Question about Coffee Makers & Espresso Machines
I have a miele coffee maker but my steammer spout does not make steam. What can i do?
  • 66 Answers
^ Take out the water tank and then insert it again. If still no or little water is dispensed the steam valve is clogged. ^ Open the appliance door. ^ Press the steam lever down and pull off the rubber sleeve. ^ Using the small end of the provided tool unscrew the top of the steam valve counterclockwise. ^ Clean the tip and screw it on again
Posted on Apr 04, 2011
Coffee makers Miele cva 4066 stuck on fit jets in central spout
You might need to reset the coffee maker by turning it off and then turn it on again.
Apr 28, 2015 | Miele Coffee Makers & Espresso Machines
Only one spout dispenses coffee
Same for my CVA 5060 : the right spout seems to be blocked...
I tried a cleaning cycle and a descaling one with no success.
Any idea of where to clean ?
Apr 13, 2014 | Miele Coffee System
Miele CVA615 won't produce steam or hot water. Machine makes a mechanical noise like it's trying but no water comes out. The expel air indicator was on and this preceded discovery of the issue. Steamer...
Trey -
It sounds as if the water pump has gone bad. If the machine will not put water out of the hot water spout or the steam spout, and there is no water in the base of the machine (leaking from pump) then the pump is not putting out any pressure. The sound you hear is the pump running - but no pressure behind it.
Dec 30, 2013 | Miele Coffee Makers & Espresso Machines
Miele coffee maker water not coming through to brew unit
try cleaning the nozzles using fine wires or tobacco pipe cleaner kit. it look like you have a blockage on your tubing leading to nozzles.
Nov 06, 2013 | Miele Coffee Makers & Espresso Machines
My coffee machine cva610 says descale expel air. It won't allow me to make any more coffee.
If you don't have a manual I hope this helps. You can make coffee without "Descale"ing it but it is recommended you don't go too long without doing it.
- Make sure that the filled water container is in the appliance.
- Turn the program selector to "On" with lighting and place a container under the hot water spout and another under the steam spout.
- Press the hot water button, turn the steam selector counterclockwise and dispense hot water until it flows in quiet, continuous streams.
- Press the hot water button again. Turn the steam selector clockwise to o, to turn off the water.
Regards,
Dave - Avalonxls at att dot net
Feb 09, 2011 | Miele CVA610
Miele CVA610 error reads expel air but when we do as manual suggests (run hot water & milk frother) no water comes out.
If this doesn't do it for you, you are doing it wrong!
Oct 06, 2009 | Miele CVA610
Lack of pressure from the steam wand used for frothing the milk.
Hello Juneyjune,
These coffee systems have a series of small rubber 'O' rings that tend to crack from condensation over time causing your low pressure problem.
The 'O' rings are connected to a heater that looks like a horse shoe mounted in back of the grinding unit.
I would recommend contacting Miele technical services. They can have a technician come out to replace the 'O' rings or you can order them from the technical services rep if you know someone that can replace them for you. Just be careful. These machines operate off of 220 volts and that is no fun to get shocked by. I have been many times with this machine
Good luck!!!
Sep 06, 2009 | Miele Coffee System
Miele Coffee Machine won't dispense from 1 of 2 spouts
the spouts located is on door which carry the coffe to final stage to cup of coffee
thanks
Jun 05, 2009 | Miele CVA4070 Coffee Maker
Coffee Makers & Espresso Machines Logo
363 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
