Question about Watches
I have a battery operated Timex Anniersary Clock HD-1688 and can not find the paperwork on it. I changed the batteries but cannot remember how to make the clock run. I changed the time and set the chime but no hand movement. What do I do?
  • 744 Answers
SOURCE: Elgin grandfather clock chimes not working
I'm not positive about this, but I seem to recall that these type of clocks have two "silence levers" on the movement. These levers are located at the upper left and upper right corners of the movement as you face the movement from the back. The movement back panel has to be removed if it has one.
If the levers are pushed toward the chime rods, they will silence the hour or musical chime, depending on which one it is. I believe the silence levers are supposed to be moved away from the chime rods so the rods can retract and then strike the chime bars.
Posted on Mar 29, 2009
SOURCE: Seiko Westminster Chime Clock; Model No. QQF150G Caliber 12105
Does this help
http://www.theclockdepot.com/seiko_westminster_clock_instructions.html
Posted on Apr 22, 2009
SOURCE: Elgin Westminster Quartz Chime clock won't work
IF I GATHER CORRECTLY , YOUR CLOCK HAS TWO BATTERIES, ONE AT BASE AND ANOTHER ON THE BACK OF THE UNIT. THE ONE ON THE BACK OF THE UNIT IS RESPONSIBLE FOR CLOCK'S FUNCTIONALITY AND I THINK THE BATTERY AT BASE IS FOR THE ROTATING BALLS ( PENDULUM ). SO OPEN UP THE BACK IF YOU HAVE NOT DONE SO, AND REPLACE THE BATTERY. CAREFULLY THOUH AS THERE RE TWO SCREWS ON TOP AND A SNAP AT CENTER BOTTOM WHICH YOU COULD EASILY BREAK IF YOU DO NOT DO IT WITH CARE. OPEN UP THE SCREWS FIRST AND GENTLY USING A SCREW DRIVER PUSH BACK ON THE SNAP HOLE TO FORCE IT UPWARDS AND INWARDS. IF NONE OF THIS MAKES SENSE THEN WE ARE LOOKING AT TWO DIFFERENT CLOCKS.
HOPE THIS HELPS.
Posted on Oct 11, 2010
  • 16 Answers
SOURCE: Quartz president wall clock, I need to set the chime
I have a pendulum wall clock from the president collection. If yours is the same or similar, the following may help:
*Look at the back for a slide switch labled "start" at the top and "set" at the bottom and move it to "set"
*Look for for small push buttons. They represent the hours and minutes. Push each in turn, the number of pushes to represent the time, ie, for 09:45, ignore the first(0), push the second 9 times(9)-push the third 4 times(4)- push the 4th 5 times(5). When done, push the slide switch back to "start".
If yours is the same as mine - a wall hung pendulum clock with Westminster chimes, made around 1988. I would be happy to scan and send a copy of the instructions.
John
Posted on Nov 03, 2010
SOURCE: timex westminster anniversary chime clock doesn't chime correct number
Take the batteries out from the base, where the chime mechanism is. Wait till it gets close (20 seconds till) to a specific hour time, like 8:00 or 9:00, replace the batteries for the chime mechanism. And then count the chimes at the hour. If they are correct, you are set. If they are incorrect, turn the time back 15 minutes before the hour and bring it right back and monitor the chimes again. Hopefully this should fix it. Please post the results.
Posted on Nov 10, 2010
Timex W-225 -- the tide and temp button are non-responsive
have you try changing the battery...?
or-
did your watch has been been dropped?
Sep 09, 2008 | Timex Watches
How to change CR2016 and SR526SW BATTERIES OF ironman triathlon 50 lap
Timex Triathlon Ironman Watch Battery Change - YouTube
? 2:44
https://www.youtube.com/watch?v=x_C7VsE8Kks
Jun 26, 2015 - Uploaded by Lin Le
Timex Triathlon Ironman Watch Battery Change, I forgot to show you how to reset the "AC" with tweezers so ...Missing: cr2016 ‎sr526sw
How To Change CR2016 Battery In Indiligo Timex Watch
www.mademan.com/.../how-change-cr2016-battery-indiligo-timex-watc...
Oct 15, 2010 - Wondering how do you change a CR2016 battery in a Timex Idiglo watch? Changing a CR2016 battery in a Timex Indiglo watch is not a hard ..
Nov 17, 2015 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
I need a new SHENG BANG HD-1688 AA VOLT BATTERY MOVEMENT
Check on Amazon or Madeinchina .com, Tradetang may be a good place too
Nov 11, 2014 | Watches
Hello. I own a 40 to 50 year old "Timex Electronic" watch. There is a number date at the 3 o'clock position. I see no other identifying info on the outside. I don't have a battery for it. How
What is the exact model of the watch. I have several Timex Electronic watches that might fit your description. If you pop the caseback do you see the old battery inside? Most batteries would have a reference like: CR2016.
Jan 06, 2013 | Timex Watches
I have a Timex Wacky Wake-up Alarm clock and can't
When you are setting the alarm on the wacky wake-up timex alarm, if you keep pressing FWD, you will see a small PM in the bottom right hand corner. When the PM sign is gone, you will now that it is set to AM.
Mar 09, 2012 | Timex Watches
I have a Timex Ironman T563719J. The digital clock is working, but the analog portion has stopped. Any ideas?
There are two batteries in the watch. One for the digital watch and the other for the analog watch. The battery for the analog side probably needs changing but when the back is opened, you might as well change both batteries.
Jan 18, 2011 | Timex Ironman T56371 Wrist Watch
My aunt's watch is a timex expedition. it says to push the reset button after changing the battery and we can't find one. The clock works but the alarm doesnt. She had the battery replaced at walmart...
I am sending you a link to instructions for a differnet Timex, but it is basically the same conccept. This link has pictures which will help you figure this out. If you still have troubles....I highly recommend you take to a QUALIFIED jeweler besides Walmart.
http://www.userinterface.com/instruc/timex/timex.html
Best regards. Jewel
Sep 01, 2010 | Watches
Repair of battery-operated wall clock
We had the same problem with our wall clock, but it was due to corrosion from a dead battery. The battery acid leaked inside and disrupted the connection between the metal contacting the batteries and the circuit (the one with the copper coil). We took everything out cleaned the contact points with acetone (nail polish remover). After that we had to bend the contact heads up just a little bit so they would contact the circuit again (I guess we bent them down a little when we were cleaning it). It worked just fine after that. I know it sounds intimidating to take apart a clock and put it back together but you're going to throw it out anyway. Just give it a try. It was kinda fun. Think of it as a puzzle. If you can't fix it, I imagine you can get a new motor at any hobby store or Michaels.
Jun 24, 2008 | Kenneth Cole 1213 Wrist Watch
Watches Logo
73 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
