digital.
  • GoVideo Master
  • 512 Answers
Not if the unit itself still works; that is, it still plays videotapes and DVDs (with picture and sound).
Check your TV, you may have the wrong input selected for your unit (and/or other connected devices), or the TV is on the wrong channel; hence why you can't see anything from the VCR.
As for the ComCast box, give them a call and ask about it - quote the box number, and ask if it is digital or analogue - if it is the latter, they should replace the box free of charge as part of your cable subscription.
You do not need a new combo unit, unless you want one later which has a digital tuner. All it means is that you have no analogue TV channels in your combo unit.
Posted on Apr 05, 2011
SOURCE:
I have a Panasonic PV-V4525S VCR and I'm trying to program it to work with the Comcast cable. Right now it will only record the same channel that the TV is on and I have to tell the VCR to record channel...
If your using digital cable it will only record channel 3 or 4 depending on what your cable box is set to...In order for it to record different channels it needs a cable source plugged directly into it. You will only be able to record standard cable channels 1-125. If it's digital cable forget about... you can only record it with channel 3/4 a solution to this would be using a 2nd digital box.. "auto-programming" may be limited even with a 2nd cable box. If your only using standard cable 1-125... you can use the TV/VCR button it will switch between the tuner of the TV & VCR allowing you to record while you watch a different show... keep in mind this won't work for digital channels which if I'm not mistaken comcast has already converted all channels to digital even basic.
Feb 13, 2011 | Panasonic PV-V4522 VHS VCR
I recently installed a Comcast digital adapter to my SONY RDR-VX515 DVD Recorder/VCR Combo and then onto the TV. Now, when I try to program the VCR to record, the only channel options are Ch 4, Line 1 and...
Hi and welcome to FixYa
Initially, postback the model number of the Comcast digital adapter and the TV.
Offhand, if the Comcast digital adapter is connected to the Sony through a coaxial patchcord, then the Sony would really have to be set to Ch 4 (or 3). Channel selection is done on the Comcast digital adapter. It is not possible to record one channel while viewing another.
Good luck and thank you for asking FixYa
May 22, 2010 | Sony RDR-VX515 DVD Recorder/VCR
Can not record channel 160? GoVideo only goes up to channel 125??
all machines go only to channel 125 maybe you have channel 160 on cable box or sky just set vcr to channel 3 or 4 and channel 160 will come thru vcr to your tv
Dec 16, 2009 | GoVideo Go Video VR3840 DVD Recorder/VCR
Loss of VCR Channels due to Digital Switchover
Comcast is full of it.
If you have a cable box, plug the box directly into the cable feed, then place the VCR inline between the cable and the TV. Leave the VCR on Channel 3 or 4 and use the box to select the channel. You could also use the video and audio out lines from the box and run them to the VCR.
Jun 18, 2009 | Zenith VCS442 VHS VCR
Will not record digital channels
first make sure the cable is running through you vcr then make sure you vcr is set to either channel 3 or one of the inputs
May 06, 2009 | Philips MWD2206 DVD Player/VCR
VCR doesn't record since Comcast installed digital box
Try this..Run cable line into VCR in, cable from VCR out to box, then cable from box to TV..this might work...I have done this for YEARS and it is never failed. You can then watch and record 2 things at once.
Feb 12, 2009 | Proscan PSVR72 VHS VCR
Digital converter box
You need to select channel 3 or 4 on your VCR! , or line-in if you connected through the (yellow/ white/ red) cable "better video quiality!" and selct the channel you want to record on your DTV box, not the VCR!
Sep 13, 2008 | GoVideo DV2150 DVD Player/VCR
Timer recording on GoVideo VR2940
First, you need to have the cable directly input into the recorder.
If you only plug the cable box into the machine, you get what is happening now.
After splitting the cable, one side into te box and the other into the recorder, run the channel seek part of the program and it will scan all the channels available on the cable and place them in memory.
Then plug the output of the cable box into the other input on the recorder, and you get yor pay channels and upper tiers.
Your recorder is now a switching unit as well
Woody [email protected]
Nov 19, 2007 | GoVideo VR2940 DVD Recorder/VCR
GO VIDEO DV2150
you can try going from the wall to the dvd/vcr first then to the cable box then to the TV. It may find the channels but they might not be in the order you usually wouls see them i.e chan 4 may be chan 34 etc. this will only work on an analog connection, if you have digital cable box it will not work. other than that, you have to control everythng from the cable box and the dvd remains on chan 3 at all times.
Sep 25, 2007 | GoVideo DV2150 DVD VCR
GoVideo DVR4200 DVD Player/VCR Logo
167 people viewed this question
Top GoVideo Televison & Video Experts
Marvin
Marvin
Ekse
Demonic-2011
Demonic-2011
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
