Question about Yamaha P-2500 Amplifier
The clip light stand still and there is no sound from that side
    Genius:
  • 1,175 Answers
If you disconnect the input on that side , does it still clip?
How far up is the input level when it clips?
Thanks
Posted on Apr 05, 2011
Side stand light stays on side stand works as it should apart from light staying on
Sounds like a faulty toggle switch, usually located just below the bulb socket under the lamp-shade. Get someone to check it out or get the supplier to replace it.
May 07, 2017 | Cars & Trucks
Recently went for a ride and everything was good. Made a stop, when I came out bike wouldnt start. turning the key everything was normal, rpm gauge spiked, lights turned on, fuel pump was heard. Went to...
Did you leave your motorcycle in gear when you turned it off? It sounds like the side stand safety switch is keeping the bike turned off. If my Suzuki is running and I pull in the clutch, with out raising the side stand, and I place the bike in gear with the side stand down, it will immediately shut off. The cycle is set up that way so you will not drive with your stand down and go out of control when you take your first left turn. If your cycle is not in neutral and your side stand is down, that would cause the condition you describe. If that is not the case start by inspecting the side stand safety switch and the clutch safety switch for proper operation.
Jun 24, 2011 | Suzuki GSX-R 750 F Motorcycles
How do i use the deluxe smoker (brand name outdoor expedition). There were no instructions
Outdoor expedition deluxe smoker. Place stand (black metal with leg on each corner) on level surface. place metho cups in the holes and add metho 1/4 cup. place the large metal dish on top with the handles provided inserted into the holes on the side in such a way that they clamp the lid down when fitted. spread about a table spoon (experiment for taste) of sawdust over bottom of metal dish. It can be dampened. Put drip tray on top of sawdust. push metal rack with side arms up into metal dish. (with food on it). clip on top rack (with food). Clip on lid, light burners and cook for around 15 minutes. Bon apetit.
Feb 12, 2011 | Sport & Outdoor - Others
Neutral light is out, bike won't stay running in n...
sounds like you need to replace the side stand switch. it's on the upper part ofyour kickstand.
May 20, 2010 | 1992 Suzuki GSX-R 600
My 650 dragstar starts fine but cuts out as soon as I engage gear. Have checked the side stand switch and it is working fine. Any ideas?
The side stand switch can work in cojunction with a clutch switch.
It still sounds like a side stand problem, check the wires and plug, use a multi meter to check the switch. If you didnt check it that way.
The switch may work but the stand is not pushing the contact far enough
Does the neutral light work correctly?
Assuming it is not clutch drag with the bike jumping and stalling when put in gear
May 13, 2010 | 1997 Yamaha XVS 650 Dragstar
I need to change the headlight but can't get the white retainer clip to pull up. Any suggestions?
hay theres a white clip in side that you pull up that will releise the light housing , its just in side above the light it stand out.
Jan 09, 2010 | 2001 Pontiac Aztek
Clip light
It sounds like one side of the power amp has shorted. May be hazardous to the speaker so best take it to a shop for repair. If speaker stills sounds OK, probably the clip detector transistors have failed.
Nov 08, 2009 | Behringer Eurolive B212A Speaker
How do I take stand off
Carefully place the TV screen side down on a
cushioned surface to protect the screen from
damage.
Remove the 4 M6 bolts by the CABLE MANAGEMENT CLIP.
After removing the stand, install the included
protection cover over the hole for the stand.
Press the PROTECTION COVER into the TV
until you hear it click.
Jul 09, 2009 | LG 42LG50 42 in. LCD HDTV
1993 bmw 1100 cutting out
sounds like there is a switch there, you should be able to see it. here is a link to free pdf service manual for your bike http://www.carlsalter.com/motorcycle-manuals.asp
Apr 04, 2009 | 1996 BMW K 1100 LT
Bike will not say anything.
I know it sounds stupid, but make sure it's out of gear, then double check that it's out of gear. I have an old bike, and I'm not sure, but the new ones have a drop switch or something incase they fall. I think it's under the seat or on the side. Also check the kick stand switch.
Mar 23, 2009 | 2007 Suzuki GSX 1300 R Hayabusa
Yamaha P-2500 Amplifier Logo
188 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
