Question about Norelco 7886XL Electric Shaver
The little wire that connects the head to the body flipped off and down the drain. Need a replacement
  • Norelco Master
  • 1,610 Answers
The wire hinge is sold attached to the head holder. You will find this item at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-quadra-head-frame-with-hinge.html
Posted on Apr 04, 2011
How do you get to the accelerator switch on John Deere turf tractor
flip the tractor over and you'll need to pop out the gray plate that holds the foot pedal with a flat head screwdriver and then the wires should be red white blue connected in that order
May 19, 2012 | Peg Perego Power Wheels ACCELERATOR...
Headlight bulb replacement on renault modus
Replacing a dipped head light bulb on a Renault Modus.
Having recently purchased a 2008 Modus with the passenger side dipped beam head light bulb not working. Concerned that posts on this matter talked about removing several body parts or a costly visit to the Renault dealer.
It's a simple 10 minute job. It is a little tricky with limited access and restricted view. However - its as simlpe as - remove circular cover from rear of bulb holder - remove the clip on connecter and push to side. You need to pull the wire clip above the bulb slightly to the side from its holding and it flips down and out of the way Be careful not to detach the clip from its holding points below the bulb - it's extra hassle to put back in.
You can now remove the old bulb - replace with the new bulb. Make sure its sitting correctly in housing. Re attach the clip to its holding point above the bulb. Replace the connector.Replace the circular cover to the rear of the bulb holder.
It takes 10 minutes - cost me under five pounds for the replacement bulb. Hope this helps.
Feb 05, 2012 | Renault Modus Cars & Trucks
1.5 year old 7140XL worked fine, then next time would not turn on at all. Charge light shows charged.Any suggestions?
There are two likely possibilities. These problems would either be that the head is damaged or jammed or there is a loose connection inside.
You can easily test if it is the heads by flipping up the head assembly and then turn it on. If it runs with the heads flipped up but not when they are snapped down, you can assume that the heads are the problem and they will need to be replaced. You will find replacements for this model at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-hq8-spectra-sensotec-replacement-heads-p-251.html
If the shaver will not run with the head flipped up either, you may have a loose connection inside...usually from the moto to the circuit board or from the battery to the circuit board. You may be able to locate and repair this but if your shaver is 1.5 year old, it is still under warranty. If this is the case, contact Norelco using the info in your user manual for the warranty
Jun 30, 2010 | Philips 7140XL Electric Shaver
How to put air in the tires the stems are different
Your bike tube has Presta style valves. Automotive style valves are known a schraders. To inflate the tube, you will need either an adapter, presta to schrader or a hand pump that has a head for presta valves. Any bike shop will have one for sale. To fill the presta valve style, remove the black cap(if it is there) You will see little stem with a small knurled nut. Screw the nut all the way up until it stops. Put the pump head over the stem, making sure it is pushed down. Flip up the lever on the pump head, fill to desired pressure 100 to 120psi...yes, that much pressure, it's a road bike. Flip the lever on the pump head down and remove it from the stem. The PSST you will hear is the air from the line on the pump...not the tire. Screws the knurled nut down and replace the black cap. If you do not srew the little nut down and push on the stem you will let the air out of the tire. If you need more help, you can email me @ danklett@yahoo.com and I will send you pictures of the process, or the staff at your local bike shop should be able to show you how.
Jun 12, 2010 | GMC Denali 700C Road Bike
My Dell Insprion got wet and now the keyboard doesn't work
let it dry out for a couple of days and try it. blow it out with a hair dryer. buy a replacement keyboard on ebay or use a usb keyboard
Oct 26, 2009 | Dell Inspiron 1501 Notebook
The basket full light will not go out
YOU WILL HAVE TO HAVE SENSORS REPLACED
Sep 15, 2009 | Fellowes DM15C Shredder
Model 110 does not drain
if you don't want to replace the lid switch you can bypass it,remove the 2 head screws one on each side,you may have plastic caps to pop off one on each side,flip the head up,you will see the lid switch jack on the washer,unplug it,cut the 2 wires on the outside of the wire jack leave middle wire(the side of the wire jack that goes to the timer)wire them together with a wire nut,plug back in , put head back and your done,let me know how you do-mike
Apr 09, 2009 | Kenmore 22642 Top Load Washer
How do I replace the water pump?
replacing pump,,theres two screws on either side of console..phillps head remove end console caps if equipted,,with hand..if earlier mobel there right behind console..flip console back dont remove..disconnect lid switch,,the small harness that has the brown and gray ,,wires with a green groun,,always unplug unit first...remove 2 brass clips on booth ends,,now just pull the cabnit toward you and leave on side,,look straight down at your feet theres your pump,,the plastic part with the 2 hose leading out it..pry punp clips up with a smal screw driver,,twist a little and there off,,remove drain hose,,and tub to pump hose ..reverse to put together
Dec 27, 2008 | Kenmore 22422 Top Load Washer
Remote works, but not the reciever
This one is tough one. It soundslike you have lost the connection between the flip face and the main head unit. I suggest you pull the head unit and get it to a bench for closer investigation. Look for and tears in the connecting wire harness between the Flip control, and the main Unit.
Sep 03, 2007 | Toshiba Sony CDXM8805X
Kac-8152d
Are you sure you are getting signal to the amp. Try another signal source. try temporarily connecting the shield of the input cable to the car body ground. The signal ground may be open in the head unit due to a previusy faulty amp.Most newer head units ave tis signal ground fused inside the head unit.Older ones ma have bunt circuit trace. If it works when you groud the input to the car body this is what has happend. The previous amp had an open power ground so the curent when to use the signal ground but it will not hold the curent so it in turn opened.
Apr 02, 2007 | Kenwood KAC-8152D Car Audio Amplifier
Norelco 7886XL Electric Shaver Logo
59 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
