Question about Symbol LS 4278 Barcode Scanner
I have a new LS4278 with the STB4278 cradle using a KBW. I downloaded the easy setup and scanned the "default" then paired it then the "IBM PC/AT". When i scan something, it beeps like it scanned, then i get three tones and a red light on the cradle. and of course nothing in word pad. Help ;-)
  • 2 more comments
  • bigmacdave Apr 05, 2011
    Ok,
    i let it charge fully. (only have one) the green light it solid.
    When i scan something, it beeps once like it scanned, and then i get 4 beeps all the same tone and the green light on the cradle turns red. then about a second the light on the cradle turns back to green.
    no. i didn't install any software. I just followed the setup instructions from the Quick start.
    It has three things to scan and then says i can use notepad to make sure its working.
    1) default
    2) the pair tag
    3) IBM PC/AT keyboard
    then it says, use notepad to make sure its working
    ok, software installed. no difference
    Things i know: the scanner is talking to the cradle because if i scan the "default" it unpairs it and if scan something, the scanner beeps in many tones and the cradle does nothing. When i pair it back, and i scan, then i get the scanner making 4 tones the same time the cradle turns red.
    my setup is i have the KBW plugged in the keyboard port and the cradle, and i have the power adapter plugged in to the cradle. It seams the cradle isn't talking to my machine. is there something i can check
    Yes, i followed the instructions for the KBW section. also i found this quick guide which pretty much says the same thing on shorter.
    http://support.scansource.com/images/TKP...
  • 2,427 Answers
Hi,, ok the beeping means it scanned, however, the tones after it means that there is not response from the application sever. Let me explain. The bar code scanner is OPOS, and requires POS software for it to work right. in other words its designed specifically for POINT OF SALE DEVICES. 1 such program is cash register express.
http://www.internationalpointofsale.com/downloadcrenet.html
click that link full out the form and you will get a FREE FULLY WORKING VERSION.
what happens is the scanner, scans, sends it to the pc, the opos software takes the info, and sends back a message saying thanks, the scanner isnt getting the thank you message and thats why it appears a bit grumpy with the tones and all.
Any POS software will work, you just need to install it, setup the devices propperly on it and caliberate it which can be tricky for people. dont wory i am not letting go out in the cold alone.
http://download2.pcamerica.com/12.0/cre_getting_started_manual.pdf
That is the getting started ,manual with full detailed instructions in setting up the device in CRE (cash register express).. same principle is used in any pos .. OPOS can be complicated and scary, but use that guide and you'll be fine.. Is in pdf format and requires adobe acrobat reader to open, more than likely you already have that. so just save a copy or print it out.
PS the manual has instructions for cash draws and printers as well..
let me know if you need more help,, bye..
Posted on Apr 06, 2011
  • 2,632 Answers
Welcome to Fixya. If you are receiving Three quick beeps (all the same tone) it means that the battery is low. Since this was a brand new device then you need to charge it up same with other device that uses a battery that you need to change before you use it. I attached the manual below so that if you have questions about the functions of the Scanner you can use it a reference.
LS4278 Reference Manual
You can also download the latest software and driver on the link below
LS4278 Drivers and Software
If you have questions please let me know. Thanks for using Fixya.
Posted on Apr 04, 2011
  • 1 more comment
  • Rofel Lantican
    Rofel Lantican Apr 05, 2011
    Did you already installed the latest software?
  • Rofel Lantican
    Can you please try to install the driver of the scanner so that it will work
  • Rofel Lantican
    Just a quick question did you follow the reference manual above on how to set it up?
My canner ls4278 is making a sound and turnin red when i scan
It could be the scanner is not paired to the cradle. The scanner will be once for the barcode and then four times for the communication error. Make sure the cradle has power; it will pull power from a USB port. Scan the pairing barcode on top of the cradle. The scanner will give a high low high low beep and then shortly after give a short low short high beep indicating the radios have paired. If the scanner still beeps four times after doing this, the host type may not be set. If connecting USB scan HID Keyboard from the LS4278 Product Reference Guide.
Jun 10, 2014 | Symbol LS 4278 Barcode Scanner
Why does my LS 4278 scanner beep when cradled?
It sounds like the power is dropping along the 15 foot length of the cable. You could try connecting a power supply to the cradle and should not hear those beeps any more. The part number of the power supply is PWRS-14000-253R. All of this assumes you are using the STB4278 or CR0078-SC cradle to connect. If you have a CR0078-P cradle it needs a different power supply.
Apr 30, 2014 | Symbol LS 4278 Barcode Scanner
LS4278 no laser
There are three possibilities I can think of assuming this is not a brand new scanner:
1. The LS4278 is faulty - which given Symbols quality I would say it is normally not the case unless th scanner has been dropped or otherwise damaged.
2. The cradle is not charging the scanner. You may wish to try another cradle - one that you know is charging aother scanner. After a few minutes you should be able to see the laser.
3. The battery in the scanner either needs a recondition (see product reference guide), or needs replacement.
Apr 14, 2014 | Symbol LS 4278 Barcode Scanner
My symbol barcode scanner beeps 4 time while I try to scan. The Manual states that the battery is bad. I replaced the battery & it does the same thing.
This 4 beeps also stays for communication error. Please check the connection to the cradle and also the connection between the cradle and PC.
You can start by pairing the scanner with cradle with the Pairing barcode, then defaulting the scanner to the standard settings - use the barcode "Set All Defaults" from the manual. Then select the right host type USB, RS232 or another.
After this procedure should the scanner work.
Sep 07, 2010 | Symbol LS3578-ER Rugged Barcode Scanner
I have a symbol LS4278 scan gun. When I place the gun in the cradle it blinks with an amber light. In the documentation that says that it has a "Critical battery temperature fault". I replaced the...
Hello Lynda,
this seems to be an error with the charging system of the scanner. As you stated the error occurs also with other battery. Just check if the scanner is in warranty and send it for repair.
It could work also with this error, but the charging will not work correctly. As the temperature error is safety measure which stops the charging until the status get changed.
Aug 02, 2010 | Zebra LS4278 Cordless Bar Code Reader...
Are you able to please give me the reset instructions for a symbol scanner? model: LS4278
Hi, I would be happy to assist you in resetting your LS4278, but it would be helpful to know how you are connected. The Set Defaults barcode will reset all of the scanner settings, but it will also cause you to lose the "pair" (communications) between the scanner and cradle. If you try scanning a barcode at this point you will receive a single beep followed by four error beeps. This just means the scanner is not talking to the cradle. Scan the barcode on top of the cradle. The scanner should give a high low high low series of beeps followed by a short low short high. The short low short high indicates the scanner is talking to the cradle again and you are ready to scan.
If you are connected through the USB port and scan a barcode and get one beep, but do not see data on your host try unplugging the black power supply cable from the cradle. Try scanning your barcode again and it should show up on the host.
Jul 09, 2009 | Symbol Cobra LS1902 Handheld
Scan in color
Press the "Scanner" button. The new screen includes a button for "Scan Settings". Press that button; the next screen offers, among many options, a pair of buttons for "Tex/Photo" or "Full Color". Make your choice, then press "OK" and you're back to the main scanner menu and you scan as normal.
Everything is easy, when you know how. <s>
Frank
May 07, 2009 | Office Equipment & Supplies
Replaced battery - do I need to re-boot?
No you have to configure blutooth Adress, it's located on the bottem side of the scaner , scan that barcode and try to read, if it fall, get the user configuration gueid and enabel KBW OR USB ( first Chek Your communication method) if it's KBW trun to page 56 and scan Load keyboard Wedge Defaults , if it's usb trun to page 68 and scan enabel usb interface. if agein fall, scan the recall deafult and do the above steps.
mevan
MARC
Aug 04, 2008 | Metrologic Instruments Voyager BT MS9535...
Symbol LS 4278 Barcode Scanner Logo
1,756 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
