Question about Saws
Startrite 301s vertical band saw wont start up at all. It was working fine today then just stopped. I have taken i apart and cleaned, changed fuse etc. I can't seem to find a manual with the electrical diagram. Any ideas?
althehun
SOURCE: Maytag CRE9500 electric range has
Hi , Jorland...
I have a CRE9500ADE and has fuses way behind the drawer under the oven,
there is a 15 amp fuse for the clock and controles the way see it.
Hope this helps...
Posted on Oct 28, 2008
rowdy45176
  • 2176 Answers
SOURCE: manual craftsman band saw
I just went to Sears.com and then to Sears Parts Direct (down at the bottom of page under Craftsman tools) and typed in your model number. You can look at this manual online. Good luck
Posted on Dec 20, 2008
  • 46 Answers
SOURCE: Fuses no. 7 & 37 on my 318is K-reg Bmw keep MELTING.
you have to figure out where there is a short in your wiring--follow wires, look for broken, missing insulation--if it started in lights, look there first maybe. Also check the connections of plugs. Good luck it may take some searching.
Posted on Mar 27, 2009
  • 22 Answers
SOURCE: Manual lever to lock self clean oven wil not lock
After sliding latch to its locking position did you press the self clean button on the control panel?
Posted on Mar 31, 2009
  • 4369 Answers
SOURCE: Need to know the fuse box diagram, what fuse
fuse panel in car on driver side by left knee under dash
Visual Inspection Chart
Mechanical Electrical
  • Wiper linkage
  • Washer nozzles
  • Washer pump hoses
  • Central junction box (CJB) Fuse 211 (15A), Fuse 215 (30A)
  • Multifunction switch
  • Rear window wiper switch
  • Wiper run/park relay
  • Wiper high/low relay
  • Windshield wiper motor
  • Windshield washer pump
  • Rear window washer pump
  • Circuitry
  • Battery junction box (BJB)
  • CJB
  • Generic electronic module (GEM)
Posted on Dec 11, 2009
Testimonial: "Thank You! I will check the fuse out and let you know."
How do I get a manual for a trade master 9 bandsaw?
MODEL: 270S INSTRUCTION MANUAL - Industrial Tool ...
www.industrialtool.com.au/.../user_manuals/trademaster/RF270S.pdf
SHUT- OFF power and clean the BAND SAW and work area before leaving the machine. (11). ... Consult the owner's manual for recommended accessories.
Trademaster bandsaw manual - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesDake parma trademaster section i ii band saw instructions parts. Dake parmatrademaster, section i ii, band saw, instructions and. Vertical bandsaws ...
Trademaster RF 270S Instruction Manual - ManualsLib
www.manualslib.com > Brands > Trademaster Manuals > Saw > RF 270S
View and Download Trademaster RF 270S instruction manual online. METAL CUTTING BAND SAW MACHINE. RF 270S Saw pdf manual download.
[PDF]Trademaster Parts Manual - Utilimaster
Jan 21, 2016 | Blade Saws
How do you lock femi 782xl Bandsaw for vertical operation
BandSaw at Trick-Tools
vansantent.trick-tools.com/tools/BandSaw
BandSaw found in: Femi NG160ABS Benchtop Semi-Auto Mitering Bandsaw, Ellis 1600 Dual Mitering Head ... ...that has a locking valve for setting up cuts. ... The HEM Saw 782XL portable bandsaw is a great fit for hobbyists and those needing an accurate portable ... JET HVBS-56M, 5 x 6 inch Horizontal/Vertical Bandsaw.
Band Saws, Horizontal & Vertical - Trick Tools
www.trick-tools.com > Sawing
Find Band saws in a variety of configurations including horizontal, vertical, ... Bandsawblades are a long lasting and low cost consumable, reducing the maintenance andoperating cost of this type of ... Femi 782XL Benchtop Mitering Bandsaw.
FEMI 782XL Swivel Head Portable Bandsaw 110 volt
www.stakesys.co.uk > Shop By Category > Metal Cutting Band Saw
The 782XL can be locked in a vertical position and, when used in conjunction with the optional table kit and quadrant, used as a vertical bandsaw for cutting ...
' The Saw That Cuts Straight
www.hemsaw.com/
Dec 16, 2015 | Saws
Saw was running fine and just stoped in middle of cut in Auto and wont start back . Checked fuses all ok.Any help on what to lookk for next?
If it had stopped cutting and won't turn on again, it sounds like the problem is with the motor of the band saw. I suggest you contact Doall or if you have vast electrical knowledge, open the motor and check yourself which part of it have failed.
May 24, 2014 | DoALL 290197 - C-305A Automatic Machine
Blade drift with Milwaukee bandsaw
Worn band saw guides maybe? Or too much tension or change the blade , I use bi metal Haltbar band saw blades of sawblade.com
Mar 26, 2014 | Milwaukee 6238 Deep Cut Portable Band Saw...
Powermatic Band saw 143, when i press the start button the saw turns on but wont stay on. When i release the start button the saw turns off. What is the problem. Please help. Thank You, Lee.
Your powermatic band saw has a Magnetic motor starter. Since it is hard to find parts for the 143 you can remove the power and take the starter apart and clean the contacts. If that fails you can take it off and take it to a Electrical Supply Store and have them match you up with one that will work.
The way the switch works is when you push the on button it picks a relay that starts the motor and also has a contact the holds the relay picked. when you push the stop button it drops the circuit.
This is a safety feature to prevent the motor from restarting after a power failure until you hit the button
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Thanks for using Fixya.
Jul 02, 2011 | Powermatic 143 14inch Band Saw...
Chain brake stops motor dead when activated.
It sounds like when you pull the rope, the chain moves. Is this true? If so, it sounds like your clutch came apart, and is lodged inside the drum assembly. One way or another, if you activate the brake, and the engine stops, the brake band clamps down on the drum, and the drum is seized to the clutch. It will have to be taken apart and verified.
Nov 21, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Unit is 3 yrs old and used weekly. Starts and
Inspect the fuel line in the tank, it should be long enough to fall to the bottom of the tank whatever the operating position. It sounds like it may not be picking up fuel in a certain position.
Nov 09, 2009 | Homelite Leaf Vac Attack
Continuous vertical white band display problem
What is the error from installing xp sp3?
Is the white band always there? it is either a problem with the lcd panel most likely, or the graphics card. try a different monitor if you have one.
Jun 21, 2009 | Dell Dimension 9100 PC Desktop
It's a startrite super 260 combernation machine i am unable to work out how to tighten the drive belts for the saw unit i have taken the machine apart but can not find any ajustmant points are you able to...
Hi Steve there is a screw above the height adjuster if you need a manual i can email you one I have a problem with mine that you may be able to help with regarding capacitor size if you could look for me let me know doggone1@hotmail.com
Jun 13, 2009 | Saws
I do not know how to change the blade on a dewalt
I'm not familiar with that particular band saw but I have had a few different band saws and they all pretty much work the same.
Unplug the saw and remove the top and bottom wheel guards.
Look behind the top wheel and you should see a large bolt standing vertically it may have a knob on it or it may not, look on the bolt to see if it has stop nuts if so loosen them then turn this knob so as to lower the wheel enough so you can remove the old blade.
Clean the rubber tires on both wheels and install the band with the teeth facing down.
Now the tricky part, adjust the top wheel so that it is firmly against the band and turn the wheel slowly by hand (be sure the saw is unplugged) if the band "walks" one way or another, you will have to find the set screw or set screws that adjust the tilt of the wheel, adjust these until the band runs true on the wheel. When it does, tighten the wheel a litte more and turn again slowly by hand repeat this until the band runs true and it is very tight on the wheel, Put the guards back on before you turn on the power. You should be good to go.
Apr 05, 2009 | Dewalt dw3988 14tpi portable band saw...
Saws Logo
120 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
