Question about Hitachi 60SBX72B 60" Rear Projection Television
I have an Hitachi Projection TV Model #60SBX72B purchased new in Nov 1997. This has been an amazingly dependable set....moves to 6 different homes and not one service technician call has ever been needed. Recently, we have been seeing horizontal static lines across the middle of the screen....randomly and frequently, but not contstant. It happens on all stations. We are also seeing a red and blue blurred rainbow effect in the upper left corner of the screen. Additionally, there are times when the picture seems slightly warped or over-sized for the screen. We have Comcast cable service with a DVR player attached (also another unit - a DVD/VHS player is attached). We had done nothing to change the connections or move the set that might have triggered the problems noted above. Suggestions please? We were hoping to get some more mileage out of this workhorse of a TV before we have to chuck it and buy the newer technology. The picture (until these problems started) was always amazingly clear. Suggestions please?
  • dspottenger Apr 04, 2011
    I'd like another Expert's opinion....
    as stated, although we've moved this set to 6 different homes....it has not been moved in the last 4 years and no connections or components have been changed.
  • dspottenger Apr 07, 2011
    Thanks for the information you provided through fixya.
    A repair tech looked at my Hitachi Projection TV today. Diagnosis....mother board is fried and they don't make them anymore.
    Other parts could be replaced, but the cost of fixing it still would not solve the bigger problem of a fried mother board that could stop working at any time.
    $90 for tech diagnosis.
    Time to search for a new t.v.
    What is best? LED?
    Which brand is best?
  • Hitachi Master
  • 12,061 Answers
Http://s100-manuals.com/search.asp?q=60sbx72b
service and repair manual at above link.
"moves to 6 different homes and not one service technician call has ever been needed" (sic)
well it maybe now that it may make up for it.... :(
This could be your color engine, it may also be your color wheel? even a PSU problem, however unfortunately these symptoms you describe, are symptomatic of many many many faults. This realistically precludes diagnosis via, a forum, and one really must examine a set before a determination could be made, well unless a "Clear Cut" fault was exhibited, this one is not. These units never had any "Weaknesses" so to speak, and were/are a reliable set, though very out dated now. Once they start to fault, it is the "Thin end of the wedge" so to speak, and repaired units will usually fail again with 12 - 18 months. (According to statistics)
With this symptom, it is impossible to tell what the exact "Cause" of this symptom is. The LED's do not tell us what is wrong, sometimes it may indicate the "Area" in your case it is the X board. BUT thats NOT where the "Fault is" thats just the part that is affected. T What is happening is that you have a fault in the set, that is potentially very bad, and the Power Supply senses this and attempts to shut it down, now when it shuts down, the fault clears momentarily, and so the PSU, again tries to power up, sense the fault and tries to shut down again, we call this a Hic-upping Power Supply, and is often the symptom of a much larger underling problem. These days unlike the "Old" analogue days it just isn't realistically possible to fix anything but the most basic of problems with todays sophisticated units. This is quite apart from the Safety aspect, any unit that can cause a firs or have an explosion, or both, is NOT to be treated lightly, and and the repairer, of the unit is legally responsible, another thing to think about. Also, one must have tools, a Multimeter, a soldering iron, a deslodering iron, an oscilloscope, a signal tracer, tools, and most important of all, a Service Manual, without which, there is no way to even begin to understand and fix it, and more importantly Program it, AFTER it has been fixed. As these days a TV, is a PC, a Tuner, and an HDTV Monitor, and more, all in one. in the "old" days TV"s were more, rudimentary, and built to last for 20 years, and a "Parts" supply was set aside. They usually used to fail for only a few reasons, and they while still difficult, were less difficult to repair. Electrical knowledge was transferable, and they could be and would respond to, This-is-the-symptom-This-us-the-Fix, But that no longer applies, as now, it can be a Fault on I squared Bus, or "Sensor" failure, or it simple may have "Crashed" just like a PC, It could be a Diode go bad, and that will stop the whole thing. You see, in the day, the sets were Very "Fault Tolerant" because they were Analouge, and a faulty, component, or more sometimes, the set would always diplay something usually, and when they didn't it was one of only a few things, sure there are always the horrid ones, and there are pleanty of those, but all in all it was quite easy. But with Digital Electronics, it either goes, or it doesnt, there are usualy few half measures. I mean thats the definition of logic either going or not. So it can take very little to completely paralyse a set, and generally give the only sysmptom, it can, by not working, usually No picture, or the like. So you, see the list is endless almost for any given SYMPTOM, as that is what is being seen, not the cause, as I keep going on about. Also any fault, usually involves the Power Supply, it is either the cause, the cause of the damage, or it is damaged. or ALL of them. Then after you have done the electronic repairs, you then must program the set to work, and align, and set up in general, any one of those settings missed or done wrong, back to square one. So, it is nearly always my professional opinion that one should always get a "Quote" form the manufacturers recommended service center, I cannot stress how important that last point is. It is even worth the cost of shipping. you see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace. Often my clients,do not go through with repair, unless it is moderate, but in some of the more costly jobs they see it, as do i, that a replacement, with a warranty, is a better option. As an aside here, one could then tear the TV down, and sell the Known Good bits. You'd be surprised who needs parts, i myself often must by from third party sources to effect a repair. So money could be recouped, somewhat,and help out someone else
Posted on Apr 04, 2011
    President:
  • 1,768 Answers
1. the moving could have thrown the color guns out of sync.> your TV unit will need service .
2. the horizontal out put circuit and or the vertical sync circuit may need to be serviced.
3. Your TV may need a TV technician to look at it to determined the fix.
Checking the main board with schematic and Oscilloscope for possible fail components is what will be needed to fully resolve your issue.
Reset button om the 60SBX72B WHERE IS IT?
Does not have one, follow the cord inside the set to see if main fuse is good or not.
Dec 23, 2012 | Hitachi 60SBX72B 60" Rear Projection...
TV power up,then power off.
Its a common problem on this model and many other Hitachi's. Its a bad capacitor and pico fuse. You can get parts and instructions for the repair from www.TvRepairKits.com. Its a failry simple fix if you have proper instrcutions.
Dec 03, 2010 | Hitachi 60SBX72B 60" Rear Projection...
Can the convergence on a Hitachi rear projection tv be set with a remote other than the original?
No, but almost any Hitachi remote for their projection sets will work--different Hitachi remotes use different buttons in the DECAM or advanced convergence adjust mode.
Tell me the model number and I am fairly sure I can tell you the part number of the correct remote. These remotes can be purchased new or used on Ebay at fairly low prices 15-30 dollars.
Let me know if you have questions and if this information helped you rate this solution as I do this here for free.
Also, if you have any questions about your Hitachi confirm the actual model number and I will help you.
I am an expert on this brand and own two of their projection sets myself.
SD TECH
Dec 09, 2009 | Hitachi 50UX57B 50" Rear Projection...
I have a hitachi 60sbx72b tv doesn't display anything
Tries unplug for awhile replug see if it reset itself?Don't work or only for awhile happen again.The main video board must changed.
Jul 11, 2009 | Hitachi 65SWX20B 65" Rear Projection...
60.5 inch ultravision rear projection tv - circa 1999-2000
If you provide model number I can suggest correct remote control to buy.
Oct 13, 2008 | Hitachi Televison & Video
Will not turn on
Yes this would have damaged the tv IC"s and power unit of the tv you need get it serviced ...............
Jun 14, 2008 | Hitachi 60SBX72B 60" Rear Projection...
Moving the TV
you should be fine as long as you don't drop it of course. you and turn and twist it any which way but id say measure the height of the tv because at some point you will have the top and bottom of the tv touching 2 different walls if im not mistaken
Feb 13, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Televison & Video Logo
120 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
