Question about Panasonic TC-P42G15 Plasma TV
MY Panasonic tv just went blank half way but when it was on but everything went blank after about an hour of switching on
  • 760 Answers
Sounds like you have a loose ribbon connector. A bad D Board at the most. Anything else and your set would just shut off with an error code flashing at you.
Posted on Apr 04, 2011
My tv have a very typical problem it goes to blank screen but the power is on after few seconds it came back as usual ok. this problem comes down after running more than half an hour constantly.
First make sure you have the latest firmware for your tv by going to Panasonic website. Go to the support part of the site an look for any update in firmware.
Once you have the latest firmware and if the problem persist, try to look for any source of heat close to your tv and eliminate it.
If none of the above works, contact your retailer for a repair, this looks like a overheating problem.
May 07, 2011 | Panasonic PT-44LCX65 Television
My TV was working and then all of the sudden the screen went blank and now there is a flashing red light that appears. I tried to turn everything off and back on (the universal solution to everything) but...
Hello
There is something confusing the system control of your TV and it should me resetted. To reset it, just switch OFF your TV with its front panel power control switch, and after that, unplug the TV from the wall socket. Wait for about 5 minutes or so, and the plug it and switch It ON. If this does not work for the first time, give some more time to reset, say about an hour or so, and try. OK.
Jan 29, 2011 | Philips 37PFL5332D 37 in. LCD Television
PANASONIC TH-42PX60U 42 - half of screen not working
I had the same issue. I am going to replace my scan buffer boards. The upper half of mine works but the lower half is black so I would replace the lower Scan buffer board but in case of future issues I have ordered both upper and lower for $44.
The scan buffer boards are fairly simple to locate. Open up back of tv there are two biffer boards identical. The item or product code on them contain letters either SU or SD (Scan up and Scan down)Look up tv parts and item code you will find a place to order or just get the 1 800 number from tv manufacturer.
Jun 18, 2010 | Panasonic TH-42PX60U Television
Panasonic 27'' tube television
There are some components in the vertical deflection circuit area that are failing. An experienced TV service man should be able to troubleshoot and repair this for you. It could take several hours of labour cost.
Jerry G.
Apr 26, 2009 | Panasonic CT-36D12D 36" TV
While watching TV screen went blank. Voice stayed on
the photon charges at the back of the tv might be damaged, try to take it in to be repaired if not i suggest u buy a new one, please, please, please do not take it apart to fix it urself, alot of bad burns have happened to people who try to fix plasma tv's.
Apr 12, 2009 | Akai 50 in. Plasma TV
Panasonic Problem
replace the fuse of the tv device (in the primary main power section),or contact the nearest repair shop.
Jul 18, 2008 | Televison & Video
TV blank, sound okay, picture comes for half a second while switching channels
i am a technician and i too have this issue. if any of you can get a schematic and service notes, send them to trae3@live .com and i WILL find the problem and report to each of you. i cant get any help from sears all i need is to speak with a technician who actually works on these things, get the paperwork and then i am sure it is a matter of a module swap. any info will help us!
Jun 23, 2008 | Protron PLTV-26 26 in. HD-Ready LCD...
Panasonic pt-52lcx65 picture problem
Have a sears technician come over ,call them and set up an appointment, they are the best techs out there for tv issues, they will come out even if you did not buy the tv from them. Most of the Sears tv techs come from Philips which closed down their tech shop a while back. It sounds like you have dirty or faulty fans on your board. please advice.
Sep 10, 2007 | Panasonic PT-52LCX65 44" HDTV
Picture problem, half screen blank
On a plasma there are 2 buffer boards, upper and lower, it all depends which half of the screen is on as to which buffer to replace, the buffer boards are located usually on the left hand side if you have the back off the unit. You maybe able to reseat the ribbon cables and get the video back up
Feb 17, 2007 | Panasonic TH-42PX500U 42 in. Plasma...
Panasonic TC-P42G15 Plasma TV Logo
93 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
