Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
How do I recalibrate scale on Robinair 34134Z
    President:
  • 180 Answers
Robinair Model-34700Z scal calibration follow as bellow:
Press main menu then press up or down arrow till scree appear ''CHANGE DEFAULT'' then press 5454 from the keypad & then YES key (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & then press YES key. now follow the on screen text. Once you calibrate scale then press STOP key to exit.
NOTE: You should have 9KG/20LBS of weight for scale calibration. Do not change ''TANK TARE'' or any other setting it must be on factory setup.
Hope this will help you to solve the problem & if my solution is useful to you please vote for it
Posted on Apr 05, 2011
  • foxesautomot Jun 09, 2011
    my 34134 z has no keypad to enter 5454 whatever
I have a 34134z that will not recover or charge
You may need to replace compressor. Open compressor test port (located on one of the pipe line which come to compressor from top of spin-on filter) and fixe a vacuum gauge on it. press recover from menu and check compressor suction for 13''Hg. If compressor has no suction then its need replace.
NOTE : if you do not have a vacuum gauge then after opening cap from test port, press recover from menu and then gently press small valve on test port with a small L-key to feel suction of compressor. if the compressor discharging air instead of suction, replace compressor.
Jun 11, 2014 | Robinair Cool Tech 34700Z Recovery,...
Hi, my robinair ac375 wonot charge gas, gauge up arrow and down arrow wont move, we done filter and vaccum oil and reset. it is possible to get special way to reset gauge?
mhkamran.jpg Please check Charging solenoid (S3) in Solenoid manifold block, it may need to change solenoid coil or Rebuild. If charging solenoid is OK, then problem can be SCALE or MAIN CIRCUIT BOARD. See if the machine display show default charging weight 90 kg/lbs when you active CHARGE mode. If not then calibrate scale. But if default charging weight is shown then replace MAIN CIRCUIT BOARD. See attached picture to find solenoids. I wish this will help you to solve the problem. If so please vote for it for further assistance. Best of luck!
May 13, 2011 | Robinair Cool Tech 34700Z Recovery,...
Hi, I have a robbin 34134z indicates high pressure and do not work. At times it works and then stops working. I can do? . I live in Venezuela and here there is no Robinair agent indicated as repair them. I...
This is a common problem of Robinair 34700Z / 347002k & 347112k series machine.so don't worry just do the following :- 1# May the ISV tank is not overfilled,remove some refrigerant manually from tank. 2# Purge excess air from the tank manually.( Open air purge hose from the tank,then press tank valve as needed to purge air from the tank) 3#Check the air purge solenoid for proper operation.Hope this will solve your problem, Best of luck & vote for my solution!
Nov 25, 2010 | Robinair Cool Tech 34700Z Recovery,...
How do you calibrate the scale on a robinair 34700z A/C Machine?
Robinair Model-34700Z,for scal calibration follow as bellow:
Form the main menu go to ''CHANGE DEFAULT'' then press 5454 & YES key (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & press YES key. now follow the on screen text.
NOTE:you should have 9KG/20LBS of weight for scale calibration. Do not change ''TANK TARE''. it must be on factory setup 16.30 lbs OR 7.40 kg.
Hope this will help you to solve thr problem & if my solution is useful to you please vote for it
Aug 27, 2010 | Robinair Cool Tech 34700Z Recovery,...
Over charges. machine seems to operate normal, but it over charges every time. I tried to recalibrate the scale. this didn't help.
It seems to be your last calibration was not correct!
For Robinair Model-34700z scal calibration follow as bellow:
Aug 15, 2010 | Robinair Cool Tech 34700Z Recovery,...
Over charging won't recover scale don't work
It is not clear which model of robinair machine you have! However your machine need to re-calibrate the scale.
Aug 05, 2010 | Robinair Cool Tech 34700Z Recovery,...
Hi i need to know how to calibrate robinair 347000z mechine
Form the main menu go to ''CHANGE DEFAULT'' then press 5454 & YES key (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & press YES key.now follow the on screen help text.Hope this will solve your problem.
May 05, 2010 | Robinair Cool Tech 34700Z Recovery,...
RECALIBRATE SCALE ON ROBIN AIR MACHINE
Form the main menu go to ''CHANGE DEFAULT'' then press 5454 & enter (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & press ENTER botton.now follow the on screen help text.Hope this will solve your problem.
Mar 24, 2010 | Robinair Cool Tech 34700Z Recovery,...
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
2,476 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
