Question about Acer Ferrari 5005-5832 Notebook
My laptop is during working over heating.after then os was carshed so i was formated hd.so hidden partioned have lost.after den internal issue.cn u sugest me where is the service centre
    Brigadier General:
  • 8,909 Answers
If you were to browse www.acer.com there is a list of authorised repairers in you area.
Posted on Apr 04, 2011
My flash drive cannot read the content.why?
YOUR COMPUTER VIRUS AFFECTED .TRY TO SURE BY FOLLOWING STEP>
IF CAN NOT SHOW HIDDEN FILE (TOOLS >FOLDER OPTION >VEIW> CHECK ON SHOW HIDDEN FILE>CHECK OFF HIDE PROTECTED ND CHECK OF HIDE EXTENTION)
CAN NOT OPEN MS CONFIG
CAN NOT OPEN REGESTRY
CAN NOT OPEN GROUP EDIT POLICY
THINK VIRUS AFFECTED .DELETE PARTION CREATE VPARTION AND INSTALL OS.
IF OK YOUR PC GO RUN TYPE >SFC /SCANNOW
ENSURE THAT YOUR OS IN THE CD TRAY.
RESTART IT .
Nov 24, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
HDD cannot be detected after reformatting
Ok, unfortunately, even though, you had two partitions they were both on the same Physical drive, now you cannot "Format & Partition" without breaking the install, as the Win 7 is the "Boss" and when you formatted you have wiped out all you boot track information, You maybe have a shot, if you get a Win 7 install disk, and boot off of it, then ask it to repair your "Boot Sector" this may allow you to Boot into Win 7,if you are lucky. Then you can use as normal. But if you cannot do that, you will have to boot from a Win 7 or Vista or whatever OS you wish to install,and follow the instructions, and do a complete reinstall of the OS. If you wish more than one partition, in the setup, it allows you to choose the size of your drive, so simply do all that, at that time.
May 08, 2010 | Acer Aspire 4720 Notebook
I can't install any OS because by DVD drive doesn't detect it!
have you tried using fdisk and delete partion then make new partion and set active partion then boot from CD which will then format drive then install OS
Jun 24, 2009 | Computers & Internet
I have to recover fat32 partion with OS & data
Dear user,
Pl Check your format your c: drive or D: drive.
another way you connect your hard disk to another working coputer and pl check your hard drive data by drive.
Regards,
Ravindra Shah
Jun 01, 2009 | Computers & Internet
No internal hard disk found
Hi there.
Use the Vista CD to create the new partition, but first you have to delete the old partition first, (the 220GB partition not the 10GB one because that will be the recovery partition).
Get a calculator and work out your new partition, for example 50GB is 50x1024MB so that will be 51200MB.
When you have deleted the 220GB partition select NEW and input your newly worked out partition and carry on from there, to activate the other partition just format it.
Please post back with the results and for anymore help if needed.
Good luck and thanks for using FixYa!!
May 24, 2009 | Dell Inspiron 1525 Notebook
No internal hard disk found during booting when i am going to format
It is possible that the HD has failed completely. However, this is a relatively new laptop, so I would suspect that is not the case. Sometimes the HD will lose contact for one reason or another. This can usually be cured by removing the HD and reinstalling it, which will remove any crud from the contacts.
http://www.fixya.com/support/t1639067-reseat_hard_drive
If the machine is still under warranty, call Dell support. They will walk you through diagnostics to determine the actual problem.
If you're not sure of the warranty status, go here:
http://support.dell.com/support/topics/global.aspx/support/my_systems_info/details?c=us&l=en&s=gen
HTH
I have a Dell Inspiron Laptop Having Issues
You need to not delete the partion but you need to do a format on your HD (harddrive) to basically remove EVERYTHING. What you did was just installed a second windows onto your computer.
Feb 04, 2009 | Dell Inspiron 8200 Notebook
Partition
The solution to your problem is very simple.
First make two partions of your harddrive, To do so:
-Open up control panel.
-Click open Administrative Tools.
-Click open Computer Managment.
-Then Click on Disk Managment on the right side.
-Choose your main Harddrive, Right click and click Shrink Drive
The amount you Shrink will became your second partions that you can put any OS you want.
After you Have made two partions Install the Vista Os on the second partion(its usually named D:).Soon after the installation is done choose vista from the OS choice menu.
-Log into Vista
-Click on the Drive that has XP installed into and by using the ".exe" files of the software you want to install. Install the software onto vista.
And there you go, now you have:
-Vista N XP on two seperate drives.
-And your vista has the software you wanted.
Please Rate, Thanks
Jan 06, 2009 | Lenovo IdeaPad Y510 Notebook
Missing hard drive space
Simple problem you made the partions using FAT 16 file system and 80 GB cannot be partition using win98 10 will limit the disk to 10 GB.
Remove all Partions And Use Windows XP to create partition during Installion.
Fix Ya
Best Of LUCK.
Jan 07, 2008 | Computers & Internet
Acer Ferrari 5005-5832 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
