Question about Nikon N50 35mm SLR Camera
I bought an older 28mm nikon lens for my d60. when i try to rotate the apertrure ring, the d60 screen says that the aperture must be set to the highest setting. am i stuck with this aperture setting? or will it adjust by the d60? thank you for your help
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Set the aperture to its smallest opening (largest f/number) and lock it. You can control the aperture from the camera, the same way you do it on a lens without an aperture ring.
Posted on Apr 04, 2011
Where is the aperture ring on d80 Nikon
If you are using an older lens the aperture ring will be close to the camera body when the lens is on the camera. In order to set the aperture with a D80 and older lens you must set the aperture ring to "22" or the highest number on the aperture ring available. For newer lenses there is no aperture ring. You set the aperture by setting the dial on the top left of the D80 to "A" for Aperture Priority. You then set the aperture by rotating the front dial on the right side of the camera under the shutter release button. On older lenses, after setting the aperture ring to the highest number, you then set the aperture in the same manner.
Sep 22, 2014 | Nikon D80 Digital Camera with 18-135mm...
I have a tamron 28-200mm lens that have a aperture ring at the back .. so is it possible to lock the aperture at f3.8 and shoot at 200mm focal ?? (this lens was f3.8- f5.6) by the way i was using a n
If you're using a Nikon camera, you want to lock the aperture ring at its smallest setting (largest f/number). You can control the aperture from the camera body, the same way as on a lens without an aperture ring.
This has nothing to do with the focal length. You can shoot at any focal length from 28mm to 200mm.
Feb 10, 2014 | Cameras
Error message
Turn the aperture ring on the lens to its smallest setting (largest f/number). You can control the aperture from the camera body, the same way as with a lens without an aperture ring.
The aperture ring is the one with a bunch of numbers on it such as 2.8, 4, 5.6, 8, 11, 16, and 22.
Jan 16, 2014 | Nikon D60 Digital Camera
How can I use the aperture ring instead of set it to minimum in order to use the ring not the dial. I am trying to operate this way with an AF lens (not af-s) and my d5100.
Set the aperture ring to its minimum setting (largest f/number) and leave it there. You control the aperture from the camera body, exactly the same way as on a lens without an aperture ring. In the A mode, simply turn the command dial. In the M mode, hold down the aperture (exposure compensation) button and turn the command dial.
Apr 06, 2012 | Nikon Cameras
Hi, I have a Nikon D60. Somehow I locked aperture at highest number. Even with Manual setting, it does not let me change aperture! Please help
The lens is supposed to be locked at its smallest setting (largest f/number). You can control the aperture from the camera body, the same was as on a lens without an aperture ring. For example, in aperture priority mode (A), simply turn the command dial. In manual mode (M), hold down the exposure compensation button while turning the command dial.
That was for a lens with the electronics to communicate with the camera. If you have a purely mechanical lens, you must shoot in manual mode and control the aperture by turning the ring on the lens. There should be a small orange slide near the aperture ring, Slide it toward the front of the lens to unlock the ring.
If you need more help, please feel free to reply to this post. Please specify the lens when you do.
Aug 13, 2011 | Nikon D60 Digital Camera
Message: Lock lens aperture ring at minimum aperture (largest f-number) I think I'm doing this but the message won't go away and the camera won't work.
You must lock the aperture ring to f/22, so the camera can engage the aperture adjustment lever on the lens. Then, you can change the aperture with the command wheel.
When you change the aperture with the command wheel the aperture ring on the lens doesn't move when the camera actually adjusts the lens aperture.
Take the lens off and locate the aperture adjustment lever on the lens mount.
Unfortunately, this won't work with older AF lenses. So if you are using an older lens, the only thing you can do is change the camera setting to M (Manual) to adjust the aperture on the lens yourself.
May 16, 2011 | Nikon D60 Digital Camera
I have just bought a 60mm micro lens. when i put the lens on my Nikon D50 the message FE3 appears on the screen. i have tried taking of the lense and putting it back on but the message still appears.
I hope you mean FEE.
Turn the aperture ring on the lens to its smallest setting (largest f/number). If the ring has a lock, lock it in place. You control the aperture from the camera body, just as you would on a lens with no aperture ring.
Dec 08, 2010 | Nikon Cameras
I have a Nikon D60 and have just bought a 50mm AF 1.8 D lens but find I can only use the aperture setting at 22. Is that right ?? why can't I use the other aperture settings ??
The D60 camera sets and triggers the aperture that you have selected (or the camera has selected if in auto mode) and sets the aperture as you take the picture. Moving the aperture ring on the lens will not work, in fact once you move it from the f22 position the camera will stop or possible show and error. on my older Nikon AF lenses there is a small lock to lock the aperture ring in the lowest position when mounted on a digital camera, it is found near the f2.8 side of the aperture ring. when you want to set the apertures manually, you put the camera in aperture or manual mode and set the aperture you want by moving the the rotating wheel on the grip part of the camera. the aperture you select will show in the window, you do not have to move the ring on the lens,it must remain the f22(highest numerical) position.
Oct 24, 2010 | Nikon Normal AF Nikkor 50mm f/1.8D...
The 300mm lens would not work when attached to the
Which 300mm lens? Does it have an aperture ring? If so, you'll have to turn it tothe smallest aperture (largest f/number) and lock it if it also has a lock. You control the aperture the same way you do so on any other lens, by turning the command dial (possibly in conjunction with holding the aperture button).
May 11, 2010 | Nikon D60 Digital Camera
Nikon 50mm 1.8 lens error message
The 50mm lens is fairly old and uses a different system to the later lenses. On the D90 and other later cameras you should rotate the ring to 22 and lock it there using the lock just above the aperture ring.
To adjust the aperture you use the front dial by the on/of switch.
Try it out in A mode. Rotate the mode dial on the top left of the camera to A (Aperture Priority mode) then lightly press the shutter button to turn the meter on. Then rotate the front dial and you will see the aperture reading changing.
The older Nikons changed their apertures using the ring but the later Nikons use the camera controls.
Jun 25, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Nikon N50 35mm SLR Camera Logo
104 people viewed this question
Top Nikon Photography Experts
Ric Donato
Bart Pulverman
Are you a Nikon Photography Expert? Answer questions, earn points and help others
