Question about InFocus Proxima Pro AV 9310 Multimedia Projector
Hello., I've just tried to power up a Proxima 9310., and for the first time in my experience the orange light has come on and shut down has effected after a couple of seconds. I would like to ask for advice with my lack of specific familiarity on this one. Yours Sincerely Pol
  • InFocus Master
  • 6,694 Answers
Time to replace the lamp of you projector.Lighting up of the orange light indicates that. All the projectors comes with self disorganizing program. if there is any complaint except power supply that will indicated by the projector by its self disorganizing system.
switch OFF the projector for some time. then power it ON. if picture come then first of all reset the lamp hour timer. To do the same do the follwing
1. Press the menu button and press rear click button or select button
2. Select settings press the rear click or select button
3. On setting display select Lamp age and press the rear click or select button
4. Move the arrow to Yes and press the rear click select button
OK will displayed and wait for your conformation
5. Move the arrow to Yes and press the rear click or select button
if there is no picture when you switch on the projector then go for a new lamp. you hve to do the reset procedure after replacing the lamp. It is always recommended the you should reset the lamp hour only after replacing the lamp.
ok
Posted on Apr 04, 2011
Why is our Proxima Desktop Projector 8000 turning off after a period of time?
There is a THERMAL fuse that is used to prevent fires and electrical destruction of the unit. Lamps get very hot and unless the AIR flow is good, the temperature gets too hot and shuts down the system. The fan speed may be too low, the unit may need to be cooled down with an exterior fan? Try options.
Jan 04, 2015 | Office Equipment & Supplies
Proxima dp6150 shuts down unexpectedly
the interface between the mother-board and the power-supply is not work well
Add some solder on the interface , it will increase the contact surface
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, motherboard,
powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 18, 2014 | InFocus Proxima DP6150 Multimedia...
I have a KDP-65WS550 when i turn the power on it shuts off by itself, I've tried all the reccomended fixes and none have worked, the red light is blinking 10 times
Hello Mike
I don't know what else have you done with your TV. Yet, from the number of blinking code, I do understand that its video out board has the trouble. But, before going forward with you I want to know whether you are aware in electronics and have some experience in serivce TVs, and can follow the schematic diagrams, if I send it to you. If you aren't aware in electronics and cannot follow the circuit diagram of this set, there is no use of going forward. If you are confident, inform me. I'm ready to assist you. OK.
Nov 22, 2011 | Sony Grand WEGA KDP-65WS550 65" Rear...
Hello. I'm having a little problem... I have an White-Westinghouse split-type air conditioner (model WSA12PTGMA). The problem is i've lost the user guide manual... and now (after a long period of...
The unit is low on refrigerant and the freeze sensor is shutting the unit down... if you reset it is will wait for the 15-20min to time out before it shuts down again...
heatman101
Jun 20, 2011 | Electrolux Heating & Cooling
Need to calibrate my projector but i need services codes
try volume up-down, video,effect, computer, or volume down-up and different combinations of video,effect and computer. It's been along time since I serviced one of these but trial and error should give you the factory menu.
Oct 19, 2010 | InFocus ASK Proxima M2+ Multimedia...
Image is red
if the entire image is red but still clear, try brand new cables. If that doesn't fix it then the lcd cable could be unplugged or the lcd panel itself could be bad.
Oct 09, 2010 | InFocus Proxima Pro AV 9310 Multimedia...
I have a proxima s540 ultra lite data
From what you describe, it sounds like a fan isn't working. When you turn on a projector, it will go through a quick self test--checking that everything is operating correctly. Some of the fans send out a signal to the main board telling it that they are running. If no signal is received, the board senses this and auto-shut down occurs to protect the unit from heat damage. The errant fan could be spinning but the computer pulse might not be being generated. It will require a tech to find this out.
Aug 31, 2009 | InFocus Proxima UltraLight SV1 Multimedia...
Inspiron Battery Light Flashing Orange
Battery.
Dell has a chip internal to the battery programed to shut down after a certain number of charge cycles. This means every time you plug the laptop in with the battery installed. When it reaches this determined number the battery effectively shuts down, even though technically it's still good. There have been loads of complaints on the net toward Dell over this issue. I have myself experience this. Battery good one day, powered down, went home, powered up... only to receive the deadly flashing light. Only cure is to replace battery. Several hacks trying to get around this but they're all horrible. Bad Dell - bad, bad Dell!
Jun 29, 2009 | Dell Inspiron 6000 Notebook
Will not reset, light blinks 8 times
Hi there you can try this
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i950)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
All The Best Pineworks
Jun 04, 2009 | Canon I990 InkJet Photo Printer
InFocus Proxima Pro AV 9310 Multimedia Projector Logo
148 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
