Question about D-Link DIR-615 Wireless Router
I am unable to setup a security password for my wireless network on my Apple Macbook using D-link wireless router model DIR-615
  • Jeffrey Groves
    Jeffrey Groves Apr 04, 2011
    What have you tried so far?
  • susan
    susan Mar 08, 2014
    I have reset my password, I have unplugged my router and Roku and tried again
    Problem Solver:
  • 21 Answers
Enter a new login name and a new password for the administrator login. if you are a user then enter a new password and login name into the user login.
Posted on Apr 04, 2011
How can i fix dir 615 ssid stop broadcasting issue?
Step 1: Open your web browser and type in the IP address of the router (192.168.0.1 by default).
Step 2: Enter the username (admin) and password
Step 3: Under Setup Select the Wireless tab
Step 4: On Wireless Tab - Select Invisible if you do not want the SSID of your wireless network to be broadcasted by the DIR-615. If Invisible is selected, the SSID of the DIR-615 will not be seen by Site Survey utilities so your wireless clients will have to know the SSID of your DIR-615 in order to connect to it.
Sep 08, 2014 | D-Link DIR-615 Wireless Router
Have hooked up DIR-615. It says the network "dlink" requires a password. Is this predetermined if so how do I find it. I have tried my usuall computer passwords to no avail. Thanks
I assume you're talking about the wireless network, not the wired network.
This password is manually set, not predetermined. To know/change it you'll have to use a network cable to connect to the router instead of wireless.
Once connected, open up your browser to 192.168.0.1, this should bring up the router's web configuration page, from there:
- Login (by default: user: Admin, pw: <blank>
- select WIRELESS SETTINGS and press the "Manual Wireless Network Setup" button
- you should see the configured wireless password at the bottom under the "Wireless Security Mode" section.
if you failed to login with Admin/<blank> combination it means the password is changed previously, in this case, you must reset your router.
Quote from user manual, here's how to reset it:
"To reset the router, locate the reset button (hole) on the rear panel of the unit. With the router powered on, use a paperclip to hold the button down for 10 seconds. Release the button and the router will go through its reboot process. Wait about 30 seconds to access the router. The default IP address is 192.168.0.1. When logging in, the username is admin and leave the password box empty.
Good luck
Jun 13, 2012 | D-Link DIR-615 Wireless-N Router (54682G)
Can't connect my iphone4 to dlink it says dismis
lets try removing the security configuration if any from the wireless network then try connect the iphone again.
Dec 04, 2011 | D-Link DIR-615 Wireless Router
D- link 615 router how do i find out my network securtiy key
Type in 192.168.0.1 on the address bar of your browser and open it up. If it asks you to login, make use of "admin" as the username and password. Next, click on wireless setup then click manual wireless connection setup and look for your wireless network key there.
Aug 27, 2011 | D-Link DIR-615 Wireless Router
I cant find the 8 digit pin on the router lable of the router. d-link dir-615
Connect a network cable to your computer from your router. Goto http://192.168.0.1 on your web browser. Press login (password may be blank or it might be admin, or if you setup your own password, put it in)
Click Wireless Settings (on the left menu) Now click Manual Wireless Network Setup. The current PIN will be displayed here. You can reset the PIn to default or generate a new one, or if you don't want to use PIN protected setup, disable it by taking the check mark out of the Enable option.
Regards, Chris
Jul 01, 2011 | D-Link DIR-615 Wireless Router
I dont remember my password
In order to find the wireless security password of your Dlink wireless router DIR-615 , please follow these setps
1. Open up the internet explorer in the computer in which you are online and clear the address bar and type in the number 192.168.0.1 and hit enter.
2. You will be logged into the D-Link router setup page .
3. Under the SETUP tab, in the left hand side, click on WIRELESS SETTINGS? you will find Wireless security Mode under which you can find the password for the wireless settings.
Good Luck!
Thanks in Advance!
With Regards,
Prema.
Jan 03, 2011 | D-Link DIR-615 Wireless Router
The red light on my d link 615 came on after I reset my router. It gave me a new password and renamed my network.
You need to enter router config page (connect via cable) 192.168.0.1 and setup cloning MAC address (this depending on your ISP requirements, i.e. VirginMedia), then rename your network and secure it with WPA-PSK2 password
Oct 25, 2010 | D-Link DIR-615 Wireless Router
Cannot connect MacBook to DIR-615 router
Is your wireless network secured ?
If you are trying to connect to the secured wireless network, make sure that the network that you are typing is correct.
If you are not sure about the network key
then check the network key on the router.
You said that MAC is able to connect to the neighbor's wireless network.
Make sure that the Wireless MAC filter on your router is disabled.
Click here to know more about network key
Oct 06, 2009 | D-Link DIR-615 Wireless Router
How do i secure my dir-615 router
1. Log into the router by typing 192.168.0.1 in the address bar of your browser.
2. User admin for the username and leave the password blank (unless you have changed the username and password, if so use your custom settings)
3. Next run the security security wizard: Click Setup at the top then click Launch Wireless Security Setup Wizard.
4. It will take you step by step to set up a secure wireless network.
I would also suggest you change the router password while your in there to prevent others from accessing your router using the default setting if you have not already changed it.
You can download the user manual for the router at:
http://www.dlink.com/products/?tab=1&pid=DIR-615&rev=DIR-615
Happy Surfing!
Jun 06, 2009 | D-Link 802.11g Wireless Router WBR-1310...
MacBook not connecting to DIR-655 Router
My solution was that I changed the wireless mode from "B,G and N" to just "B and G," and then it worked fine.
Nov 23, 2008 | D-Link Xtreme N DIR-655 Wireless Router
D-Link DIR-615 Wireless Router Logo
344 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
