Question about Frigidaire Washing Machines
I bought a used frigidaire gallery series and it will run for a few minutes and stop. The pause button flashes. Only drains & spin if change to that setting
    Brigadier General:
  • 6,277 Answers
(try this JUST IN CASE!)
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Apr 04, 2011
How to fix gallery frigidaire code pau
Hey friend, thank you for the post!
I see from your post that your Frigidaire washer is displaying a PAU code. Normally means the washer has been paused, which could be cleared be pressing either the cancel button or start button once. If that does not clear the code you could try resetting the appliance by disconnecting power. This could be done one of two ways by either unplugging the washer or flipping the household circuit breaker for ten minutes. Please comment back I would like to know if this information has been helpful. -Matt
Jul 23, 2014 | Frigidaire Washing Machines
How do i find out what the frigidaire gallery series dryer error messages are
Hello Friend, this is Z. I appreciate your post!
To get the error code your dryer may be experiencing, attempt the following:
Wake your dryer by pressing any button except for CANCEL.
Press and hold the "CANCEL" and "START PAUSE" buttons simultaneously for 6 seconds to show the error recorder code your dryer may have. The error code normally appears in the display as an E followed by two numbers.
If your dryer shoes, E00 it indicates no failure code was detected.
I ask that you please follow up with a comment on the post, at your convenience, to advise if you receive an error and if further troubleshooting is needed.
Thank you!
Jul 17, 2014 | Frigidaire Dryers
Frigidaire gallery series front loader will not spin or drain
You really should recall the error code from the unit. Try the following and let me know if you can figure out the alpha numeric code.
WAKE THE WASHER BY PRESSING ANY BUTTON.
WAIT 5 SECONDS.
PRESS AND HOLD THE START AND PAUSE/CANCEL BUTTONS SIMULTANEOUSLY.
ALL LED'S WILL GO BLANK AND AFTER A FEW SECONDS THE CONTROL WILL SIGNAL THE STORED CODE USING AUDIBLE BEEPS AND BLINKING LED'S. THE CONTROL WILL REPEATEDLY SIGNAL THE CODE, AS LONG AS THE START AND PAUSE/CANCEL BUTTONS ARE PRESSED. A TWO-SECOND PAUSE BETWEEN REPEATS AFFORDS YOU THE ABILITY TO MAKE ACCURATE COUNTS TO IDENTIFY THE CORRECT ERROR CODES.
PLEASE NOTE THE FOLLOWING: ON A SMALL NUMBER OF WASHERS WITH SERIAL
NUMBER PREFIX XC4, IF THE PREVIOUS PROCEDURE DOES NOT PREFORM AS
SPECIFIED, FOLLOW THE OPTION BELOW:
* FOLLOW ALL PREVIOUS STEPS BUT INSTEAD OF PRESSING START AND PAUSE/CANCEL BUTTONS, PRESS AND HOLD OPTIONS AND PAUSE/CANCEL BUTTONS."
*THE CONTROL WILL PAUSE FOR 2 SECONDS, THEN REPEAT THE CODE AS LONG AS THE TWO BUTTONS ARE PRESSED AND HELD."
NOTE: A LETTER APPEARING IN THE CODE STANDS FOR A NUMBER HIGHER THAN NINE: A=10 B=11 C=12 D=13 E=14 F=15 "
"EXAMPLE CODE F1: THE FIRST DIGIT WOULD BE 15 AND THE SECOND WOULD BE 1. IF THIS CODE WOULD APPEAR ON A WASHER IN THE GOOD MODEL LINE, THE FIVE INDICATOR LIGHTS WOULD BLINK FIFTEEN TIMES AND THE START INDICATOR LIGHT WOULD
Jul 28, 2012 | Frigidaire ATF6000ES Front Load Washer
I have a Frgidaire Gallery series front loader washing machine. It just started pausing itself mid cycle. I have to keep checking on it and repress the start button. It doesn't seem to be spinning...
I have the same problem ,, and i called frigidair and they didnt seem to care my unit is only a year old ,, im so furious right now ,, now i was looking on the recall list and the water pumps are on the recall list on selected models i know with mine it will stop then pause and not drain the water out ,, maybe some can help us out :)
Sep 06, 2011 | Frigidaire ATF6000ES Front Load Washer
My moms front loader is a frigidaire gallery series. when she tries to start a load itll bring in a lil water and then just stop. don't understand why it is doing that
Turn off the machine then unplug it for at least 5 minutes and plug it back. Turn on the washer then press any button and wait for 5 seconds. Press and hold the START/PAUSE and CANCEL buttons simultaneously and the most recent error code will appear on the display as an "E" followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. Post back the error code to determine the problem and necessary actions to be undertaken in order to address it.
Jul 19, 2011 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Washer will spin while in rinse mode, but does not
this could be a main control board problem.how ever i would check the drain pump for any kind of foregin object that may be causing the drain but to stop functioning.last resort bad drain pump
Sep 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Won't wash
press the pause and stop button at the same time it will give u a code
Mar 20, 2009 | Frigidaire Affinity ATF7000E Front Load...
Washing Machines Logo
22 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
