Question about GE Washing Machines
My GE washing machine approx. 2 yrs old makes a terrible noise when spin drying. I suspect a bearing failure. Never having fixed any washer I need to know how to access the bearings of either motor or pump. Thank you Reiner Schwark
  • 1462 Answers
SOURCE: Drum will not rotate
im confused as to why you think no drum rotation would be caused by bearings. typically worn bearings would cause noisy spin. only if bearings were completely seized would that cause no drum rotation. can you rotate drum by hand? if so bearings are not seized. can you hear motor rotate when you select spin? if not, then likely cause is motor brushes. do these simple tests and get back to me if you want. and bearings are quite difficult to replace on this machine
Posted on Apr 27, 2007
  • 79 Answers
SOURCE: grinding noise
The Neptune bearings are an interesting breed... Maytag wants you to replace the whole outer tub which includes the bearings installed for $180 or so. You can replace the bearings yourself. See www.tonytool.com to see how it is done. The tool costs $379 or so... but it is designed for the service tech. not the d.i.y.er. But watching the video can give you an idea of how to do it yourself. The bearings were available on www.neptunewaxmotor.com for about $35.00. You will also need the Maytag seal kit 12002022 to complete the job whether you decide to replace bearings or the outer tub.
Posted on Jan 05, 2008
the dr
  • 447 Answers
SOURCE: Kenmore Super Capacity Washing Machine
If your washer is the one you have chosen a Whirlpool built kenmore unit than your washer doesnt have any bearing that fail, It could be the spin tube mounting block becoming stripped ( most common) or a clutch or brakes not releasing issue (not likely). Also make sure the machine is agitating it may just be filling with water and draining and making motor noises. In this case the motor coupling has broken. both the block and coupling are inexpensive parts and easy to install.
Posted on Jan 15, 2008
I just took my Neptune MAH5500BWW apart and found that the bearings are shot. My local Maytag service provider quoted me $425.00 for the whole outer tub! I would have bene happy with $180.
Posted on Feb 07, 2008
  • 6 Answers
SOURCE: Clanking noise during spin cycle
I was told by 3 technicians that my washer had shot bearings and this is a common problem for the Kenmore Elite Front loader.
Sears knows it and will not do anything about it except try to sell you a new washer since it costs $800 to replace the unit with the bearings.
Posted on Feb 13, 2008
Excessively noisy when it spins. The faster the spin the noisier it gets.
Sounds like the Drum Bearings are gone they are **** on Hotpoint..Could be quite expensive depending on age...3 years old you will need a half drum complete with Bearings approx cost £80 plus labour....if more than 4 yrs old then perhaps bearing kit plus 3 hrs labour....Hotpoint give a FREE 5 yrs parts warranty however CALL CHARGE....£105 approx parts are free.....You need to ecide if you should fix or just buy a new one........
Jan 14, 2011 | Hotpoint WMA58 Front Load Washer
Hi my hotpoint washing machine is near 3 years old the last few weeks it is making a terrible noise when on spin only. \r\nthe noise is really loud but everything is washing and drying the same its just...
Sounds loike the main drum bearings have failed.
Spin the drum by hand from the front, and if it feels rough, or is rumbling or grating, then the main bearigs have failed.
Quite an expensive repair, unless it is covered by the Hotpoint 5 year parts guarantee, check with Hotpoint.
Jun 16, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
The washer works as far as washing the clothes but makes a terrible noise when spinning.
If the machine is a few years old it could mean that the rear seal has worn and allowed water into the spin bearings. If the drum feels loose, it means ther'es free play in the bearings as well. Not good news..It's a major job and will need a wokshop...........Nomess
Apr 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
FRIGIDARE FRONT LOAD WASHER,2+YRS OLD ON FINAL HIGH SPEED SPIN MACHINE MAKES LOUD VIBRATION NOISE AND FIND NEED TO SHUT DOWN DUE TO FRANTIC VIBRATION AND NOISE.
It is possible the bearings on the motor that spins the canister could be going bad especially at the high speed. This could also be from clothes getting unbalanced in the final spin cycle. Hope this helps. This could still possibly under warranty!
Aug 22, 2009 | Washing Machines
Won't spin anymore and has been making terribly load noises while spinning for 3-4 weeks> Also, there is gray/black water leaking from underneath (2-3 weeks)
this appears to be main drum bearing failure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Kenmore HE2 Plus Front Load Washer
Drum won't stop filling with water
i think u need a bearing seal to ur washing machine so ur gona need a technician and if its gona coast a lot just change it
May 31, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Outer Tub Bearing
Yikes, I would buy a new washer for that price. Also try calling another local appliance tech out and see his price on fixing the problem. You may also be able to fix it yourself but you will have alot to remove
Feb 09, 2009 | GE WSXH208A Front Load Washer
Makes horrible noise during spin cycle only
The bearings have most likely gone bad. This is a very common problem with the front load washer when powder soap is used.
Jan 28, 2009 | GE WBVH6240F Front Load Washer
Jan 02, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
