This 10 year old trouble free washer just stopped responding recently. Acts like there is no power getting to it whatsoever, but the power outlet is good. The washer was submerged in about 6 inches of water during a flood 6 years ago but never required any service or had any issues from that occurence other than some apparent bearing squeak. Not sure how to diagnose electronic issues.
  • 2 more comments
  • davidmickelb Apr 05, 2011
    Sorry, thought the model info was included from my original search for issues with this model. It is a Kenmore model 417.40042990 front loading washer. They sold a million of these and it's been extremely reliable and effective. Would like to hold onto it as it seems good for another 10 years or more. It has the service manual attached inside the machine if that might help. I don't know where the fuses are. I've opened up the front and back panels and there is an apparent control module in the lower left corner looking from the rear. All wires seem to be connected and in good condition. Will await your advice. Thanks!
  • davidmickelb Apr 07, 2011
    Hi again. I got the fuse out and it appears to be rated "250V 25A T" according to a stamp on the circuit board where it was mounted. It is a white ceramic cylinder about an inch long. I called a local appliance parts distributor and they said no such part is listed for my model. I found the same online. I looked online for a fuze with those ratings and found lots of similar matches but they all include a lot of extra details about style, fitment, and additional ratings that I don't understand. So, I don't know which one to order. Any idea whether this would be a "slow" trigger fuse or a regular trigger? I called that RepairClinic.com place and they said there was no fuse on this model. They were not very helpful. Any other suggestions on how to locate the proper replacement fuse? Thanks.
  • davidmickelb Apr 08, 2011
    I'm not sure why this fuse would not be servicable. It is not soldered to the board. It simply clips in and out like any other fuse. I've already pulled it out. I found sources online that sell an assortment of replacement fuses that look exactly like mine. The only issue I'm having is identifying the exact specifications of my fuse. I know it is a "250V 25A T" ceramic fuse and I've learned that the T stands for "slow blow". I'm not sure if different fuses with this rating have other differences, like ohms. Do you have any idea? I don't want to get the wrong fuse and do damage to my board. Not sure if that is a risk or not. I suppose I need to get a decent quality multi-tester and try to figure it out.
  • davidmickelb Apr 13, 2011
    Thanks for the confirmation on the fuse configuration. I installed a new replacement fuse and there was no change. Still no evidence of power reaching the motor. I get no response on any cycle setting on the main dial. As I mentioned before no part of the machine has given trouble in the past or shown evidence of impending failure. Any more do it yourself suggestions for me? Do any suppliers offer a return policy on something like a new speed control panel if I wanted to try one?
  • Washing Mach... Master
  • 2,605 Answers
Welcome to FixYa.
Can you provide the make and model number of the washer you're inquiring about. Some washers have fuses, and some don't...there are too many possible scenarios to generalize about your machine.
I'll watch for your reply post.
Regards,
Macmarkus :)
Posted on Apr 04, 2011
  • 2 more comments
  • Mark MacDonald
    Mark MacDonald Apr 05, 2011
    Hello again David,
    Thank you for the reply and providing the model number. That is indeed a very popular model of washer and yes Sears sold millions with the Kenmore badge on them, as did Frigidaire, Gibson, GE, White Westinghouse and more.
    To address the issue of fuses, this machine actually only has one fuse and it is located on the control board you referred to on the lower left (from back). you will need to remove the control and check that fuse if you can. The control is held to the washer cabinet base via one screw and a slot at the front, it will simply slide back and out when the screw is removed.
    **First unplug the unit from the wall before performing any service...safety first**
    This is the control I'm referring to just to be sure...#134149220
    If you look closely at the metal casing the control is fastened to, you'll see it is held in place by a couple of screws. Remove these to pull the control out to inspect the board thoroughly (particularly the fuse)...you will need an ohm meter to check continuity of the fuse.
    If the fuse is indeed blown, you'll need to either find a replacement fuse and solder it in place ( I do not know of a place which makes them available, I presume an electronics supply house or the like perhaps...but you'll need the amp and voltage rating of the one in place, I don't recall off hand ) or replace the control which is available at most brick & mortar part stores or on-line at places such as "searpartsdirect.com" "repairclinic.com" for approx. $150 to name a couple.
    Let me know what you find and we'll move forward from there if necessary. Good luck.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Mark MacDonald Apr 08, 2011
    Hello again,
    Sorry I haven't been available for a while. The fuse you are inquiring about is not a serviceable part as I alluded to in my post.
    "If the fuse is indeed blown, you'll need to either find a replacement fuse and solder it in place ( I do not know of a place which makes them available, I presume an electronics supply house or the like perhaps...but you'll need the amp and voltage rating of the one in place, I don't recall off hand ) or replace the control which is available at most brick & mortar part stores or on-line at places such as "searpartsdirect.com" "repairclinic.com" for approx. $150 to name a couple."
    So no, you likely won't get it through typical appliance part sources, I was suggesting you may be able to match the fuse at electronics supply place if you're a "do-it-yourselfer"...but aside from that you'll need the entire control as I mentioned.
    I've been dealing with a very intermittent internet connection this past 24hours or so, again my apologies for the delay in my reply.
    good luck.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Hey David,
    Sorry for the cofusion. There have been several revisions of this style of control board on these washers...many where sodlered into place.
    If yours is indeed a "snp fit" and you knosw the rating there is no reason you can't simply install an exact replacement of 250Vac-25A slow blow fuse. ( the resistance value is built into the 25A rating...the amount of resistance won't matter. If the meter is set to 1X ohm reading, it should simply be open/infinite or closed/0 ohms...no resistance = obviously "closed" )
    The only thing I'll caution you on is if the old fuse was blown, the new one may simply blow immediately as well indicating there is indeed an issue on the board...but the fuse is certainly an inexpensive alternative to try and resolve the problem.
    Let me know how you make out again and good luck.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Mark MacDonald Apr 14, 2011
    Hi David,
    It's been a long day so I wasn't able to reply earlier. In any event, I'd be curious to know if the fuse you put in the control is now blown as well. Have you checked ?
    The issue as I alluded to can be on-board the control itself and therefore cause any replacement fuse to blow as well.
    It couldn't possibly be the motor or you'd still have some indication of power through a water fill valve, door lock, drain pump or something.
    Does your washer have any tech sheet or diagnostic literature in an envelope pasted to the side panels inside the cabinet ? That is typically where they are located. I'd suspect it is the control board, but I just hesitate to say without the info regarding the original fuse ( I think you said it was blown, right ?) and the replacement fuse.
    I'll watch for your post and try to reply asap to try and resolve this issue finally.
    Regards,
    Macmarkus :)
Whirlpool dishwasher DU1015XTXBO Stopped working during cycle, acts like don't getting any power. Checked the plugin and it works. No lights or anything coming on the dishwasher. Its like it just
You may have power, however if a circuit board fails, all the power in the world won't start the washer. You need a technician to test the circuit for internal damage.
Feb 17, 2018 | Whirlpool Dishwashers
My washer just stopped during the wash cycle and responds to nothing ! I checked power (at the wall outlet) and also the lid switch (it makes the clicking sound but does nothing). Any idea on what to even...
Might be a bad capacitor. Do you hear a hum? Dead in the water? I recently worked on one where the capacitor simply fell apart. I had a couple of old ones laying around and put one on there and she came to life. You can't hear the timer? That is a sure sign the molex block could have backed out with vibration I have seen that. Got a model number? You might get a better answer.
Get a free service manual HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 13, 2010 | Whirlpool Washing Machines
Maytag Neptune. 10 years old.Slow drum rotation
The problem may be with the bearing of the washing machine is spoiled due to leak please try to change two inner bearing along with the washer it will work for another ten years
Dec 24, 2009 | Washing Machines
Gary asks kenmore model 110.96583120 runs for 10
.I am not a repair professional. I am a 78 year old man
who has been making his own repairs for about 50 years. So the washer or dryer ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and found that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video which showed me how to take my machine apart. This video made it possible for me to do my own repair. If you are repairing a dryer or a front load washer I suggest you go to www.applianceaid.com where they have very good step by step trouble shooting and repair information on both washers and dryers as well as other appliances. If you have a direct drive top load washer and need help taking it apart this video is an early christmas present. I was so impressed with it that when I saw all these people needing help, I wanted to tell them about it. If you look at the back of your washer and the panel is solid (no small inspection plate to remove which would indicate you have a v-belt drive) chances are you have a direct drive and this video is just what you need. You can see it at www.acmehowto.com You will probably still need help in determining what the trouble is and how to fix it. After viewing the video or if you have a v-belt drive rather than a direct drive, I suggest you go to www.applianceaid.com where they have very good
trouble shooting and repair nformation on most
washers and dryers. I think you'll find what you need
there. Don't worry about the timer, they hardly ever
go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Dec 02, 2009 | Kenmore 63942 Dryer
Whirlpool Washer #WFW8300SW01 will not operate.
There's a couple of reasons for the F-01, most common is a bad relay on the main control board. (CCU)
This washer will also flash that code if:
1: Either the back or front access panels are removed while operating, there are ground safety switches that are held closed by the panels.
2: If the power supply outlet is supplying much less than 120V (usually would need to be 112V or less to cause it)
3: If the polarity is incorrect (hot and neutral reversed) at the outlet
4: If there is an open ground at the outlet.
The easiest way to check 3&4 is with a simple plug in outlet tester. I have seen all of these problems throw an F-01, but I would still say 9 out of 10 times you have no option but replacing the CCU. Make sure to double check your manual about the warranty info, as some electronic controls are often covered beyond the 1yr standard warranty. If you're going to replace it yourself, it is accessed by removing the top panel, and is located towards the front, right side of the cabinet, and has a zillion wire harnesses plugged into it. When replacing the board, note that there may be some harness connections available on the board that are not used, mark them as such. Hope this helps.
Nov 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
No response from washer - what should I do?
there is a fuse located at the top console of washer. replace fuse and you should have it running again.
May 21, 2009 | Washing Machines
Lid locked
Sounds like a falled board in the machine itself. At 8 months old, is your warranty still in effect? If so, may want to call the Searsman. Good Luck!!! Jim
Sep 03, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
