Question about Philips RC2K16 Remote Control
I have philips rc2k16 remote that is not working with dvd player. ive changed batteries and still no response from player when trying to even turn it on. does it need to be reset or replaced?
4 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: Dog chewed my Philips DVD remote!
Remote codes
http://www.remotecentral.com/index.html
Posted on Mar 17, 2008
SOURCE: what is the remote code for PHILIPS DVP5990
I'm using the GE Universal Remote, and found that the four digit code 0914 worked.
Posted on May 05, 2009
SOURCE: i have a philips universal remote code-cl043 and
I just move and lost my code sheet for my phillips universal control is there some where i can get some codes,i have a emmerson television thanks.
Posted on Oct 02, 2010
Constant standby mode on philips DVD player
Hi Johnny
Please follow these steps (even if you are sure you have done them correctly :)
1) Check if something is blocking the path between the remote and the IR sensor on the DVD player.
2) Check your remote control batteries to make sure you have fresh batteries inside(try with new ones to be sure)
3) Make sure that you have inserted the batteries according to the polarity that is instructed.
4) Remove all the cables but the power supply and try to see if it works. If it does you have some faulty cable which should be replaced.
5) At last if none of the above points helps then either your DVD equipment or the remote control is faulty. You may contact your vendor demanding you guaranty wright or a service shop for diagnose and repair.
Finally , please don't forget to rate my post.
Wish you best of luck.
Best Regards
XyFinx
Dec 14, 2013 | Philips DVP2880/F7 DVD Player
Remote stopped working
clean the circuit board on the remote moisture might be the problem
Aug 14, 2008 | Philips DVD750VR DVD Player/VCR
Remote control will not operate dvd player. changed batteries. will not work. turns on manually but can't make any selections with the remote
The remote has probably quit working, to be sure take it to a tv repair shop, they should be able to check it while you wait.
Dec 31, 2010 | Philips DVP642 DVD Player
I've changed my batteries but my remote still doesn't work properly. It will turn the player on and off but will do nothing else. I can't get into the menu or anything. What's the problem? I also have...
it means your remote is not defective in batterynya only. you must open the remote case and you will see a small part of yellow color is called Crystal Filter oscilator, this part should be replaced. if the result is the same as before you should also replace the remote sensor LED
Jul 27, 2010 | Philips DVD750VR DVD Player/VCR
Remote control for philips dvd player DVP3020 just stopped working for some reason and I cannot get it going again. And yes, I have changed the batteries, and put the remote right up to the sensor on the...
yep! the code may have dropped out. Try using a programmable remote.
heres the codes 0 5 0 3 ,0 5 3 9
Please rate our help to keep FREE service online
Aug 30, 2009 | Philips DVP3020 DVD Player
Apex AD-2600 DVD Player
wuts the code for a jvc dvd player
Feb 22, 2008 | Philips PM435S Remote Control
Remote control wont work
just press play on the remote or on the front pannel of the player. if your remote still doesn't work try changing the batteries :-)
Feb 07, 2008 | Philips DVDR3380/05 DVD Recorder
Philips RC2K16 Remote Control Logo
96 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
