Question about Nintendo Wii Console
How do i reprogram my wii remote after it has been used for another wii box
    President:
  • 1,623 Answers
Just open the battery compartment and press the red button then open the flap on the front of the wii console and press that red button. The lights will flash on the wii mote until one stays lit then it is paired
Posted on Apr 04, 2011
How to reprogram a universal remote control?
http://www.youtube.com/watch?v=fXDdeXmJjfM
http://www.remotecentral.com/features/remotes.htm
Instructions
    • 1 Find the brand of the universal remote you own on Internet sites like Remote.com (see Resources below).
    • 2 Click on your universal remote brand on the website to find the code list for that remote.
    • 3 Check to see if your remote is preprogrammed to operate your TV, VCR, or Cable Box using the following codes: TV - 000, VCR - 000, Cable Box - 000, AUX - use VCR code 037.
    • 4 Manually turn on your device. Hold down the "Code Search" button on your remote, then press and release the device button you want to set up until it flashes.
    • 5 Push the power button repeatedly until the device turns off, then hit "Enter."
    • 6 Press any other button while the device is on to see if the device responds. If it does, you don't need to do any other programming. If it doesn't, repeat steps 4-6.
Read more: How to Reprogram a TV Remote ' eHow.com http://www.ehow.com/how_4454612_reprogram-tv-remote.html#ixzz1mji7B48P
Feb 17, 2012 | Sony DVD/VCR Combo Player
Tip
Wii Cursor is off-center, jerky, erratic, disappears, etc.
  • Verify that the Wii Remote's pointer lens is free of obstructions and contamination (stickers, heavy smudges, etc.). The pointer lens is the tinted rectangle at the end of the Wii Remote. If the Wii Remote Jacket is being used, verify that it's securely in place on the Wii Remote. If the Wii Remote Jacket is askew, it might be partially blocking the infra-red sensor on the front of the Wii Remote.
  • Try a new set of batteries. Occasionally weak batteries can cause this type of behavior.
  • Reset the Wii Remote:
    1. Take the batteries out of the Wii Remote, wait for one (1) minute, and then re-insert them.
    2. Wait a few seconds before pressing any buttons to wake up the Wii Remote.
    3. Re-sync the Wii Remote by using the steps listed above in the white box titled "Try these steps!".
  • Check the Directional Sensor Functionality by holding the Wii Remote with the button side down. Without using much force, tap the button side of the remote against the palm of your other hand. Doing this does not take a lot of force, so be sure not to tap the Wii Remote very hard.
  • Verify Sensitivity Setting dots:
    Go to the Sensor Bar's sensitivity setting in the Wii menu.
    • If only one or no dots appear on the sensitivity screen, there is likely a problem with the Sensor Bar.
    • If there are more than two dots, then it appears there is an additional light or infrared heat source being picked up by the Wii Remote. Avoid sources of infrared light in the gameplay area such as electric, propane or kerosene heaters, flames from fireplaces or candles, and stoves or other sources of heat.
    • If both dots appear and the erratic behavior continues even when you move closer to the TV, there is likely a problem with the Wii Remote and it will need to be repaired.
on Mar 04, 2010 | Video Game Consoles & Games
Tip
Our wii has been boxed away awhile we cant get it to reconize our emotes can help
Here is a step by step instruction on Syncing your Wii remotes to you console!!http://www.nintendo.com/consumer/systems/wii/en_na/setupWiiRemote.jsp#Synch
Synchronizing the Wii Remote with the Wii Console Synchronizing the Wii Remote to a Wii console allows the Wii Remote to communicate with the console. The Wii Remote included with your system should already be synchronized to your console. However, all additional Wii Remotes you use with your system also need to be synced in order to function properly..
There are two different modes of synchronizing (syncing):
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please click here.
  • ONE TIME MODE - This mode allows you to temporarily use your remote on a Wii console other than your own, or to use a friend's remote on your console. It can also be used to change the order of the Wii Remotes, without the need to turn off the Wii console. One Time Mode does not delete the Standard Mode setting stored in the Wii Remote. In this mode, the Wii Remote will only communicate with the Wii console while the power is on. When the power is turned off, the Wii Remote will lose its sync with the Wii Console. For instructions on One Time Mode setup, please click here.
Note: Only a Wii Remote in Standard Mode can turn the Wii console power ON or OFF.
Standard Mode Synchronization
Note: Make sure you have placed batteries in the Wii Remote (how to).
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED will blink. Quickly press and release the SYNC button on the inside of the SD Card compartment on the console.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote added to your system.
Sep 12, 2011 | Nintendo Wii Console
How do it get google on my wii ?
  • Turn on the Wii console.
  • 2
    Select the "Internet Channel" box from the main menu and press the "A" button on the remote. Click "Start" on the bottom right side of the page.
  • 3
    Point the Wii remote at the circle on the top of the page that has "www" in the middle of it and the words "Web Address" underneath it. Press the "A" button on the Wii remote.
  • 4
    Type "www.google.com" in the box at the top of the page, using the "A" button. Click "OK" at the bottom of the page.
  • Sep 15, 2010 | Nintendo Wii Console
    Wii remote wont connect ?
    if it wont sync after using the red buttons then its just bad batteries from the sound of it or the remote has gone bad.
    Try fresh batteries or let the rechargeables charge (assuming they arent bad)
    Apr 30, 2010 | Nintendo Wii Console
    Connecting a second wii remote to Madagascar kartz
    ress the red button inside the battery cover of the wii remote, then press the red button inside the cover at the front of the wii. do this at the wii menu to register remote 2
    Apr 29, 2010 | Nintendo Madagascar Kartz Uk Pal Release...
    Reprogramming wii remote
    Okay, on the front of the wii open the door where you'd put in an SD card, and take the battery covers off the remotes so you can access the reset buttons on both the console and remotes. Then press the red reset button on the wii and then within a second or two press the ones on the remotes. This should connect your remotes to your wii.
    Mar 17, 2009 | Nintendo Wii Console
    Need help programming wii console remote
    take off the battery compartment for the Wii Remote, and you should see a small red sync button. While the Wii is on, open up the flap for the SD cards, and you should see a red sync button on the Nintendo Wii. While holding the red sync button for the Wii Remote, press and hold the red sync button on the Nintendo Wii. After a few seconds, put the battery cover back on, and test the Wii Remote. Have any questions, feel free to ask. Use the add more details part in your question to ask any more questions. Thank you and have a good day.
    Dec 19, 2007 | Nintendo Wii Console
    Nintendo Wii Console Logo
    152 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
