Question about Dell Inspiron 1564 Laptop AC Power Adapter (19V/3.2A 65Watts) by (OEM) AC Adapter
My laptop is turned off and never work again. When i press the power button nothing happen.my laptop is dell inspiron 1564.im asking.is the bios make this problem?
MerlinTech
  • 197 Answers
SOURCE: dell inspiron 6400 notebook wont turn on
try this with battery removed first..
plug in ac power, no battery,
then when turning on machine, press F8 to go to safe mode(pick the top option)
see how that works forya
Posted on Jun 14, 2008
  • 151 Answers
SOURCE: laptop dell inspiron 1545 no power up
Hello anourkhader
When was the last time you used it, and were there any problems? To find the solution to this problem is a matter of elimination. You should check the following:
Step 1 - Power
- Try an alternative power adapter
- Try plugging in your laptop to an alternative power supply
WARNING - BEFORE PROCEEDING, PLEASE FOLLOW THE FOLLOWING SAFETY PRECAUTIONS!
1. REMOVE THE POWER ADAPTER FROM YOUR LAPTOP
2. REMOVE ALL PERIPHERALS
3. WEAR A WRIST-GROUNDING STRAP, AND CONNECT IT TO AN UNPAINTED, METAL SURFACE. IF ONE IS NOT AVAILABLE, TOUCH AN UNPAINTED METAL SURFACE TO DISCHARGE ANY STATIC FROM YOUR BODY
Step 2 - Remove and reset basic hardware items
Remove and reseat the items mentioned below in the order they're mentioned:
- AC adapter
- Battery
- Memory
- Hard drive
For instructions on how to do this, please refer to your user manual. If you no longer have it, you can download it from here: http://support.dell.com/support/edocs/systems/ins1545/
If after following the above instructions, your laptop still doesn't turn on, I would recommend that you contact Dell customer support, which you can do by following this link: http://support.dell.com/support/topics/global.aspx/support/dellcare/contact_technical_support?
I hope this helps. Please feel free to contact me if you require further assistance.
ajblaj
Posted on Apr 28, 2010
  • 66 Answers
SOURCE: my dell inspiron 1520 does not work at all, power
no this is not a defect this would indicate that the power supply has failed on your pc.. look at the back of the unit if the power supply light is amber in color or blinking thne there is your issue.
Posted on May 15, 2010
dj_relly999
  • 4070 Answers
SOURCE: Dell 2007FPB LCD Won't turn
Hi and welcome to FixYa!
As a first course please check the monitor power cable. It may be a little loose that's why its not powering up.
Hope this helps and thank you for using FixYa!
Posted on Dec 02, 2010
SOURCE: dell inspiron Mini 1018 wont turn on, power
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Remove the battery, remove the cover that houses the memory then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Posted on May 12, 2012
How to turn on WiFi on my dell 1564
try F2 key ( with and without Fn Key) to turn on /off Wifi
Jul 26, 2014 | Dell Inspiron i15648634OBK 1564 Laptop...
How to rplace CMOS cell in Dell 1564 INspiron Laptop?
turn off the laptop, remove the cables and battery. Press and hold power button for 8 secs. Remove the screws at the back of the laptop. Remove the hard drive (by flipping upwards), remove the optical drive (by removing cables and the drive itself) . Turn the laptop around and remove the screws at the top of the keyboard. Lift up the keyboard and you will see the motherboard. Then you will see a circle covered with silver coating (which is the CMOS battery). Press the eject button and insert the replacement...
Oct 09, 2010 | Computers & Internet
I have Dell inspiron 1564 (windows 7 64 bit). The monitor goes blank with a screeching noise. I have run the PSA diagnostics but it showed no problem. The laptop runs normally otherwise but this problems...
I now have the same problem with the same Dell model (1564) for the second time in less than a year from purchase. The last time it happened I called the service technician who fixed it. That makes me wonder if this may be a common defect in this dell model, which requires a technician visit every 4 months. I advise you to apply to the company and ask for solution such as providing you a different model as a substitute for the defective one.
Sep 23, 2010 | Dell Inspiron i15648634OBK 1564 Laptop...
I am using dell inspiron 1564 .now i cant even install a single game because of vga problem ... what shall i do now sir
As you are using dell inspiron 1564 it comes with a atleast 512mb graphics card by default. If you are not able to play games on it due to Vga problem first check you install the proper vga display drivers for the laptop or try to reinstall the vga display driver again from the drivers disk you get with the laptop. After installation of proper vga drivers all your games will work perfectly.
Aug 27, 2010 | Dell Inspiron i15648634OBK 1564 Laptop...
My laptop does not turn on at all.
remove the battery and adapter. press power button for 30 sec. then connect the adapter. press power button. if this didnt work. you need to ask for an help of a local tech to check for the video card and cable.
Apr 05, 2010 | Toshiba Satellite P105-S6104 Notebook
My laptop fell down and now my screen does not display anything
try to press and hold Fn and F8 - this is to toggle screen setting to ext and back to LCD on laptop. if nothing happens turn off computer by pressing power button, unplug the ac adapter, remove the battery. remvoe residual electricity from computer by pressing power button 10 times. just plug again the ac and leave the battery out. Pres and hold the letter D and while holding that press the power button once and release both of them. it will perform the built in self test on the lcd. if nothing happens, turn off computer. press anf hold Fn and while holding it press power button. it will perform diagnosis on computer. if still nothing happens need to repalce motherboard and LCD.
Mar 03, 2010 | Dell Inspiron 6000 Notebook
Dell inspiron 1564 xp problem
There is a firmware update listed for January 10, 2010 on the Dell website. I would recommend punching your Dell Service tag into the driver and support section of the website and downloading/installing the bios update. If this does not resolve your issue comment back and we will move further.
Good Luck,
NOLA Tech
Jan 28, 2010 | Computers & Internet
Dell Inspiron 8200 Won't Boot up. Not even to BIOS.
Latitudes sometimes have a problem with RAM. Try these things to get it to boot...
1. Remove the RAM modules, clean the contacts with a pencil eraser, reseat modules and test.
2. If two modules, remove one and test. Place same module in second slot and test.
db
Mar 24, 2009 | Dell Inspiron 8200 Latitude C840 Laptop...
Boot problem on inspiron 1150
Try connecting it to an external monitor.
When you do, as soon as you press the power button to turn on the laptop, close the laptop lid - as this forces the laptop to display on an external monitor.
If this works, then it means the laptop screen is bad.
If it doesn't, the most likely cause would be that the laptop video card went bad.
For a while, some older Dell laptops with high-end nVidia graphics cards tended to die suddenly.
Mar 27, 2017 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell Inspiron 1564 Laptop AC Power Adapter (19V/3.2A 65Watts) by  (OEM) AC Adapter Logo
15 people viewed this question
Alun Cox
