Question about Canon PIXMA MP620 All-In-One InkJet Printer
Canon mp620 unable to use rear tray feed, rubber feeder wheel look dried out. Canon tech says no parts available, suggest I take it in to a repair shop. Not under warranty, should be an easy fix. Any suggestions?
  • cjoythree Apr 04, 2011
    I was thinking of trying WD40, but was hoping that someone could tell me how to actually get to these wheels so that maybe I could try to replace them. I don't think alcohol and soap would be satisfactory - I already cleaned them off as recommended by the manufacturer - used nail polish remover, but the wheels are too dried out to catch the paper.
    Thank you for the replies, there is no solution to this problem, presently. However, if companies had the integrity to be green and offer parts for problems such as this our country would be filling landfills slower!!
    Top Expert:
  • Canon Master
  • 76,649 Answers
This printer new was sold for less than $150.00, the cost of repair will be at least $100.00, and if the part is not available from Canon I doubt anyone else will have the part new. I suggest you replace the printer with the newest version that is comparable to the old MP620 an in my opinion as good or better then the MP620. The Model I suggest is the PIXMA MP560 All-in-one wireless Canon printer, it is sold by Amazon for starting at $117.00.
Posted on Apr 04, 2011
  • yadayada
    yadayada Apr 04, 2011
    Low cost printers used by the home computer system are considered and designed as throw away products, they don't want you to fix it, sorry but that is the truth of the matter. The high end commercial printers (big $$) are really made to last, and parts are available for many years after they are not the current model. This is also true of home computers, I know all of the above from very personnel experience. I always give the honest answer, even if it is not very popular. I do agree with you 100% on going "Green"
  • 2,632 Answers
Welcome to Fixya. The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of Alcohol and Soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and it will work for quite sometimes
This will be just a band aid solution but if still wont work then most likely you need to bring it to a repair shop.
If you have questions please let me know. Thanks for using Fixya.
  • Rofel Lantican
    Rofel Lantican Apr 04, 2011
    Like what canon tech support told you that you need to replace them. I just provide you with a band aid solution because the only solution for your problem is to replace the rollers. since that the rollers is not working then it should be replace with the same part. Anyway thanks for your time.
Will not manually feed paper
Are you talking about the document feeder or the copier. On both counts try to clean the rubber wheels above the feed tray, or up on the document feeder with something like windex or a water cleaner. make sure the wheels are dry, and watch to see if the wheels are turning. If wheels are turning when you feed you need new wheels, sometimes you can rough them up with a grit nail file, or sandpaper.
Apr 30, 2014 | Brother MFC-8460N All-In-One Printer
Printer screen says that there is no paper when I just put some in the front feeder. I have a Canon MP620.
The MP620 also has a rear slot for smaller paper sizes. Did you perchance submit a print job for some
alternate paper size and the printer is expecting a rear load of paper?
Mar 22, 2011 | Canon PIXMA MP620 All-In-One InkJet...
I cant get the machine to grab the paper and it says its out of paper, yet its not out of paper.
Hi, the Ip3000 has 3 different feeding trays...
make sure that the printer is trying to "grab" the paper in the tray that you have chosen to use in the printer properties box...
when you give the print command can you see the rubber roller moving to grab the paper in the top feeder tray???
if the roller that feeds the printer is not moving you may have accidentally changed the settings to grab paper from the bottom tray...the one right under the door that opens to let printed pages out of the printer...
the 3rd feeder tray is the DVD/CD printing tray...
I suggest that you look at the printer Properties for remedial action...
hope this helps you with your problem...
cheers
haitchhcee
p.s.
suggest you place paper in the bottom tray before making adjustments to see if it is trying to grab the paper from there...
Dec 08, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Cannon pixma ip 4600 error code 5700 - paper jam
The error code 5700 is the sensor error.Replace the sheet
feed unit and then adjust the timing of the paper feed gears.
Sep 02, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Hi, While loading paper I'm getting an alarm saying E2 though papers are present in the paper tray. I 've pulled the clip in the paper feeder to the left, kept the paper i.e. alligned it to the right of...
Does your printer have a paper tray on the bottom as well? If so there's a feed switch that tells your machine to use the tray or the rear feeder. There's also a small printer picture with a light that either is lit for the top or bottom feeder. To be safe, put paper in both trays.
Aug 13, 2009 | Office Equipment & Supplies
Can't print business cards. Won't feed from rear tray.
I just spend over an hour on the phone with Canon for the same problem... the resolution is simple. From the Control Panel, select Printers & Faxes. Right-click the mp620 printer, and select Properties. Select Printing Preferences from the bottom of the General tab, then click the Page Setup tab. Choose Print Options at the bottom. Place a check mark in the box next to "Disable the paper source setting of the application software." Click OK 3 times and the problem should be solved.
Jun 02, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Need Canon MP620 Paper Tray
Gmack1142, If you haven't already found one, I have an extra I'll sell for 10 bucks plus postage. E-mail me at schaefferrw@hotmail.com and we can set it up. Roger
May 26, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Paper feed feeding multiple sheets plus noisy feed
The most likely cause of this problem is a paper feeder malfunction. Because you were not specific in the model you have, repair could be rather variable.
One plausible cause is the paper rollers have tried up. Normally when the small rubber rollers grip the paper, the friction generated by a properly moisturized feeder can grip a single sheet. If your rollers are getting dry, you can use some rubbing alcohol on a q-tip and rub it on the rollers. Make sure not to use isopropyl alcohol, that will cause the rollers to dry out even more. I've heard of people using WD-40, but I've never tried that. You would want the WD-40 to dry a while otherwise it will leave greasy residue on your nice white paper.
Another cause could be a small object (paperclip, staple, raisins) stuck in the paper feeding mechanism. Carefully inspect the feeder, comparing one side to another, and gently pushing on the movable parts to make sure they can move free. You don't want to push too hard or you could knock out a needed spring or damage the plastic gears.
Hope this helps!
Oct 16, 2008 | Canon Office Equipment & Supplies
Printer HP PSC 1610XI
Ink Jet Printers are notorious for this. Try using household dish detergent( or any thing that contains glycerin [C3H5(OH)3] ) on the rubber wheels. It appears that the glycerin in the dish soap replaces the glycerin in the material frequently called rubber.
Apply the dish soap to all exposed wheels.
Let soak for five to ten minutes.
Wipe the wheels clean. Clean up any spillage too.
Run a few sheets of paper through the printer (until the damp/oily wheel marks disappear from paper).
Printer should work like new when complete.
May 02, 2008 | Office Equipment & Supplies
Canon PIXMA MP620 All-In-One InkJet Printer Logo
344 people viewed this question
old marine
old marine
