Question about RCA P52926 52" Rear Projection Television
Blue convergence Hope some can help me.. I own a RCA 52in. P52926 rear projection TV. One day my picture was perfect then the next time i turned it on it had a blue shadow on the left side of everthing in the picture screen. All other colors are great. It hasn't been moved in quite awhile. I tried to adjust the convergence thru the menu on the TV and the remote but no matter what I've tried it sets just to the right of the + in the adjustment screen and it just won't line up. Is there any other adjustments?
  • Anonymous Aug 09, 2008
    rca projection tv aftter turning it on 3 hours convergence goes out .
    Champion:
  • 230 Answers
DO you have 2 possible solutions
1.--Look under the CTR ( picture tubes) for leak coolant , all the times this set leaking, if is positive, use alcohol 90% with a bottle spray, clean the area, tied screws gasket ctr and let dry for 6 hours minimum.
2.--Loose connections on the left chassis ( convergence board), re solder ( look for possible resistor born)
Posted on Aug 13, 2008
My RCA P52960 52in. rear projection tv has what looks like a slight Fisheye lense look to it,the center being perfectly fine but all around the edges is a slightly blurry and can see all three...
We calling convergence problem.
Re solder fly back terminal ( transformer)
Replace pico fuse 400mA(little red box fuse) beside fly back.
Go to set up, convergence, select auto convergence and your TV will work perfect.
I will be here for any future question.
Thank you for visit fix ya.
Aug 04, 2011 | RCA P52960 52" Rear Projection Television
I have an RCA 52in Rear Projection TV. One day it
There is a sub-board in this set that powers the convergence circuit. Often a big Ic shorts, two diodes and finally the main fuse. not something you can fix yourself.
Nov 05, 2009 | RCA P52926 52" Rear Projection Television
Rca 52in rear projection hdtv red, blue, and green lines n double
tHIS is a convergence problem.. first question if you go into the customer setup menu. is the convergence option listed? If you have not got that option i suggest you read "the fl231 problem in the tips and trick section of this website. this can be a simple inexpensive repair..if you do have the convergence option then it can be one of three diffrent boards convergence power, convergence amp or small signal board. and will need further trouble shooting
Apr 04, 2009 | RCA Televison & Video
RCA 52in stretched picture
1) Do you have a cable box or converter box hooked up to the TV? 2) How old is the TV ? 3) Is it a rear projection TV? 4) Does this happen when watching a DVD, Game Source, VCR Tape?
Feb 23, 2009 | RCA P52926 52" Rear Projection Television
No picture, no sound
the power supply for the convergence circuit is not working, check for open resistor on the primary
Nov 24, 2008 | RCA P52926 52" Rear Projection Television
RCA 46 inch convergence problem
AM sorry, but can you provide your model number TV and chassis please?. I will tell you location parts. Thank you
Jul 14, 2008 | RCA P52926 52" Rear Projection Television
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
Dark screen and no green conv. RCA P52926 52in Rear Pro
I would first check for liquid on the board, if ok then tap on the green board see if theres a loose connection on the board
and then tap on the convergence area see if loose connection there.
Jan 20, 2008 | RCA P52926 52" Rear Projection Television
Rca guide plus gold 52 in projection tv
sounds like the blue CRT is contaminated open the back turn on the tv look into the blue gun if it looks snotty the coolent needs to be replaced
Oct 31, 2007 | RCA P52926 52" Rear Projection Television
Beeping sound when tv is pluged into wall. no picture or sound
is it beeping or cherping ,cherping it the power supply trying to run.power supply poss.faulty
Jul 29, 2007 | RCA P52926 52" Rear Projection Television
RCA P52926 52" Rear Projection Television Logo
110 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
