PLEASE TELL ME WHAT DOES A MASTERCOOL CLEAN MACHINE PURGE PUMP DO?
    Scholar:
  • 133 Answers
From the ad below, it replaces old water with fresh. ------------------------------------------------------------------------- » HVACR» Air Conditioners» Evaporative Cooler Accessories Universal Cooler Cleaning SystemBrand: MastercoolModel: CM120ASKU: 47495 PLEASE TELL ME WHAT DOES - 34252_300.jpg
$74.13
3 Business Day Shipping $7.91
No Longer Available Mastercool CM120A Universal Cooler Cleaning SystemTotal Ratings: 0
Average Rating: 0
Review this item transparent.gif Product Information Item Cleaning System Function Timer-actuated, Automatically Removes Mineral-laden, Dirty Water every Six Hours and Replaces with Fresh Water, Reduces Scale Deposits and Leaves Pads Cleaner, Saves Up to 70 Percentage of the Water Weight 3.10
  • Replacement Motors and Accessories
  • Universal Cooler Accessories
  • Cleaning System
  • Save up to 70% of the water used in bleed-off cleaning systems.
  • Timer-actuated drain system automatically removes mineral-laden, dirty water every six hours and replaces with fresh water.
  • Reduces scale deposits and leaves pads cleaner.
  • Uses: For residential size coolers only.
  • Note: Limited availability.
Universal Cooler Cleaning System, Clean Machine Pump Cooler Flushing Device for Residential Size Coolers Only
Posted on Apr 05, 2011
My printer says it's unable to clean 46? it's a mfc printer LC-51 Series ink
Please note that this error code appears when the container in the printer that is responsible for storing used / discarded ink is full or registers as full.
The following instructions will guide you through the process of resetting the printers self clean counter so the error will go away but in the event that the ink absorbing box is actually full and this is not an erroneous message the error message will trigger again immediately.
Machine Error 46 - Purged Ink Box Full MFC620CN/420CN/410CN/210C and FAX2440C
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An "initial purge", for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an "Unable to Clean" external message and will be unable to use the printer. The "Unable to Clean" external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Resetting purge counter MFC620CN/420CN/410CN/210C and FAX2440C
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Also please note that if the ink box is full and the error code is reset the printer may begin to spill out excess used / discarded ink.
I suggest purchasing a new ink absorber box and installing it.
May 04, 2011 | Brother MFC 420CN All-In-One InkJet...
Cool tech 34788 purges alot. Excessive purge time and set error messages for being unable to purge.
Please check 1# The refrigerant which you'v add to the machine, it may CONTAMINATE or NOT PURE R134a. the machine will purge continue while active VACUUM mode if refrigerant is not origenal ! Identify refrigerant if possible.2# Check the automatic air purge device & air purge solenoid repair or rebuild as require
Jul 13, 2010 | Robinair Cool Tech 34700Z Recovery,...
How can I fix MFC3360C printer "Clean Unable 50" error ?
try these steps ....
- Machine off
- Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
- press 80
- press the “mono start” button several times until you see “purge: xxxx”
- press “2783” in order to reset the purge counter. You will see: “purge:0000”
- press the "stop" button.
- press “99” to exit the maintenance mode.
tell if if any issues
May 01, 2010 | Brother MFC-3360C All-In-One InkJet...
Mastercool pump runs when themostat is off.
Check the compressor relay (in the outside unit) Most likely it's stuck.
Sep 12, 2009 | Mastercool 67680 Evaporative Cooler Air...
How to fix clean unable 46, pls tell me how
This is for the mfc5440 but should work I would really need the cleaning absorber pad replaced but takes a bit of getting to. - Machine off - Switch on the machine while holding down the ?menu?button until all the leds are flashing on/off. Now you are in ?maintenance? mode. - press 80 - press the ?mono start? button several times until you see ?purge: xxxx? - press ?2783? in order to reset the purge counter. You will see: ?purge:0000? - press the "stop" button. - press ?99? to exit the maintenance mode.
Jun 12, 2009 | Brother DCP 130C All-In-One InkJet Printer
Replacing pads
How do I replace a rigid pad on my Mastercool swamp cooler?
May 22, 2008 | Mastercool 67680 Evaporative Cooler Air...
Summer
If it was not drained for winter, do so and then remove all scale from the pan, pump inlet screen, etc. Replace the pads if they are scaled up and remove any scale from the louvered panels. WITH THE POWER OFF, check the belt for cracking and check to drive motor and blower wheel bearings for smooth operation, oil bearings with oil ports. With clean water in the sump, a good drive belt, clean pump screen and clean pads, the unit is ready to power up and run test the float action/shut-off, water distribution through the arms, belt tension (just enough to prevent slipping). These units work best when they can fully evaporate the water, so let the air flow out as fast as it come into the cooled space to maximize the evaporative effect. Also note, these unit must be level to work properly.
Apr 27, 2008 | Mastercool 67680 Evaporative Cooler Air...
Heating & Cooling Logo
990 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
