Can't open a newsletter in The Print Shop 22, Get a PMW error. Must get this newsletter to printers on Wednesday...urgent. Using XP.
  • 3 more comments
  • sunduffer11 Apr 04, 2011
    Tried restore 5 times with different dates and times. Document did not revert back to earlier date.
    And still could not open it. Now I stuck again.....can't find DOS
    Did you get my reply? Did Restore with different dates...document did not change back and could not opne. Now I can't find DOS.
    sunduffer11
    OK Benjz,,,typed in sfc.scannow (in CAPs) not recognized.
    sunduffer11
  • sunduffer11 Apr 06, 2011
    Tried all solutions you gave me....nothing helped. The trouble document must be corrupt...nothing will open it. I give up.
    sunduffer11
  • sunduffer11 Apr 08, 2011
    I asked you 3 days ago where do I find DOS. I never got an answer. Nothing you suggested helped me. Remove my name from your list.
  • 844 Answers
Hello Sunduffer11, welcome to FixYa!
Make sure that you save your Print Shop File in My Documents folder before doing the following:
Solution 1.
Do a System Restore.
  • Click start, programs, accessories, system tools, system restore.
  • Follow the system restore wizard. Restore your system to a date when Print Shop is running smoothly.
  • Then try to open the newsletter again.
Solution 2.
Uninstall Print Shop and reinstall it. (You must have the installer CD or the setup file and the serial number.
  • Click start, control panel, add/remove programs.
  • Scroll down and look for Print Shop and double click to uninstall.
  • Restart your computer.
  • Insert the Print Shop CD (or run the setup file) and follow the installation procedure.
Thanks for using FixYa.
Keep me posted.
Jas247
Posted on Apr 05, 2011
  • Jas Barinaga
    Jas Barinaga Apr 06, 2011
    If this did not work, the next best thing to do is to try to recover it using a popular recovery software such as "Recover My Files"
    , but it also does not guarantee a 100% recovery of the corrupted
    file. Corrupted Print Shop files does not occur often and is not
    popular hence we have limited ways and resources to deal with it.
    You can try to right click on the corrupted file, click on properties
    and see if it has the option to restore in previous versions as seen in
    the image below.
    Try also to update your anti-virus and run a full scan, corrupted files are sometimes cause by virus and running an anti-virus software sometimes recovers the corrupted file.
    I can sense the frustration of loosing an important file as it happened to me also.
    Thank you for using FixYa.
    Jas247
    Genius:
  • 1,570 Answers
Hi
I suggest you run the SYSTEM RESTORE. Go to START, ACCESSORIES, SYSTEM TOOLS AND CHOOSE SYSTEM RESTORE. The choose the previous date that your Print Shop is working fine.
Please post comments if you need more help. Regards
Posted on Apr 04, 2011
  • Benjamin Jr Singson Apr 04, 2011
    Another method is this.
    Go to START
    Right click on DOS command prompt and choose RUN AS ADMINISTRATOR ( if ask for password put the password)
    The type SFC /SCANNOW and press enter
    Note: The scan may take some time. Windows will repair any corrupted or missing files that it finds. If information from the installation CD is needed to repair the problem, you may be prompted to insert your Windows XP installer CD.
    I am sure these solutions will help solve your problem. Regards
  • Benjamin Jr Singson Apr 05, 2011
    Follow what I type,
I purchased windows 7 and I have print shop 22 how do I upgrade it to run with windows 7?
Check with Broderbund - either it will work OK - some programmes do or you may have to buy an upgrade - when have you heard that before!!
Feb 26, 2011 | Broderbund The Print Shop 22 Deluxe Full...
What version do I need for Windows 7. I do greeting cards and a newsletter.
What i suggest is you use Windows 7 Ultimate, click on this link so that you will be able to see the difference between them...
Hope this will help...Your response is very much appreciated...
Jan 21, 2011 | Broderbund The Print Shop 22 Deluxe Full...
Cannot install Broderbund The Print Shop 22 on XP
The specifications require Xp with SP1, maqke sure you have added SP1 aqt least to your XP version.
Jan 10, 2011 | Broderbund The Print Shop 22 Deluxe Full...
Will printshop version 22 work with windows7
Hi mfolkart,
Print Shop 22 is compatible with Windows 98 / 2000 / Me / XP
Not sure if Vista or 7 will run it.
Hope this helps...
Dec 29, 2010 | Broderbund The Print Shop 22 Deluxe Full...
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
Aug 04, 2010 | Broderbund The Print Shop 21 Deluxe Full...
Printer has stopped printing .pdf files
Check your list of printers and make sure the default printer is the correct one.
Mar 18, 2017 | HP OfficeJet 6210 All-In-One InkJet...
I am continually receiving an error message when I try to open Print Shop 22 - either Windows cannot access the specified device, path or file. You may not have the appropriate permission or Could not...
have there been any operating system changes ? like moving from xp to vista ? this would be a simple upgrade if that was the case , has your product id expired ? i'd go to the manufacturers site if none of the above has changed and see if they still support the software ?
Jul 12, 2009 | Broderbund The Print Shop 22 Deluxe Full...
Hp laserjet 3050 scan problem
You should go to HP.com and look for a TWAIN scanner driver the works for that printer in Vista.
Jun 14, 2008 | HP LaserJet 3050 All-In-One Printer
Urgent soln
try to move the silver plate (under the printhead) up a litle bit.
this silver plate is the "print head open, and the media sensor.
Mar 21, 2008 | Zebra Z4M Printer
Install of IBM infoprint printer drivers
make sure you are logged on a the Administrator to the computer then try installing..
Dec 26, 2007 | Office Equipment & Supplies
Computers & Internet Logo
394 people viewed this question
David Payne
David Payne
