Question about LG 42PJ350 42 in. TV
The original tv setting have been changed ,now there is no picture prior to them changing the settings ,we had lost the local channels but had cable now there is no picture at all at first is was a cable problem,we had a good picture, until they start playing technician
  • 89 Answers
Its very simple try to cleck the restore or go to the menu setting or make sure its not in video mode.god bless
Posted on Apr 04, 2011
My television set is stuck on one channel....the audio changes with the channel but the picture stays blurred on one channel...whats wrong with it?
Lots of possibilities. If you are using the remote, try also using buttons on the TV to change channels. If TV buttons work, the remote is broken or perhaps try changing batteries and cleaning battery contacts on the remote. If neither work, lots of other things to try. You may need to set preselect channels, so your TV thinks there is only one channel out there until you do. If you are on a cable box you just need channel 3 and change channels on the cable box. I can't tell what you mean by "audio changes with the channel" ... if you mean that when you try to advance channels, it increases volume and moving down in channels lowers volume that would be strange -- if you are using a programable remote it might not be set correctly (try another programming code). The "blurred" picture is probably symptomatic of having the set on the wrong channel, and if you could set channel it might clear up ... I'd start with getting channels to change. If you need more help, give the brand and model of TV, say if you are using a remote (original or programable), and what the 'audio changes' comment means in more detail. Probably worst case is that your tuner circuit is fried, but don't assume that without more diagnostic.
Aug 29, 2011 | Televison & Video
I connected my GE TV model 13GP301 to a Magnavox DTV Digital to Analog Converter using RF cable. I mistakenly changed the setting on the TV to the video cable connection (red, white, yellow). Now no...
if this shows "vid" on screen turn it back to tuner input with input button on original remote.... could be marked who/input on some....go to mrremote.com if you haven't got it..............good success, meder's tv service
Aug 11, 2010 | GE Televison & Video
Using my universal remote contol,lost sound on 2 TV channels
The solution is to change the audio input from SAP (secondary audio programming - default on TV sets sold in Canada) to Stereo or Mono. Your remote will need to be able to access the "Menu" settings screen for your television set.
May 07, 2009 | Samsung TV Remote Control
My new TV is set for cable. I do not have cable, I have an anten
Sansui TV's come from the factory set for CABLE. If this is a HDLCDVD320, you will have to go into the menu to change the signal type to AIR, then run the automatic search to program in your channels. Their free customer service line is 800 289 0980.
I hope this helps.
Dec 28, 2008 | Televison & Video
Hi, I have a RCA 27" console color tv without the original remote. It has the RCA cable ports. I bought a Toshiba DVD and it needs the TV to have an external channel which can only be set by remote? Is...
After market remotes only work the most basic of functions - ie., volume channel changes , on/off. They do not get into menus, change inputs, etc. If you can change channels on the console tune it to 3 or 4 and get an rf adapter for your dvd player outputs, set it to one of those channels, and connect to tv antenna input. Ir will work but the picture will not be as good as it can be.
Mar 03, 2017 | RCA G27647 27" TV
I lost my instruction manual and can only get local, non cable channels.
Go into the menu to channel setup and change the setting from tv back to cable(catv).
Jun 26, 2008 | Durabrand DU1301 TV
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
Won't receive channels above 18, cable not at fault
Your "tuner" in the menu is set on "off air" or "antenna. It should be set on "cable" or "dish". See if you can go into your menu with the buttons on the set and change your tuner setting. Keever
Mar 06, 2008 | Sharp 27L-S100 27" TV
Can't get orion 27 inch tv to turn off with cable remote
http://www.newtvremotes.com/Mfrs/Generic/ACCord.htm
you can buy the original remote from these site they have it....good luck and rate me
Dec 30, 2007 | Orion STV2763 27" TV
HDTV Cable box conflict
This set does not support 480I in the DTV mode, only 480P and 1080I is supported. Try setting the analog setting in the cable box to 480p and that should take care of watching the set in DTV. Most cable boxes have a setting for format changes in the customer menu, depending on the type of box. If you are able to change the format, then the other inputs will not work since they need a 480I signal, as well as VCRs. Another setup could be to use the S-Video cable or Video input jacks to get a better picture in 480I instead of using the cable input. However, when changing from HD to Analog, you will have to change to the correct input on the set as well. Hope this helps.
Dec 24, 2006 | Samsung HCJ655W TV
LG 42PJ350 42 in. TV Logo
139 people viewed this question
Computer Repairing
Computer Repairing
