Question about Audiovox FP1520 15 in. LCD Television
SCEEN PROBLEMS MY AUDIOVOX FP1520 HAS 5 VERTICLE LINES ON IT. IT HAPPENED AFTER I CLEANED THE SCREEN
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
U have to chage ur screen .ur panel driver is loosignal signal
Posted on Oct 19, 2008
  • olayoju victor Oct 19, 2008
    perhaps u put too much pressure when ua cleaning the screen
SOURCE:
Samsung Plasma HP4252 type SR42P5 verticle blue lines across entire screen
First off there isn't a timing board in a plasma TV. I would guess you have a bad y-sus board.
Feb 20, 2018 | Samsung HP-R4252 42 in. Plasma HDTV
Horizontal white lines 27A43.
You have some bad capacitors. They are located very near and next to your vertical IC. I would guess you would have to replace maybe four of these! Thanks for asking!
Jun 12, 2010 | Toshiba 27A43 27" TV
I have two verticle lines- one white and other one
The screen will likly need to be replaced. Try an external monitor on it, does it still have lines? if not then its the screen on laptop.
Feb 25, 2010 | HP Pavilion zd8000 Notebook
My hp pavillion dv90000 has gray verticle lines and it makes the screen behind really hard to see. What can I do?
In most cases with these lcds...when you see verticle lines and white outs, the most likely cause for this is a screen failure. Your lcd panel is failing and will fail, they are not servicable. First though check the data cable on the left side of the panel, it is secured in the back of the panel and it has been known to come loose from the socket annd this will cause visual problems of many different levels, but that is about it other than changing the screen out. These screen are relatively easy to change out and can be bought on Ebay for as low as 50 bucks.
Jan 06, 2010 | HP Pavilion dv9000z Notebook
Verticle lines on the screen
Failing Display Panel Circuit Board... THis Means You Will Need A Screen Replacement..
Nov 17, 2009 | Toshiba Satellite A105 Notebook
Verticle lines across my dell lap top
Put your screen saver to black..let the screen saver come on if lines are there you need a new lcd.....if lines are not there uninstalll all graphics drivers reboot your laptop and reinstall this will fix it if not your lcd screen is on its way out.....NEVER CLOSE YOUR LAPTOP AND STAND ON IT THAT IS JUST SILLY THINK ABOUT IT PEOPLE I MEAN COME ON HOW STUPID CAN YOU GET YES PUTTING PRESSURE ON THE LCD WILL REMOVE THE LINES FOR A WHILE BUT THEY WILL COME BACK.
Aug 22, 2009 | Compaq Presario M2000 Notebook
Verticle black lines on mitsubishi dlp tv screen
Press the Menu Key on your remote. If your menu shows clearly on the screen, then there is a problem with your source.
Mar 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Recorded images has verticle lines
No, most camcorders doesn’t work when you recording the image directly on the screen, that means you use your camcorder shot directly to the screen. Maybe the frequency is different, I have tried used RC plugs directly connect to the VCR and recorded, it is much clear.
Jun 15, 2008 | JVC GR-D22U Camcorder
Audiovox FP1520 15 in. LCD Television Logo
73 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Ekse
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
