Question about Jandy Teledyne Laars HiE2 Pool Heater 350000 BTU Natural Gas
During a recent power outage my Jandy Pool Heater Hi-E2 no longer would initiate the heater. I tried the standard process or turning off and then turning back the heater - which I've done on numerous other occasions during the 10 year life of my heater. Any recommendations before I call my gas or pool repair company to come out?
    Top Expert:
  • Jandy Master
  • 5,775 Answers
Turn all off then turn aqualink back on first then heater should be recognized
Posted on Jan 30, 2016
  • 22 Answers
SOURCE: jandy aqua link main control box
Do you have a 4 button switch in the spa and is the light on the button that is slightly under water? If so , the button is bad as the water is completing the circuit and turning the light on and off.
Repalce the button or disconnect it at the outdoor panel.
Posted on Dec 21, 2008
SOURCE: low pressure reading on Pool Heater
I had this problem with ours last year. I replaced the water pressure switch and it began working fine. We later had a symptom that the blower would start but it would not ignite. The ignitor rod was corroded so I took it out and sanded it with some sandpaper---worked fine...until I dropped it trying to reinstall and it broke. Bought a new one and it works fine now.
Today's problem is related to the blower now.... it is always something, isn't it?!?
Posted on May 30, 2009
  • 128 Answers
SOURCE: Where is the Air Flow switch on a Jandy LX natural
The air flow switch is in the upper panel on the inside of the heater. There are gray hoses plugged into it.
Posted on Aug 23, 2009
  • 5 Answers
SOURCE: I have Jandy RS4 system with 4-button poolside
Pull the cover off the control panel. You will probably find a button which would be accessible from outside the panel with a paper clip or pencil but is unlabeled. On the board itself by the button, in small letters it should say "reset". Push the button and see what happens.
Posted on Oct 09, 2009
  • 10 Answers
SOURCE: I have a Jandy Laars LX Pool/Spa Heater...when I
If the unit is lighting then shutting off then repeating it isn't rectifying, means not sensing the flame. May have a bad flame sensor or ignition control. I'm guessing your AGS is indicated on the GUI also.
Posted on Mar 07, 2010
How do I fix an Jandy ePump?
open up the power box see if still wet dry out make sure communication plug is dry then power everything down reboot and try again if it doesnt work the main board in the pump is no good
May 25, 2014 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
Jandy HI-E2 350K pool heater vent limit switch is resetting, flow is fast and good, but water temp is getting over 140 and kicking vent limit switch out
the vent switch is for the exhaust. the 135 high limit should be opening if the water temp is getting to 140 degrees.. 1 safety will kill the entire circuit since they are all wired in series
Oct 10, 2013 | Zodiac Jandy Hi-E2 350K BTU Residential...
Hi e2 jandy heater
check pressure switch and copper tube to it
Jun 08, 2012 | Jandy Laars Hi - E2 350,000 Btu Heater
I have a leaking Heat Exchanger in my Jandy Hi-E2 Pool Heater. Do you have instructions for replacing it?
major overhaul call a professional if not correctly done waste of money or buy a new heater
Jun 27, 2011 | Jandy Laars Hi - E2 350,000 Btu Heater
My Jandy Laars Natural Gas pool heater (LJ250N)
Check your heater by-pass valve and be sure it is almost closed. If not that then it will be your internal by-pass. These will force water through heater and keep it from overheating the water inside it and shuting it down. Also check to be sure the baskets are clean and the filter is clean.
Jun 27, 2010 | Zodiac Jandy Lite 250K Btu Natural Gas...
AquaLink RS8 switchs itself from Pool to Spa pump
make sure no programs if ok remove spa side remote plug if ok then replace spa side remote istill does it reset board but before write down all auxs and jvas
Mar 15, 2010 | Jandy AQUALINK RS TELELINK KIT
I have a Jandy Hi-E2 heater, when I try to turn it on the ignition module sends a 3 times signal (ignition lockout). Any idea about this problem?
I am a chief maintance at a courtyard marriott and i have the same problem my ignition board blinks 3 times and says ignition lock out and usually it has something to do with the flow so may want to check a flow issue
Dec 24, 2009 | Jandy Laars Hi E2r Heater 350k Btu Natural...
Laars HI EZR heater does not come on
Hi. I work on Laars HI-E2 heaters at the hotels and there are 3 possible problem. The igniter, ignition control module or "not enough air for good hot combustion" are the main sources. I can go into details about my experiences. I suggest it is best to contact a service company to look at the problem.
Apr 25, 2009 | Jandy Laars Hi - E2 350,000 Btu Heater
Jandy Teledyne Laars HiE2 Pool Heater 350000 BTU  Natural Gas Logo
53 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
