Have a contractor with a AWS18THX & AOS181HX In his own house & 1 year after installed the contractor is shut down. He is showing a code F1 (communications?) How can I get a manual for this? Thanks Mark
  • mharvey124 Apr 04, 2011
    The brand is a Amcoraire?
    Thanks
    Problem Solver:
  • 5 Answers
Mark,
Your problem lies with the communication wire from the outdoor unit to indoor unit ("S" terminal). Make sure the connections are tight and all plugs at the outdoor unit are plugged in. Also the communication wire should be 14 awg. If it too small, errors could result. Worse case send the Aquaman there.
Posted on Apr 05, 2011
Testimonial: "Thanks for the help Aqua man!! Problem solved!!!!!"
    Brigadier General:
  • 4,736 Answers
Mark, reread your post. To help you, we need to know who the Manufacturer is. The Model Number alone doesn't help much.
Posted on Apr 04, 2011
  • Rich Landrum Apr 04, 2011
    Mark, I have searched my date files of Amcor Air Conditioners and there's not a model number even close to yours. I'm sorry, but I can't find anything on those models. You may want to repost your question (include the manufacturer this time) and perhaps, one of the other experts can help you. Sorry I couldn't do more for you.
03gmc envoy showing code p1514 and reduced power light on engine shuts down
Type: OBD & your codes
OBD PO 440
OBD PO128
Codes have nothing to do with installing parts
Codes are System Faults only
Codes are used to diagnose a system & component
test to find a problem
Sep 26, 2014 | 2003 GMC Envoy
Rheem RTG-66DVN shuts off 1-2 times a day
You received recommended answer posted ago.
Probably same answer today:
Don't install tankless, especially in location where there is no service technician available unless you expect to heat water by setting tankless out in sun.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Repair any brand tankless, any error code or problem, same day, yourself for $385:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Add comment and give link to service manual that you located.
Apr 05, 2013 | Rheem RTG-66DVN Natural Gas Tankless Water...
I have an LG Dishwasher model LDF9810ST. Error code E1 keeps showing (Water Leakage Problem) NO water problems anywhere to be found. I have a hard time shutting down the machine. It has had a new MAIN...
Are you draining the unit in the basement or under the kitchen sink?
If you are draining the unit to the floor you will need a new drain hose with a syphon breaker. This drain hose is factory installed on all new LG dishwashers.
The part # is AEM69493801
This is a known issue and may be covered under your factory warranty.
Depending on where you live a factory service tech may be in your area.
Could you explain the second problem further...Hard time shutting down?
Shoot me a E-mail @ omaharox@msn.com.
I am a LG factory service technician not a sub contractor.
Mike
Jan 08, 2010 | LG LDF9810ST Built-in Dishwasher
The on off button presses down but not up and the a irflow does not go on. It is less than a year old and the construction men purchased it at Home Depot. Since they left no papers with me, is there any...
This tub should certainly still be under warranty if it is less than a year old. With my business, I offer a one year warranty that is standard with all of my installs. You may want to try your contractor first to see if he/she offers a warranty. If your contractor did not offer you a warranty, you may call American Standard @ 1-800-442-1902 mon-fri. from 8 am-6pm EST. If you have to go through them, the part should be under warranty, but you will be on your own for the labor portion. I would still check with my contractor first. I do not know any contractor that does not offer a one year warranty. Unless this was just a handyman and not a professional contractor.
Nov 20, 2009 | American Standard Home
I have a fisher paykel dishdrawer dishwasher that i get a F1 error code then it shuts down i have dried up the bottom tray but it will only work for about 1 week and it does it again
Perhaps you need to find out the source of the problem. The F1 code is due to the flood switch at the base of the housing getting triggered by water collecting. You could have a cracked hose or broken actuator arm (this is piece of plastic at the back of the drawer that holds the wires and hoses) Moisture can get to the flood switch if foaming occurs due to incorrect detergent powder being used.
Good luck
Nov 10, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
I get an "F1" code on my Maytag range.
you need a new temperature probe. its usually located in the upper left hand corner in the rear of the oven.
Mar 19, 2009 | Maytag MES5570 Electric Kitchen Range
Poorly installed roof
You should call an ingenior to come and take a look at your roof , it will cost you a bit of money , but if he can state that your roof need to be redone again you should easily get a clean case in court
Nov 23, 2008 | Roofing
F1 service code
The owner's manaual states that F1 means Control Malfunction.
The manual recommends the following:
Press Oven cancel pad or disconnecting power supply may eliminate F code. If failure continues contact an authorised dealer.
Aug 02, 2008 | Amana ACF3325AS Dual Fuel (Electric and...
F1-1 error on Jenn-Air Range
if it is the stove that is in the picture the fault codes are in the door under the oven door.
Jun 01, 2007 | Jenn-Air JGS8750 Gas Kitchen Range
Heating & Cooling Logo
118 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
